07-13-2018, 12:19 PM | #51 | |
Re: F/S C & K Auto Trans Shfit Linkage Setups SBC & BBC
Thanks, Mel! Yes, I’ll buy the shift linkage, as discussed this am.
Again, thank you, Tim Quote:
07-13-2018, 01:30 PM | #52 |
GM Addicted
Any transmission levers left? In need of one
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
07-17-2018, 10:20 PM | #53 |
Always on the hunt...
All out of the 4wd/K linkage setups at the moment, we do have both of the other 2wd auto linkage setups pulled/ready for shipment. If you haven't found anything in the next couple of weeks, feel free to check back in as inventory is constantly changing. Thanks, Mel
Sorry, not parting with any of these at this time, only offering the trans mounted piece as part of the full linkage setups. |
07-17-2018, 10:23 PM | #54 |
Ok thank you
07-17-2018, 10:27 PM | #55 |
Hey Tim, your under bed spare tire rack and the 2wd SBC/TH linkage setup pictured in above post #49 have been shipped, your package went out via FedEx home delivery on Tue. 07/17 and as of this evening the FedEx website is projecting that you should see the parts next Tue. 07/24 by the end of the day. Thanks again, Mel
07-18-2018, 07:11 AM | #56 |
I have an original BBC truck with TH 400 that has the linkage like the SBC with wider brackets. Any idea if in 1972 they changed or should I get the BBC setup?
thanks for the help. Just trying to put truck back. |
08-22-2018, 05:32 PM | #57 |
All 1968-72 C/10-20-30's equipped with a big block 396/402 and TH400 auto trans used the same as pictured above, 2wd BBC/Th400 linkage setup. If your truck is working/shifting fine as set up you can leave as is, or if concerned about bringing the truck back to original then get the correct setup. Mel
09-02-2018, 10:34 PM | #58 |
“On The Hunt”
I will take a 2wd BBC/Th400 auto trans linkage setup.
