Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-30-2018, 12:32 AM   #51
JackB
Re: 71 AZ Rust Free CST Blazer Frame Off
Something of a milestone today. It was a little over a year ago that I drove the Blazer into the garage. Today it moved out of the garage under its own power. It grew a couple of inches and turned blue. Working on aligning the doors before I put the front clip on.
JackB is offline   Reply With Quote
Old 06-30-2018, 07:50 PM   #52
JackB
Racking up the miles 1/10 already. Drove the Blazer on the trailer today and took it to the AC shop and got it charged up. Ended up going with R12 as it seems that was working best for most . Of course the AC effectiveness is somewhat limited by the lack of a windshield. One note on the AC, the reman A6 compressor came with the electrical connection at about the 2 O'clock position whereas the originals are more like 11 O'clock. I was able to make it work there but later discovered that it can be reclocked. At some point it will probably bug me enough that I'll get it fixed but it involves removing the compressor so it wont be anytime soon. Just a few more small items and the engine compartment will be finished and then I'm going to see about aligning the doors and getting the fenders and hood on. And remember how I said I didnt have any brake line leaks? Well I did, I just couldnt see it until it leaked enough to drip on the ground. Its a union on the inside of the frame rail thats leaking so add that to the list of things to sort out.
Old 07-04-2018, 08:35 AM   #53
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Lol! Congrats. Major milestone - looks like you'll be cruising here very soon.
You noticed the difference in clockface for the compressor harness connection also? My reman compressor that we repositioned the connection on blew a seal during charge and had to be removed and replaced. I have an original A6 compressor that I will send out for a rebuild.
Try shims to get the door aligned. Who knows maybe the new mounts differ enough from OEM that the alignment is slightly off.
Old 07-04-2018, 04:14 PM   #54
lks dcvn
lks dcvn's Avatar
I have to say that this things looks incredible and just over a year to do this type of transformation is awesome!
lks dcvn is offline   Reply With Quote
Old 07-04-2018, 06:34 PM   #55
JackB
Thanks for the words of encouragement. I hope its together soon but as I'm sure you guys know the little details just take forever. Seems like everything has to go together at least twice before it stays for good. It cracks me up when I watch the car shows on TV where they always seem to have a deadline and they work all night to finish the build just in time for some event. Sorry I aint buying it. lol
Old 07-06-2018, 04:12 PM   #56
JackB
Another 2 steps forward and 1 back day. Got the front fenders on but decided to take off the top and have it repainted. The top is not original to this Blazer and had been repainted at some point.I thought it was good to go but after getting it mounted and looking at it for a few days I noticed enough little things that needed to be touched up that I decided just to bite the bullet and have the whole thing repainted.
Old 07-08-2018, 10:58 PM   #57
DeadheadNM
Carpe manana
DeadheadNM's Avatar
You'll be glad you redid the top. Good decision.
Old 07-08-2018, 11:27 PM   #58
JackB
I'm sure I will. I picked up some of the Napa stoneguard as there is one area that would benefit from some texture touch up. From what I've read it appears the correct color is GM 521 White. Cant seem to get a handle on the correct sheen. Is it satin, semi gloss or somewhere in between?
Old 07-11-2018, 06:47 PM   #59
JackB
Some progress to report. Front fenders and grill are on and the interior is mostly installed.
Old 07-11-2018, 09:40 PM   #60
IronCanine
I'm trying....
IronCanine's Avatar
This is just a very solid build.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 07-20-2018, 07:26 PM   #61
JackB
Really close now. I changed my mind several times about the wheels and tires I wanted. In the end I went with the ralley wheels with 33 x 10.5 tires. Im happy with it. Too bad the blue will have to come off the lettering, it kinda goes with the truck.
Old 07-22-2018, 01:38 PM   #62
JackB
Pretty much wrapped up under the hood. I confirmed what I already knew from my Camaro days that repop tower clamps suck. I'm getting better though I've learned that if you lube them up good and run them in once outside the car the failure rate is much lower. Only lost a couple this time around. Next up alignment and exhaust.
Old 07-22-2018, 02:42 PM   #63
DeadheadNM
Carpe manana
DeadheadNM's Avatar
That all looks OUTSTANDING! The tower clamps can be a real pita. Don't forget the hose clamp on the hot water bypass valve...
Old 08-03-2018, 09:49 AM   #64
1972CST
1972CST's Avatar
Awesome build! Mine will resemble yours very closely.
I would like to get the details on your seat covers if I could- brand, where you got them, quality,...?
1972CST is offline   Reply With Quote
Old 08-03-2018, 04:49 PM   #65
JackB
About the seats..Good news and bad. Quality is great, the vendor (Truck World) not so much. My purchase went OK with them (long wait time but that didnt matter to me as I was many months from needing them when I ordered). Read this http://67-72chevytrucks.com/vboard/s...d.php?t=740358
Old 08-06-2018, 09:41 AM   #66
1972CST
1972CST's Avatar
Thanks for the seat info, have some decisions to make now.
Old 08-06-2018, 11:35 AM   #67
jaros44sr
jaros44sr's Avatar
Very nice build!!!
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-24-2018, 01:27 AM   #68
DBear
DBear's Avatar
very nice rig....curious to what lift and size you are running. thanks in advance
DBear is offline   Reply With Quote
Old 11-24-2018, 10:05 AM   #69
JackB
The lift is 2 inch Tuff Country EZ ride (12612K). Tires are 33 x 10.5
Old 11-24-2018, 03:15 PM   #70
DBear
DBear's Avatar
Awesome, I thought it was a 4"....I like the ride height....thinking of going to 2" from my 4" lift. I hear skyjacker add-a-leafs will give these k5's about 2". Do you have a measurement from ground to top of fenderwell? Thanks again for the info
Old 12-26-2018, 11:57 AM   #71
f.flujan
hey nice truck neighbor. I'm in menifee as well working on a 68 c10. Who painted the blazer? gotta have a beer one day and talk trucks
f.flujan is offline   Reply With Quote
Old 02-28-2023, 08:31 PM   #72
JackB
Hey guys its been a few years but Im back. Ive put a whopping 290 miles on the Blazer since I finished it. Ive decided its time to let it go and Im putting it in the Mecum auction Mar 31 in Glendale AZ. Heres the link if you know anyone who might be interested in bidding. https://www.mecum.com/lots/AZ0323-55...vrolet-blazer/
Old 12-16-2023, 05:51 AM   #73
yote1234
yote1234's Avatar
Beautifull blazer !!!
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is online now   Reply With Quote
Old 12-16-2023, 08:10 AM   #74
1970cstblazer
1970cstblazer's Avatar
Thumbs up Re: 71 AZ Rust Free CST Blazer Frame Off
Someone will be a happy camper owning that one!
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 12-23-2023, 11:34 PM   #75
LT7A
I guess it's long gone by now. I hope it went well for you Jack. I'd have a hard time letting go of one like that. Too bad we never got to see it out and about, but 290 miles isn't much out-and-about-ness ; ) It was really cool to see the work you did on this one. Have you got another project you're working on now?
