07-10-2018, 11:08 PM | #51 |
Re: GM connect and cruise engine package
One more
OLDIRONRACING |
07-10-2018, 11:10 PM | #52 |
Some more that got done.
OLDIRONRACING |
07-10-2018, 11:11 PM | #53 |
Some more pic
OLDIRONRACING |
07-10-2018, 11:12 PM | #54 |
Can't post but one pic at a time ?
OLDIRONRACING |
07-10-2018, 11:14 PM | #55 |
Made my on pedal bracket using the factory holes.
OLDIRONRACING |
07-12-2018, 11:28 PM | #56 |
My motor sets to high in the front. I have the CPP motor stands with dirty dingo sliders. I'm at 6 degrees with a degree finder on the top of the intake. What s up? Are any one else haveing the same trouble? I used the original trans cross member.
OLDIRONRACING |
07-12-2018, 11:33 PM | #57 |
How do I make this a build thread or link? Rename it or move it?
OLDIRONRACING |
08-10-2018, 09:20 PM | #58 |
Did you figure out the problem?
01-02-2019, 12:04 AM | #59 |
Still have not found the fix to the exstream angle of motor. I can put a3/4 spacer under trans crossmember and get it to 5* but trans touches front of trans tunnel at pinch weld.
OLDIRONRACING Last edited by Oldironracing; 01-02-2019 at 12:14 AM. |
01-03-2019, 10:00 AM | #60 |
Can the motor come forward then on its mounts so the back of the trans can come up more?
01-03-2019, 10:05 AM | #61 |
Can't move forward,won't have room for air intake tube between motor and fans
OLDIRONRACING |
01-05-2019, 09:11 PM | #62 |
Ok up date on truck been a lot going on. Holley front drive installed air intake built brake lines made and run motor back in and now build a exhaust.
OLDIRONRACING |
01-05-2019, 09:12 PM | #63 |
How do u load more than one picture at a time?
OLDIRONRACING |
01-06-2019, 06:34 AM | #64 |
Whos top rad mount did you use ?
01-06-2019, 04:43 PM | #65 |
Made my own. Trying to post pictures.
OLDIRONRACING |
01-06-2019, 04:52 PM | #66 |
Got pic to upload finally. Added this two sence last post. White 70 is a driver and the blue is work in progress.
OLDIRONRACING |
01-06-2019, 04:53 PM | #67 |
Pic. Upload
OLDIRONRACING |
01-06-2019, 04:54 PM | #68 |
Pic
OLDIRONRACING |
01-06-2019, 04:55 PM | #69 |
Pic.
OLDIRONRACING |
01-06-2019, 05:01 PM | #70 |
Pic.
OLDIRONRACING |
01-07-2019, 12:38 AM | #71 |
I wouldn't measure the angle on the top of the motor. You need the angle at the trans tail shaft. Then you match that angle at the rear end pinion. 3 degrees down and 3 degrees up is good. Often you have to tweek it after all the weight is on the wheels. You can do that on the trans crossmember or angled shims on the spring perches. If you draw an imaginary line back from the trans output shaft, and another line forward from the rear pinion, the two lines should be parallel. Google image driveline angles and get some good explanation.
01-07-2019, 12:40 AM | #72 |
01-07-2019, 10:38 AM | #73 |
At the crank front pulley I have 4*now. Thank I'll be good for now.
OLDIRONRACING |
01-07-2019, 12:47 PM | #74 |
01-09-2019, 12:29 AM | #75 |
What r u guys doing for exhaust and what muffler?
OLDIRONRACING |
