01-05-2020, 11:28 PM | #51 |
Re: Mongos 81 c30
Manual clutch conversion or still hydro?
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
01-05-2020, 11:29 PM | #52 |
Post Whore
Re: Mongos 81 c30
manual...on the IH I used the same bellhousing setup but used a hyd slave onit
01-15-2020, 11:23 AM | #53 |
Re: Mongos 81 c30
Watching this build closely, looks great so far!
01-15-2020, 08:05 PM | #54 |
Post Whore
Re: Mongos 81 c30
well shifty....not much to watch..i built this truck over 10yrs ago...I will be pulling the bed off this summer to sandblast and repaint and redo the miserable bedliner job that's on it ...and also to fix the cab where some moron hit and run on me...it caved in the cab corner and the only way to fix it is remove the bed
thanks for looking though
01-26-2020, 01:17 AM | #55 |
Post Whore
Re: Mongos 81 c30
had someone ask about the toolbox in the bed...its actually a tool drawer with dual 100# drawer slides on it....
03-04-2020, 03:12 PM | #56 |
Post Whore
Re: Mongos 81 c30
Looking thru some old folders and finally found some pics of the C30 before I painted it..
03-04-2020, 03:17 PM | #57 |
Post Whore
Re: Mongos 81 c30
And some of the body work needed...
03-04-2020, 11:34 PM | #58 |
It followed me home?
Re: Mongos 81 c30
Damn I love this truck, are you tired of it and want to sell it cheap? haha
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
03-05-2020, 12:01 AM | #59 |
Post Whore
Re: Mongos 81 c30
Uuuhhhmmmmmmmm...nope...haha..
04-05-2020, 01:39 PM | #60 | |||
Re: Mongos 81 c30
Check out my build thread, first build on a squarebody in almost 10 years and was a pain since I needed to run a stock LS ac compressor. http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 Last edited by Ford Assassin; 04-05-2020 at 01:45 PM. |
04-07-2020, 11:37 PM | #61 |
Post Whore
Re: Mongos 81 c30
correct..the engine is bone stock except for headers and a dyno tune
11-18-2021, 09:00 AM | #62 |
Post Whore
Re: Mongos 81 c30
Did a little pulling upgrade to the C30..I added a under bed winch..
It's a superwinch 9000 that I had taking up space on the shop floor,so I put it to good use I used a 1/2" plate that bolts to the frame to mount the winch and fairlead to, and it was just right for fairlead to sit behind the tag So I cut out the tag plate, welded a hinge to it ,and used a couple of magnets to hold it closed The controls plug for the winch was broke, so while searching for a new plug, I found that I could use a wireless remote for the winch..bought a cheap one off Ebay and wired it in..best winch upgrade ever..!! I also went ahead and wired in a new plug for the remote..for those just in case moments.. Ran the power wires up the frame rails to the battery, where I added a disconnect switch so no power is at the winch until needed.. I recently put it to use when I loaded the IH travelall on the trailer..
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 11-18-2021 at 09:09 AM. |
11-18-2021, 09:26 AM | #63 |
Re: Mongos 81 c30
Great execution and addition!
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
11-18-2021, 05:21 PM | #64 |
Post Whore
Re: Mongos 81 c30
Thanks outlaw!!!...
I wanted to get this knocked outta the way before I pull the bed off next summer Still gotta fix the cab where I got hit and run on..and the bed has to come off to fix the cab dent.. and the bedliner that's on the bed is turning loose.. So the bed will get sandblasted,epoxy, and painted while its off..no more DIY roll-on bedliner
01-13-2022, 01:10 AM | #65 |
Post Whore
Re: Mongos 81 c30
and a pic of the C30 in action..this is in Grand Junction Co....1500+ miles from Ala...did over 3000 miles on this trip..truck ran flawless and avg just over 13mpgs round trip
01-13-2022, 01:16 AM | #66 | |
Re: Mongos 81 c30
As much as I loved the 6.0/LS/turbo NV4500 setup in my C30....the Cummins mpg is insane. Still haven't gotten used to the brick in the washing machine sound though. Lol
01-13-2022, 08:47 AM | #67 |
Re: Mongos 81 c30
That's not bad at all, especially pulling that aerodynamic binder!
01-13-2022, 12:06 PM | #68 |
Post Whore
Re: Mongos 81 c30
Yeah was really thinking diesel swap way back then, but then I started pricing engines, changed my mind quick...
And as far as pulling the "IH brick", most of the time I had to look in the mirrors so I'd know it was still back there, even when I went thru the cyclotyphoonado in Arkansas, the crosswinds had little effect.. But it did not like pulling Vail pass on i70...about 35mph is all I could get at those elevations going up some of those hills
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 06-02-2022 at 03:58 PM. |
01-13-2022, 12:15 PM | #69 | |
Re: Mongos 81 c30
07-27-2022, 04:03 PM | #70 |
Post Whore
Re: Mongos 81 c30
I decided to replace my 40+yr old shocks.. been awhile since I've bought shocks, WOW, they sure have got pricey.. went with bilstein 4600, the old orig shocks I pulled off had no rebound left
No time to drive it yet to see if it makes a difference, the rubber bushing in the old ones was deteriorated and I noticed I was having front wheel bounce issues.. I also noticed some nice flat spot cupping on the fronts, so I may have to get them trued up..
08-18-2022, 04:20 PM | #71 |
Post Whore
Re: Mongos 81 c30
just a update..
all i can say is WOW ,what a difference the new shocks made.. i took the truck for a 40mph drive across the hay field..very very smooth.. before your head would hit the cab roof doing about 15mph
08-18-2022, 05:15 PM | #72 |
Re: Mongos 81 c30
Strange what we can get used to!
