Old 10-18-2018, 07:43 AM   #51
talmadgemoss
talmadgemoss's Avatar
Re: 1955 2nd Series Build Start
Nut Case...Here are the wheels and tires information. I will pull those measurements tomorrow after work (Out of Town Today).
◦ 2 x Ridler 675 Wheel 17x9.5 Chrome 5x4.75 (5x120.65) -5mm Offset
(Please Enter Your Vehicle's Year, Make & Model: 55)
◦ 2 x Cooper Zeon Rs3 G1 Tire 225/50R17 Xl
◦ 2 x Cooper Zeon Rs3 G1 Tire 275/40R17 Sl
◦ 2 x Ridler 675 Wheel 17x7 Chrome 5x4.75 (5x120.65) 0mm Offset
talmadgemoss is offline   Reply With Quote
Old 10-22-2018, 05:00 PM   #52
talmadgemoss
Just a few quick shots of the progress. Radiator support and radiator installed with the transmission cooler. Got the fuel cell going in and started the wiring also. Lot's done, but lots more to go.
Old 11-01-2018, 01:30 PM   #53
talmadgemoss
Getting the wiring finished up and getting ready to start the plumbing next.
Old 11-12-2018, 03:40 PM   #54
talmadgemoss
Just some pictures of the progress lately. Getting some of the plumbing installed, fuel lines and transmission cooler lines. Also starting on the bed getting the tubs cut in.
Old 11-15-2018, 02:58 PM   #55
talmadgemoss
Test fitting the bed today for the tubs.
Old 11-15-2018, 03:52 PM   #56
dsraven
love that color, is it toyota blue from the tacoma? looks great with the chrome
Old 11-20-2018, 01:32 PM   #57
talmadgemoss
Not sure on the color it was painted this color when I purchased it.
Old 11-21-2018, 11:54 PM   #58
duramax55
color looks like bahama blue used in 1992 chevy trucks. On a side note do you know the length of your steering column??
duramax55 is offline   Reply With Quote
Old 11-23-2018, 05:16 PM   #59
talmadgemoss
Not sure of the length, but it's an IDIDIT column Part# 1140652020. It's a direct replacement.
Old 11-30-2018, 08:58 AM   #60
talmadgemoss
Getting the Tubs installed now. This is how we plan to install by bolting them to the wood in the bed. Ordered all the cables, accelerator, brake and light dimmer pedals should be in today. Ready to hear it fire up soon.
Old 12-03-2018, 09:20 PM   #61
agnes the dog
agnes the dog's Avatar
Your truck looks great! You've come a long way.
It appears that you have the same fuel tank that I have. I got mine from a local guy off craigslist. It was new, but he didn't remember the brand. I'm looking to re-do my filler neck. Do you recall where you got the tank or who made it? Mine comes really close to the bottom of the bed and I"m hoping the manufacturer has a recommended filler. Thanks.
Just because you can, doesn't necessarily mean you should.
1959 3100 stepside 355 + T5
agnes the dog is offline   Reply With Quote
Old 12-04-2018, 08:35 AM   #62
talmadgemoss
Thank you for the complement. The fuel cell came from Classic Parts and I purchased my filler neck from Tank Inc. They have some nice filler necks and caps. I'm using this one.
http://www.tanksinc.com/index.cfm/pa...rod/prd475.htm
Old 12-04-2018, 08:45 AM   #63
talmadgemoss
We got it fired up yesterday...Original heater core leaked...But all the gauges and tach worked good. Had 60# of oil pressure at idle. Trying to load the video but can't figure it out.
Old 12-04-2018, 12:12 PM   #64
agnes the dog
Thanks!
Old 12-04-2018, 04:11 PM   #65
dsraven
nice job on those tubs. looks like it came that way.
Old 12-05-2018, 11:55 AM   #66
talmadgemoss
Does anyone have any suggestion on exhaust? I'm think either turn down after the muffler before the rear end or exiting out before the rear tire? I'm looking to get with a shop later this week to see about routing. I have the rear mounted fuel cell as shown in the pictures. Thanks!
Old 12-05-2018, 12:44 PM   #67
MNchevy
Cool idea on the tubs. S-10?
MNchevy is offline   Reply With Quote
Old 12-05-2018, 01:10 PM   #68
talmadgemoss
Actually inner fenders of a ford ranger.
Old 12-05-2018, 03:51 PM   #69
dsraven
exhaust is kinda tough, room wise, but better out the back for keeping things looking nice, paint etc. oxides of nitrogen in the exhaust tend to accel the oxidation of any bare metal from rock chips etc. heat tends to warm up diff housings. never been a fan of out the side or turned down under the unit but, out the side maybe better if not out the back. just my thoughts though. out the side tends to put a coating on things like wheels and fenders.
Old 12-05-2018, 07:48 PM   #70
Scottish58chev
Just a thought but my plan is to run them to the outside then over the axle and back, my bump stops are under the chassis so i may have more room than you and not sure on your ground clearance either, like i say, just a thought.
Scottish58chev is offline   Reply With Quote
Old 12-12-2018, 09:46 AM   #71
talmadgemoss
We are mocking up the front clip and everything is looking like it will work. Got the new Lokar accelerator pedal in and cable getting it hooked up. Hopefully get the truck out to the muffler shop by the end of the week.
Old 12-17-2018, 09:08 AM   #72
talmadgemoss
Able to get the Truck to the Muffler shop for the exhaust Friday. Had enough room to route it behind the tires. I have some tips, but need to get the tubs in a bed back on before installing them. Going to re-route some of the braided cables for the brake lines now that the exhaust is in.
Old 01-02-2019, 09:12 AM   #73
talmadgemoss
Starting to get the truck back together now. The lights are working, turn signals and the interior lights now working. Finishing up the tubs this week for the bed, installing the horn then installing the new chrome grill, bumpers and head light bezels. Hopefully getting it to the alignment shop in the next couple weeks'. Been driving it around the block everything seems to be work good right now.
Old 01-02-2019, 01:29 PM   #74
bluetrim
Looking good!!
bluetrim is offline   Reply With Quote
Old 01-02-2019, 02:15 PM   #75
dsraven
with the braided brake lines you may need some heat shields since the braided lines usually have teflon liners and they may not like the exhaust so much.
looking good
