Old 08-29-2019, 07:30 PM   #51
clay68c10
clay68c10's Avatar
Re: 1968 GMC - Ol' Blue
That color catches my eye every time I see one of those Yotas. It is going to look great.
How were the door skins quality-wise? The doors look good in your pics.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 08-30-2019, 09:16 AM   #52
MDPotter
MDPotter's Avatar
The skins were pretty good. Where the inner and outer are welded together inside the door, I had to rebend that tab to line up better but that was easy. What I should have looked at before test fitting the door was the lower front corner - I should have hammered the edges over with a little more inward force. The corners stuck out a little bit and hit the rocker at the front edge when you open the door. I had to grind the first couple inches and reweld it to get the gap right. But the skins fit the contour of the inner structure well and they seem to have good EDP on them so I'm happy with them.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 08-30-2019, 09:19 AM   #53
MDPotter
MDPotter's Avatar
I spent a couple hours last night just laying mud, probably 15 batches. I have my work cut out for me. Clean Sheets are awesome for mixing filler, I just wish I didn't have to clean the spreader off every time.
Old 08-30-2019, 10:06 AM   #54
cornerstone
cornerstone's Avatar
I bought a decent amount of cheapie spreaders so I could keep the work going, then clean them up later.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 08-30-2019, 10:57 AM   #55
MDPotter
MDPotter's Avatar
Does it chip off pretty easy after it's set up for a couple hours?
Old 08-30-2019, 11:22 AM   #56
TA_C10
TA_C10's Avatar
I found it super easy to clean them off with a rough cotton rag and some thinner/pre-prep spray. And if you wait like 2 minutes after your done, it's not brick hard, and its not sloppy still either, take another scraper and just knock it right off, then use the thinner for excess. Takes like 5 seconds the whole process.
If you wait too long and its brick hard, it's not that easy to clean off, but it's still not bad. The material those scrapers are made of the mud doesn't soak in so they are to clean.
And yeah, good progress there man, you will be sanding and sanding, then more mud, then more sanding. We will see you in a month lol.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 08-30-2019, 01:35 PM   #57
MDPotter
MDPotter's Avatar
Haha I'll be pretty frustrated if I'm still sanding on this cab in a month. Famous last words!
Old 08-30-2019, 11:37 PM   #58
cornerstone
I found that the areas that had more than a 1/16th of filler would break off with a quick twist of the spreader, but if it was less than that it was more of a chore.
I bought a pack of 3 different size stainless steel spreaders with plastic handles, and I like them better than the plastic. For one, they are more rigid which I found made it easier to lay down a thin uniform skim coat and also because they clean up real fast by pressing them against my bench grinder with a 7' wire wheel, and don't get damaged in the process.
Brian
Old 09-04-2019, 10:17 AM   #59
MDPotter
MDPotter's Avatar
This is what 5 hours of sanding looks like. I've got almost all of my first round of filler sanded down. I got sick of sanding the other day and decided to work on brake lines for a bit and then got stumped so I'm stalled on that too.
It's a little harder to find time to work on it nowadays with my fiancee taking classes and a new puppy at home, but we're figuring it out. My dreams of having the cab, doors, and fenders painted before winter aren't realistic anymore so I'm just working to get the cab painted. Sometimes life gets in the way of our hobbies and that's okay. I'll just be happy when the cab is done as it is by far the biggest chunk of bodywork.
Old 09-04-2019, 11:12 AM   #60
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Hang in there. It's hard to stay motivated through sanding. I too was hoping for paint, but opted to just leave it in primer for the remaining 80 percent of the build. Once I can actually start, put in gear, and role in either direction I will then take it apart and block and paint. I'm tired of sanding
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 09-04-2019, 01:29 PM   #61
TA_C10
TA_C10's Avatar
Yeah I agree, hang in there man. Looking good. And I like that 64 in the background. Are you daily driving that?
"It's only money".
Old 09-04-2019, 01:34 PM   #62
MDPotter
MDPotter's Avatar
Thanks guys. I'm starting to see the light on the filler. Now that most of that first application is blocked down, things are close so the 2nd and 3rd coats should be less.
The 64 is my dad's, we finished it last winter and he does daily drive it. I drove it for a couple days this weekend and it's fun. Even though the AC isn't working right now and it's loud compared to my 2016, it's a good kind of loud because you can hear the engine and really be in tune with the truck. There's something about cruising down the road in this vintage of truck that can't be beat.
Old 09-11-2019, 09:54 AM   #63
JUN1269
Seeing your build has given me a boost of motivation on mine. Keep pressing forward, it's looking really good.
JUN1269 is offline   Reply With Quote
Old 09-11-2019, 10:12 AM   #64
MDPotter
MDPotter's Avatar
Thanks JUN, I'm glad it could help motivate you. I was sanding on it last night and am getting close to being done with the filler work. I'm working on it as much as I can so I can get it painted this month.
Old 09-16-2019, 09:18 AM   #65
MDPotter
MDPotter's Avatar
Not great pictures, but just a quick update. I've been sanding on the cab every chance I get and I think I'm finally done with filler. I'm taking tomorrow off so I can finish prepping the cab, doors, and fenders fo a coat of epoxy so that I can shoot some high build on Thursday and block sand on Saturday. I'm on a mission to have these parts turned blue by the end of the month.
Old 09-16-2019, 09:23 AM   #66
1971Stepside
Almost Satisfied
Looks great! I thought I was about 90 percent there until I shot another coat of primer...so many spots to still fill and clean up. I can't wait for paint, but I still have so many things to test fit etc. I need to hold off. Can't wait to see her in blue.
Old 09-16-2019, 10:28 AM   #67
MDPotter
MDPotter's Avatar
I hear ya man. I could spend probably another 5 days on the back of the cab and the firewall, but the return for spending that time to get a flawless surface in those areas wasn't worth it to me. I was watching a video on YouTube last night by United by Trucks and his truck "Teddy" is a patina GMC and it's so cool. No body work, just nice mods and driving. Made me second guess all this work I'm doing, so I'm hoping it pays off.
Old 09-18-2019, 10:05 AM   #68
MDPotter
MDPotter's Avatar
Well my day off yesterday was successful, I got everything done that I wanted to. Theoretically, filler work on the cab, doors, fenders, and cowl should be done now. I sprayed a coat of epoxy on everything in preparation for high build primer tomorrow so I can move on. I'm worried about the sand scratches that I can see through the epoxy though. On the plus side, the seam sealer came out well.
Old 09-18-2019, 10:07 AM   #69
MDPotter
MDPotter's Avatar
Old 09-18-2019, 11:02 AM   #70
TA_C10
TA_C10's Avatar
Self leveling seam sealer gives me the warm and fuzzy's You know it just seeps into cracks that traditional seam sealers couldn't do. Looks great man!
"It's only money".
Old 09-18-2019, 11:08 AM   #71
MDPotter
MDPotter's Avatar
It is kind of enjoyable to apply and see. I used a single component at the vertical sections and that created a dam to keep the self leveling from running down too much. It did run all the way down the passenger side and kept creeping out the bottom, but I think it stopped after I put epoxy down.
Old 09-19-2019, 10:39 AM   #72
Camaroguy
Camaroguy's Avatar
I finally got a chance to check out your project. It's looking good for sure and I am excited to see the blue on it. You planning to two-tone it or stick with the single color?
Kudos for having the guts to tackle the harness.
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD)
Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712
Camaroguy is offline   Reply With Quote
Old 09-19-2019, 10:54 AM   #73
MDPotter
MDPotter's Avatar
It'll be solid blue. I'm just hoping it starts and runs and I will honestly be a little surprised if it does, considering that I touched every single wire on the harness and had every single pin removed and repinned from the PCM connectors at one point. Almost every wire was either lengthened or shortened too. This was back when I had freetime in the evenings to tinker with such a task. But if it becomes a total failure, I can always buy one from BP or PSI.
Old 09-20-2019, 09:26 AM   #74
MDPotter
MDPotter's Avatar
I wasn't happy with the way the panels looked after I shot one coat of epoxy on them so after getting some advice from the guys on the SPI forum, I sprayed two more coats of epoxy and everything looks great now. More of the scratches are filled and there is no more mapping of the filler. I can't recommend SPI enough, their products are great, pricing is very reasonable, and they have unmatched technical support. I was afraid of epoxy after using it once because I didn't know how to spray it without getting craters, but I don't get so much anymore. What's great about this epoxy is that it has a 7 day recoat window, meaning you can apply filler or more epoxy over it within 7 days of spraying without having to sand first.
I'm actually a little surprised at how straight everything looks and don't think I'll do any blocking. I just need to take care of some cratering and scratches and should be able to seal and base/clear next weekend!
Old 09-20-2019, 12:36 PM   #75
1971Stepside
Almost Satisfied
Looks great! Come and finish mine
