Old 01-29-2020, 04:21 PM   #51
dsraven
Re: my '59 short bed build
you could make the shackle into an H with a piece of stout flat bar welded in on it's flat just above the spring. then remove the center bolt and plug the holes with weld for added strength. if you do this off the truck make sure to leave some extra width and then use shims on each side of the spring and frame mount bushings in order to be able to remove the shackle easily. otherwise it could be pretty tight getting installed/removed
Old 01-29-2020, 10:25 PM   #52
Clarance J
Clarance J's Avatar
Hello 1-ton of fun. I have been following your build and like the direction its going. The reason I'm posting here is about your mounting of your steering box. I used the same kit and box and have no problems with it. Now when I was looking at the mounting to frame I found several comments about frame flexing and cracks showing up. I used the information and instructions I found by CCP, Brothers etc. I located my box closer to the cross member as instructed and maybe the little 1/2 spacers in the kit might have been enough but I did not like them. I put backup material inside frame with solid 1/2" x 1" solid bar outside frame between box. My truck is only 2 wheel drive. With your box mounted 3" forward its closer to the end of the frame with those big tires I'm sure there will be more flexing going on. Just a thought. Keep up the good work.
Earl
You have to have patiences or you'll be one.
Clarance J is offline   Reply With Quote
Old 02-03-2020, 02:09 PM   #53
1-ton of fun
polishing a turd
1-ton of fun's Avatar
Earl
Earl, thanks for the info! i much prefer your 1/2" bar spacers vs the little round spacers....also thanks for the tip for the plating on the inside of the frame. i think i'll do something similar there too!
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 02-10-2020, 03:32 PM   #54
1-ton of fun
polishing a turd
still having steering clearance issues... so now i'm thinking about instead of changing tires to a 35x10.50, i'm going to try this y-link kit for the drag link: https://www.ballisticfabrication.com...nt=27222290311
if that works, i may be able to switch back to the alloy wheel from the steel one to tuck the tires back under the fenders better (the alloys have 1.25" more offset)
Old 02-12-2020, 01:45 AM   #55
1-ton of fun
polishing a turd
That was a dead end, leaf spring in the way. Looks like I’m going to a high steer setup...parts ordered, now to wait on deliveries. I now have about $400 worth of k10 steering stuff that I can’t use.
This week i’ll begin to go through the front axle to replace ball joints, seals, axle u-joints, bearings, rotors/hubs, and hub locks.
Old 02-16-2020, 09:06 AM   #56
1-ton of fun
polishing a turd
Tore down the Dana 44, and threw some paint on the housing. Cross over high steering looks like it might work, the sway bar and drag link will be close to each other, but I think it will clear...just need to order a section of threaded DOM tubing for the drag link to see for sure...
Old 02-29-2020, 04:48 PM   #57
1-ton of fun
polishing a turd
front end almost done...new brakes came in
Old 05-26-2020, 11:45 AM   #58
Kula57
looking good
I'm thinking of going 4x4 also, what type of steering box are you using for the cross steering setup.
thanks
Kula57 is offline   Reply With Quote
Old 06-25-2020, 12:59 PM   #59
1-ton of fun
polishing a turd
Originally Posted by Kula57 View Post
looking good
thanks
c10 2wd box
Old 06-25-2020, 01:14 PM   #60
1-ton of fun
polishing a turd
got the rear brakes done. little shop mfg disc kit with parking brake
Old 06-25-2020, 01:20 PM   #61
1-ton of fun
polishing a turd
also made some shock mounts and mounted the 14" travel fox 2.0 shocks on the front.
Old 06-25-2020, 06:39 PM   #62
Kula57
Thanks for the response, keep posting updates looks great. I have a 85 k10 donor which I just pulled the 700r4 and np 208. Can't wait to see how your cross steering comes together. I also think I may go with the forward shackle mount for the rear along with the shackle flip.
great job
Old 06-26-2020, 11:43 AM   #63
1-ton of fun
polishing a turd
great job
I just grabbed a 700r4 and np208 setup for this truck...saving the np205 for another build.
Old 08-19-2020, 08:13 PM   #64
Kula57
Hey 1 ton hope things are well with you.
wondering if you have any new pics like from the front end, steering, and how the rear suspension is going? supper curious as i'm pulling apart the 85 k10 for my build
thanks
Old 08-20-2020, 11:48 AM   #65
1-ton of fun
polishing a turd
thanks
rear is almost done, going to weld on the shock mounts today, and add a torque arm to help with spring wrap
the steering is almost there. i need to weld the box mount on the frame, and i think i'm going to plate the frame to add some strength.
Old 08-20-2020, 03:03 PM   #66
Kula57
Thanks for the pics. Did you move the steering box or is it in the same position you had it previously?
By the way, the motor in my 85 donor ended up being a 400 not a 305 so I might use. I looked up the casting code.donor has a tilt column so i'm taking that also.
great job, the more pics the better
aloha
Old 08-20-2020, 06:50 PM   #67
1-ton of fun
polishing a turd
aloha
I have not moved it from where I put it in once I switched to the crossover steering, which is not quite as far forward as when using the stock steering set up with the c10 box kits
Old 08-20-2020, 06:52 PM   #68
1-ton of fun
polishing a turd
Also I welded on the shock mounts to the axle today.
Old 08-24-2020, 09:19 PM   #69
Kula57
Nice! I like that you were able to use the stock upper shock mounts. What are the shock mounts from that are on the rear axle?
Also, I know you got 4" lift front springs for a jeep. And I believe it was a 4" shackle flip for the rear. Did this combo come out even or is one side higher than the other.
thanks
Old 08-25-2020, 10:31 AM   #70
1-ton of fun
polishing a turd
thanks
they are just some fabricated universal shock mounts, can't remember where i got them from exactly.
the frame is level when sitting on the suspension side to side.
front to back not sure yet, seems pretty close to level.
the rear suspension is the front leaf hangers from the 86 k10 which hang lower than the '59 ones did which adds some lift, the the rear shackle flip (~4" lift) and 2.5" lift leaf springs. the rear can go up an inch on the shackle if needed. i feel like its more like 8-9" of lift overall in the rear.
the front is 4" jeep springs, and you get another about 4" when going from the stock drop axle to the straight live axle, plus i put shackles in that are a couple inches longer too. i haven't figured out how to get a sway bar to mount in there yet though...
was going to get tires this week, so i can set if down off the jack stands, but looks like we have a hurricane incoming now...
Old 08-25-2020, 10:56 AM   #71
1-ton of fun
polishing a turd
i managed to get the 700r4 and transfer case in, so i can fab the crossmember to hold it in...
Old 08-25-2020, 12:25 PM   #72
Kula57
Thanks for the photo's and info. take care out there hope storm passes by. can't wait those the new tires mounted.
Old 08-29-2020, 03:06 PM   #73
1-ton of fun
polishing a turd
Got the trans and transfer case mocked up with the crossmember I built off of one from a ford van that I had lying around. Going to have to redo one side of the crossmember extension to bring it in about 0.25” to meet the frame. Otherwise, I think it fits good. Almost ready to order driveshafts...
Old 08-30-2020, 01:29 PM   #74
1-ton of fun
polishing a turd
Crossmember made. Going to clean it up and paint it today.
Old 08-30-2020, 04:41 PM   #75
Kula57
Looks like you have quite a bit of room under there, I have the frame mounted master so not sure how that will work. but keep it up and keep the pics coming also.
thanks
