Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-06-2021, 10:23 PM   #51
PGSigns
PGSigns's Avatar
Re: Pole Frame Garage
Your average is not real good. Something we learned doing mine gloves always when doing metal. Hopefully yall get through the rest with no more injuries.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-08-2021, 07:10 AM   #52
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Dang! Sorry to hear of you and your friend's injuries! That metal is stupid sharp! The insulation looks great though! Isn't it nice to be able to put stuff in it now? It's a double edged sword at this point. You're so close to the end but it feels like so far away from getting in and working on projects in it.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-10-2021, 08:36 PM   #53
rharris
rharris's Avatar
I am going to try to keep it somewhat empty until i am done working on it. We had a productive day today. We got 27 pieces of ceiling liner up. We had 2 guys on separate scaffoldings and 3 guys on the ground. There are 3 stacks of 13 panels that we predrilled - i wanted straight screws. We started in the opposite end corner of the man door so when you come in the man door you can't see the overlaps. The doors are getting installed on the 18th, so i have to have the ceiling completed.
72 Cheyenne Super C10 SWB
2001 Silverado 1500HD Crew
2011 Silverado 2500HD Crew Duramax (Hers)
rharris is offline   Reply With Quote
Old 01-11-2021, 09:44 PM   #54
PGSigns
PGSigns's Avatar
Great progress. Looks good.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 01-15-2021, 12:23 PM   #55
Dieselwrencher
That looks really nice!
Ryan
Old 01-15-2021, 10:20 PM   #56
rharris
rharris's Avatar
The overhead door installers do not want ribbed metal up to the edge of the door frames due to his track and opener brackets. Most times you see the door 2x6 is exposed or painted. Since the entire inside of my building will have metal panels i didn't want the wood exposed. I had the Amish store bend some pieces to accommodate. I think it turned out really well. Ribbed panels and J-channel will go between the doors. I'm also happy with the soffit lights. I knew they would not give off much useable light, but i think they look great. I'm thinking about hanging hubcaps where the light hits the clay above the doors.
Old 01-18-2021, 08:43 PM   #57
PGSigns
PGSigns's Avatar
Coming along nicely.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 01-18-2021, 10:05 PM   #58
rharris
rharris's Avatar
Doors are in
Old 01-21-2021, 09:38 PM   #59
PGSigns
PGSigns's Avatar
Doors look nice on it. Almost time to start filling it up.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 01-22-2021, 10:43 AM   #60
racecougar
racecougar's Avatar
Originally Posted by rharris View Post
struggling with the ceiling insulation. If i blow in, i will need to block off the eves to keep the insulation from going down the walls and out the soffit vent. They make rafter mates, but they are for 24" OC. I have 48". Putting two together don't work so nice. The rafter mate keeps a channel of vented air from the soffit vent up to the ridge vent and allows a spot for the blown to rest against. Thoughts?
I know I'm way late to this party, but when I built my shop, I utilized 10mil plastic sheeting to create my own insulation baffles. I also installed sheeting to create a vapor barrier above the ceiling sheetmetal. Since I work alone, I used a drywall hoist to get each panel up near the ceiling, slid it onto two deadmen made out of 2x4 off-fall, then attached it to the trusses. I ended up blowing in about R-55 of fiberglass in the ceiling (I bought more insulation than I really needed, and I wasn't going to take it back). With R-19 batts in the walls, and the building sealed up as tight as it is, heating and cooling my 30'x60'x12-1/2' building takes next to nothing. I've been enjoying the building for a great couple of years now.
Good looking build you've got going on!
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 02-12-2021, 05:40 PM   #61
rharris
rharris's Avatar
The heater is in. It heats up quick, 38 - 62 degrees on initial fire up in about 45 minutes. It does use more fuel than i expected. In two weeks it has used over 30 gallons if my calculations and gage is correct. I keep it around 45-48 and had it kicked up to 55 two or three times for about 12 hours each time. I was hoping to go all season on one fill - that certainly isn't going to happen if I keep the heat on. I used an infrared gun during a 20 degree day on the building, inside and out, and i don't see any heat loss/transfer in the walls or roof line. It was about 2 degrees cooler above the metal ceiling, so the metal is doing a little to restrict heat to the attic, but not much as expected. The doors are insulated well at R17, but you can see from the pictures that there is loss there. There was about an 8 degree increase around the seals and in between panels.
Old 02-12-2021, 05:43 PM   #62
rharris
rharris's Avatar
Lights are in 2 of the 4 bays and I am happy with the looks and the lighting. It gives off enough light, without shadowing. It's easy on the eyes with the frosted cover. The open LED style really mess with my eyes and head and these were a good choice in avoiding it.
Old 02-18-2021, 09:43 PM   #63
PGSigns
PGSigns's Avatar
Looking good.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-01-2021, 10:57 PM   #64
rharris
rharris's Avatar
All the lights are in and the electric is roughed in the walls. The wall liner is all up except for the area where the bathroom will be. I still need to frame that out. I'm very happy with the fascia on the front wall under the overhead door tracks and springs. One sheet of ribbed metal would have fit between the doors, but I had to half two sheets where the openers are so it would flex enough to go under the opener.
Old 03-01-2021, 11:02 PM   #65
rharris
rharris's Avatar
update on the heater - I used 65 gallons in 4 weeks. I would maintain 40 when i wasn't out there and then raise it to 50 sometimes when I was working on it.
Old 03-02-2021, 08:20 PM   #66
PGSigns
PGSigns's Avatar
Getting close to being done. You have done a nice job on the shop.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-17-2021, 07:10 PM   #67
rharris
rharris's Avatar
Working in the small garage is getting old. Time to move the C10 and the A into their new home and get the new garage done. I have to finish framing out the bathroom and a few pieces of wall liner and then i'll be completely ready to move in. We plumbed for a shower just because it was cheap to do so prior to pouring the concrete, not thinking i would ever need it. But as we were framing the bathroom my buddy mentioned that we are not getting a 36" shower through the bathroom door and we needed to get in in before finishing the framing. So i bought the shower and it will be in place. I'm sure the kids will use it. My little guy takes paper and markers out and draws in the garage, even when no one is in there. Glad to see that.
Old 03-18-2021, 06:59 AM   #68
PGSigns
PGSigns's Avatar
Good to see you are about ready yo put the new shop to work.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-25-2021, 05:26 AM   #69
Dieselwrencher
You're getting so close now! It looks awesome! How many BTU's is you heater? It looks kind of small for that large space IMO. Maybe it's running all the time to maintain? Mine is on NG and I usually don't leave mine on all the time. I haven't tracked my usage so maybe I'd be surprised.
Ryan
Old 03-26-2021, 06:44 AM   #70
rharris
rharris's Avatar
Heater is 125k btu. It doesn't run that often. I timed it at 6 minute run cycles once every hour if i maintain 60. It beats being cold. Maybe once i get fully moved in i can do a better assessment on the heat.
Considering using epoxy on the floor. I have never used it before, and i worry about it peeling in the future.
Old 03-26-2021, 07:14 AM   #71
Richard2112
Richard2112's Avatar
That is a damn nice aircraft hanger Joking aside, really cool project, came out very well. Looks great.
Richard2112 is offline   Reply With Quote
Old 04-02-2021, 09:17 AM   #72
Dieselwrencher
Epoxy has +'s and -'s. I personally think it's worth doing but you really need to do it before you get moved in and working in it or it's a PITA to do later. Just don't go with a smooth coating or it'll be stupid slick.
Ryan
Old 04-03-2021, 09:17 PM   #73
pwdcougar
pwdcougar's Avatar
Wow looks great!
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 04-08-2021, 08:34 AM   #74
MalibuSSwagon
I am jealous my 24x40 is getting small next place I'm building something like this.
MalibuSSwagon is offline   Reply With Quote
Old 04-11-2021, 10:17 AM   #75
rharris
rharris's Avatar
Thanks guys, I’m happy with it.
Decision time on 2 or 4 post lift. I’d like a 4 post, but after you buy the jacks for wheel work it adds up to about twice the money as a 2 post.
