01-16-2022, 12:39 PM | #51 |
Re: The Wrong Bed C10 build
I have every intention of posting numbers both of the engine and at the rear wheels. The engineers at work have to find time to squeeze it in between r&d engines to run personal projects. Once its run and the truck is back together Ill squeeze it in on the chassis dyno schedule between R&D and Beta cars. Its a great perk of my day job but I have to be at their mercy for convenience. FYI Im basing my prediction on previous builds and our programs at work and until done is a hypothetical.
01-16-2022, 12:44 PM | #52 |
Tied up a bunch of lose ends yesterday before turning the truck around today and starting on the rear. Most notably was the body mounts as they were original! Also got the 1/2 fuel system 100% done and added some hush mat between the tank and the cab.
01-17-2022, 02:03 PM | #53 |
Got the ol' wrong bed out of the shop in spun around in the drive way to back it in.(FYI don't try to do this on black ice.) But now its pushed back in and time to start on the rear drop tonight.
01-17-2022, 10:46 PM | #54 |
Not a major night tonight took it off to get the latest round of salt off my dually before this weeks cold snap. I did get to put my old 1964 Ajax high lift to use as a way of stabilizing the truck on the stands.
01-17-2022, 11:34 PM | #55 |
Dang i wish i had one of those jack thingys lol would have saved me banging my head 3 different times in the last week.
01-18-2022, 11:59 PM | #56 |
Got the rear end taken out tonight and still have to deal with some seized hardware.
01-19-2022, 12:20 PM | #57 |
Love the look of your truck. I am curious, what size tire do you have on the rear. It looks very beefy.
01-19-2022, 01:43 PM | #58 |
01-20-2022, 01:50 PM | #59 |
After a night of slogging through rusted hardware finally got almost the old parts off and broken down. I still have one more trailing arm mount to remove. (as you all know the rivets suck) Still have to figure out if I'm going to just flip the brackets or get the adjustable ones.
01-25-2022, 03:46 AM | #60 |
Progress!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
01-26-2022, 02:11 PM | #61 |
So no post for a short bit because I went like a mad man and banged out the rear half of the truck last weekend. Stripped and painted the frame and rear rails and redid the arms and rearend. Flipped the front mounts new hardware and polyurethane and air shocks it should ride pretty good. I welded on the new panhard mt and still waiting on my finned diff cover and shorter bar. But I settled at a 4" drop in the back and with it, it'll maintain its hot rod 60/70s rake and stance. Still got some lose ends to tie up like fabbing a new hitch but its coming together.
01-26-2022, 02:12 PM | #62 |
some more
01-26-2022, 02:13 PM | #63 |
last group and those are 33x12.5 -15
01-28-2022, 02:11 PM | #64 |
New diff-cover showed up so I gave it a mag finish to finish off the rear-end just waiting on the right length panhard bar now plumbing the axle tonight.
01-30-2022, 12:36 AM | #65 |
Rear chassis is 100% done took the opportunity with the good weather to roll the truck outside and view the new stance. Hopefully I can get a shot at the company dyno in the next couple of weeks so the motor can go in. In the meantime Ill tie up some stuff starting with Fabing up a new hitch
01-30-2022, 12:50 AM | #66 |
A couple more
02-05-2022, 04:40 PM | #67 |
After being sick for a bit. Fabd up a new low profile hitch for so I can drag around some of my race cars.
02-06-2022, 03:50 PM | #68 |
BlahBlahBlah
What did you used to put the magnesium finish on the rear diff cover? It looks great.
02-06-2022, 03:58 PM | #69 |
02-18-2022, 02:40 PM | #70 |
Squeezed the engine onto the work dyno after hours. Little 355 made 469 hp @6700 and 413 ft lbs @ 5200 . Got it home and wasted no time dropping it in the truck. Waiting on the clutch to show up this weekend and hopefully getting it all buttoned up in the next few days. made a lunch time run to LMC for peddles and some other lose end(great to work around the corner. Pics are from before and after dyno (didn't want to be that guy in front of the other guys from work) but supper happy with the progression.
02-18-2022, 02:45 PM | #71 |
A few more.
02-22-2022, 06:44 PM | #72 |
Got the hood back on and picked up the remaining mandrel tubes at work to fab the exhaust. It was nice to be able to get the truck outside in to the world and step back I adjusted the rear down 2" after the photos. The dogs are excited for spring!
02-22-2022, 06:54 PM | #73 |
A before and after of the drop to show the 4.5/4 inch stance
02-22-2022, 07:53 PM | #74 |
Lookin slick!
02-22-2022, 08:07 PM | #75 |
Truck looks GREAT!
That stance is perfect ; )
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
