Old 07-16-2022, 08:26 AM   #51
Gregski
Post Whore
Gregski's Avatar
Re: Did the 1/2 ton short beds come with a two piece driveshaft?
I don't mean to brag but I just picked up my 5th wrong drive shaft today, lol
this one actually had a '69 tag on it, and my chassis is technically a '69 (the truck is registered as a '71 but let's not split hairs, ha ha) I realize this one comes from a 3/4 ton truck aka a C20 however that just means the shaft would be beefier if you will that should not constitute a different length per say, if you follow my logic two trucks parked side by side, for example a long bed C10 and a long bed C20 would be the same length, no? assuming both had GM 12 bolt butts
this is soooo Goldilocks: this one's too short, this one's too long...
Gregski is offline   Reply With Quote
Old 07-16-2022, 08:29 AM   #52
Gregski
Post Whore
Gregski's Avatar
I used the Greg-O-matic drive shaft spreadarizer 3000 to divide it in two just for funnsies, mucking up the fine threads in the process
Sketch Level: solid 9
Old 07-16-2022, 08:32 AM   #53
Gregski
Post Whore
Gregski's Avatar
I also media blasted the yet another variety center support donut mounting bracket plate just for show and tell [and cause I finally got my media master blaster setup where I can see inside it, hee hee, so I am media blastin' everything in sight]
not sure if this is stock or not, maybe one of youz can verify it please [we're looking at you Mr. Keith, ha ha]
Old 07-16-2022, 11:56 AM   #54
Keith Seymore
Keith Seymore's Avatar
Yeah - I think that's stock (?).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-16-2022, 11:57 AM   #55
Keith Seymore
One of my buddies at the race track had a T shirt that said:
"That's sketchy even by my standards".
I'll have to see if I can get a picture of it.
K
1979-1986
1986 - 2019
Old 07-16-2022, 01:22 PM   #56
Jason Banks
Jason Banks's Avatar
Gregski. I have a 1968 Longbed 307 4-Speed truck that came with that style bracket. I was going to post a picture of it in this thread earlier, but looked through my pictures and couldn't find a good one of it installed.
Jason Banks is offline   Reply With Quote
Old 07-16-2022, 03:57 PM   #57
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
The problem with your logic is a C20 would not have come from the factory with a 12 bolt. It would have had an Eaton or a Dana
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 07-16-2022, 04:26 PM   #58
Accelo
Accelo's Avatar
Here is a picture and length of the rear half of the 2 piece drive shaft off my short box. I cut down the front so I do not have the original length to share.
Accelo is offline   Reply With Quote
Old 07-16-2022, 11:08 PM   #59
Gregski
Post Whore
Gregski's Avatar
so after all that 5th time was indeed the charm, with the help of a buddy we figured out how to mount this bracket, it actually mounts on the transmission side of the trailing arm cross member, I literally had to drill the two holes through the dirt and grime cause they were totally and completely clogged
Old 07-16-2022, 11:15 PM   #60
Gregski
Post Whore
Gregski's Avatar
ah, thank you
Old 07-16-2022, 11:16 PM   #61
Gregski
Post Whore
Gregski's Avatar
thank you so much could you post a pic of your center support donut and bracket, a friend of mine and I have a theory of what the 1/2 tons should look like, compared to the 3/4 ton style
