Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 05-30-2017, 11:43 PM   #726
Captainfab
60-66 Nut
Re: Power Steering Adapter Plates
The power steering pitman arm will bolt up to a '63-'70 draglink. I do not know about any earlier years.
Originally Posted by OldChevy61 View Post
Capt. Will I have to do anything to the centerlink to use this system? Or just the plate, gearbox and pitman arm.
Old 06-13-2017, 07:21 PM   #727
UTSA
UTSA's Avatar
Originally Posted by Captainfab View Post
Here are a couple more pics of the tube and flange that many are not aware of. This is a simple way to connect the original steering column shaft to the rag joint if you do not have a drill press and a welder to make use of the original flange as shown in the installation instructions. The cost of this tube and flange assembly is $25.00
captainFab,
is it just me or does that tube and flange seem to be smaller and not fit over my existing steering column? or was i supposed to receive a different tube and flange?
1965 C10 350 combo
UTSA is offline   Reply With Quote
Old 06-13-2017, 10:56 PM   #728
Captainfab
60-66 Nut
I currently make only one tube and flange. If the one you received from me does not fit the steering column shaft, you do not have an original '63-'66 steering column. If you post a pic, I can may be able to tell you what steering column you have.
Originally Posted by UTSA View Post
captainFab,
Old 07-07-2017, 07:44 AM   #729
kchampagne
kchampagne's Avatar
Hey Captain. I would like to purchase another PS adapter plate for a 65. If they are available, please send me your payment info. Thank you much!
kchampagne is offline   Reply With Quote
Old 07-07-2017, 11:28 PM   #730
Captainfab
60-66 Nut
I will send you a PM with purchasing info.
Old 07-31-2017, 01:55 AM   #731
cwumed
Captain, is like to purchase a bracket from you. Thank you sir, Matt
cwumed is offline   Reply With Quote
Old 07-31-2017, 04:51 PM   #732
66 C-10 fleet
Would you please send ordering info for the adaptor plates for a 66 chevy please.
66 C-10 fleet is offline   Reply With Quote
Old 07-31-2017, 10:32 PM   #733
Captainfab
60-66 Nut
I will send you both PM's with purchasing info.
Old 08-05-2017, 12:50 PM   #734
bosephus
bosephus's Avatar
Order info for 60-62 power steering adapter and axle saddles please. Thanks,Bo
bosephus is offline   Reply With Quote
Old 08-05-2017, 11:31 PM   #735
Captainfab
60-66 Nut
I will send you a PM.........
Old 08-09-2017, 06:47 PM   #736
RussC10
I just sent you an email requesting pricing for the power steering adapter and the column tube for my 66.
RussC10 is offline   Reply With Quote
Old 08-09-2017, 11:05 PM   #737
Captainfab
60-66 Nut
I replied to your email earlier.
Old 08-10-2017, 10:04 AM   #738
RussC10
Just sent you $$$$$ via paypal.
Thanks.
Old 08-10-2017, 11:33 PM   #739
Captainfab
60-66 Nut
Payment received.
Thanks.
Old 09-15-2017, 03:37 AM   #740
Homebuilt Hotrods
Homebuilt Hotrods's Avatar
could use a PS adapter myself for my 65 c10 frame. This comes with instructions and template still for install? Please send me the info. Thanks.
Garage Built
Homebuilt Hotrods is offline   Reply With Quote
Old 09-15-2017, 11:37 PM   #741
Captainfab
60-66 Nut
I replied to your PM............
Old 09-29-2017, 09:40 AM   #742
superfly66
What bracket are people using from the PS pump to the motor. I have the pump brackets minus the one to the motor. I got my parts from an 83 c10 and I didnt get the pump bracket to the motor. I never see any talk about fitting the pump to the motor..
And also I got the steering shaft from the 83 C10 as well. Will any mods need to be made like discussed previously about shortening the originial? Or is it better to use original with the mods? TIA ~Bryan
superfly66 is offline   Reply With Quote
Old 09-29-2017, 10:56 PM   #743
Captainfab
60-66 Nut
There are many variables to that question. It will depend on what engine you have. Do you have a 230/250 I6, A 292 I6, A small block? If small block do you have the correct short water pump or do you have one of the variations of the long water pump? Or do you have a big block? There again, short water pump or long water pump.
As for using the '83 intermediate steering column shaft, many guys do to gain the feature of the slip in the shaft in the event of a collision.
Old 09-30-2017, 10:47 AM   #744
superfly66
Old 09-30-2017, 10:51 AM   #745
superfly66
First of all thanks for the PS bracket. And I have a small block 350 vortec motor, It’s an 89 I believe and I have a short water pump.
Old 09-30-2017, 11:23 AM   #746
Captainfab
60-66 Nut
Your welcome for the bracket, I appreciate the purchase.
An '89 350 is not a Vortec engine. It is simply a TBI 350 with swirl port heads. The Vortec 350 was used from '96-'02 only.
With a small block that has accessory bolt hole heads and a short water pump I would recommend brackets and pulleys from a '72 and earlier truck or a '68 and earlier car. Personally I prefer the '68-'72 truck brackets for both the alternator and power steering pump.
Old 09-30-2017, 06:53 PM   #747
superfly66
I was told the motor came out of an 89 Trans Am. But it does have vortec heads. It has the 2 bolts in the center of the valve cover. Again that is what I was told on those heads with the VC bolts in the center. But thanks for the advice on the bracket.
Old 09-30-2017, 07:13 PM   #748
Homebuilt Hotrods
Highly recommended seller. I appreciate your willingness to help my situation and will buy more in the future and will 100% recommend to my fellow c10 crowd.
Garage Built
Old 10-01-2017, 12:34 AM   #749
Captainfab
60-66 Nut
You have been misinformed. Not all heads with centerbolt valve covers are Vortec heads. All small block heads from '87-'02 utilize centerbolt valve covers. As I said previously, the Vortec small block was produced from '96-'02 only. If your engine is indeed from a '89 Trans Am it is a TPI engine, either a 305 or a 350
Old 10-01-2017, 12:35 AM   #750
Captainfab
60-66 Nut
Thank you for the kind words. I assume you received the second steering box adapter plate today?
