07-27-2013, 07:58 PM | #7526 |
Re: What did you do to your truck today!
Weather stripping going on
1970 Chevy swb, project UGHH! 1987 Grand National http://s168.photobucket.com/albums/u.../1970%20Chevy/ |
07-27-2013, 09:31 PM | #7527 |
Junior Member
I took my '67 swb stepper for a drive, then decided it needed to be washed.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
07-27-2013, 10:21 PM | #7528 |
I have started the "tear down" on the 70' for paint. Here is a picture of where I am....was a complete truck this morning. Hope to have hood, fenders, doors, and cowl to the painter in the next couple of weeks. Putting in a new Radiator support next week..Happy, Happy,...Happy!!
1970 GMC Sierra Grande CST SWB Fleetside "Texas Touch" "An intellectual is a man who takes more words than necessary to tell more than he knows" |
07-28-2013, 08:56 AM | #7529 |
Walked out to it @ 04:30 and lit it off , drove it to the Coffee House where I'm reading this .
I *may* have found a good '69 cab out of state , we'll see . I'm quite sure there's plenty of decent cabs here in California but I can't seem to find any . God , I love this old Base Model Truck ! .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
07-28-2013, 10:23 AM | #7530 |
I'm prepping new parts for install.
07-28-2013, 12:04 PM | #7531 |
Door panels going on
07-28-2013, 12:28 PM | #7532 |
Yesterday, cleaned under the cowl and in the vent area, pulled the dash and installed a new bezel and pulled the dead am/fm cassett player, installed new water pump and thermostat.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
07-28-2013, 07:05 PM | #7533 |
I got a little closer today.
Tightened up the oil drain bolt as I had a very slight leak. I removed all of the rubber hose connections on the fuel line and all but two connections on the charcaol vent line. I loosened the metal fuel line between the fuel pump and the carb. I also picked up my new fuel pump. Posted via Mobile Device |
07-28-2013, 08:36 PM | #7534 |
Found a full set of 8 lug steelies with tires for 50 bucks. Brought em home and cleaned them up. Maybe I'll throw them on tomorrow to replace to split wheels I have now.
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L |
07-28-2013, 08:57 PM | #7535 |
9 months and $125 later i finally got to further improve the user interface.
also finally got the original fuel tank out of the cab. next step is welding in the delete plug.
i love every machine. even the ones i hate. Current project (1959) fifty niner gmc fleetside: http://67-72chevytrucks.com/vboard/s...70#post6514670 MY daily driver truck thread : http://67-72chevytrucks.com/vboard/s...d.php?t=544460 |
07-28-2013, 09:33 PM | #7536 |
I flipped my trailing arm crossmember. And welded my my trailing arms
07-29-2013, 01:50 AM | #7537 |
Scrapped out the seam sealer under the cowl on both sides just below the window, cleaned it up as good as possible, treated it with a rust converter, then re sealed them.
07-29-2013, 09:46 PM | #7538 |
Off for final exhaust work
07-29-2013, 10:13 PM | #7539 |
No "work" today but I feel I made good progress. I asked a garage about replacing the cab mount bushings and it seems to be something I can indeed do myself assuming I can get the bolts out.
Another garage will clean out the gas tank for $50.00 but the man had his doubts as to whether or not I'll end up having to get a new tank. If I do, I just do. He can also clean the radiator but according to my description, he's pretty sure the radiator is beyond repair. If my sending unit removal tool comes tomorrow I'll get that out and run the tank over for cleaning. |
07-29-2013, 10:31 PM | #7540 | |
07-29-2013, 11:21 PM | #7541 |
07-29-2013, 11:41 PM | #7542 |
Re : Rusty Joints
This seems to be a common thread , pictures would be really helpful .
07-29-2013, 11:41 PM | #7543 |
Bought some very nice grey leather second row Suburban seats today for my truck, will post pic's when I install, of course may be a few days as everyone elses stuff gets in the road...but pays for my parts.
07-30-2013, 05:34 PM | #7544 |
Spent 550 dollars made from arizona summer roof work on her! Time to get this a/c fixed! (Parallel flow condenser, a poa valve update, and a fan shroud)
07-30-2013, 06:39 PM | #7545 |
I ordered a cab to frame mounting kit from Classic Heartbeat and found out A LOT of straightforward info from the owner, Wes.
07-30-2013, 08:35 PM | #7546 |
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!! |
07-30-2013, 08:46 PM | #7547 |
What did he tell you?
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
07-31-2013, 07:30 PM | #7548 |
I took my gas tank over to a radiator shop and found out is was rusty! It's only surface rust and the guy is going to sandblast the inside, then use "renue" to fix it up. He's confident it will be right. Price is less than buying an aftermarket one.
I also removed my cab's floor rubber and found out that the front cab to frame bolts are welded in at the top. Dang. Now I'll have to figure that one out. |
07-31-2013, 09:03 PM | #7549 |
Put new Billies on it and got rid of the dual rancho redneck setup it had. All 8 shocks were trashed and I've never liked duals unless it's for desert racing and you actually need them.
Also posted the truck up on Craigslist to feel for bites and maybe trade for something more practical for my needs. Not going to post the ad here due to me not knowing the rules around here but it can be found in Austin CL. Not pushing to sell it either so I placed a pretty high price on him.
Owner: Times Are Tough Toys 92 4 Runner (Joyce, long story from my time in Africa) Lotsa stuff, just about finished dumping money into it. 89 Mercedes 560 SEL, Merdle. Wrecked 71 Chevy K20, Clifford, BB and 1 Tons |
07-31-2013, 09:10 PM | #7550 |
had to do some emergency roadside repairs due to a clogged fuel filter. Its nice to think on my feet every now and again.
