05-11-2017, 10:17 AM | #751 |
Re: How about some pics of Static Dropped C-10's
Heres my 65 C10 5/7" drop 20x8 and 20x9.5. P245/40r20 front and P285/35R20 rear BFGs. Also has 1" rear wheel spacers to make rear farther away from the bed.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
05-11-2017, 10:53 AM | #752 |
^^^ I like it! ^^^
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
05-11-2017, 11:09 AM | #753 |
Hey Zach, I was parked right behind you guys at the All Truck Nationals a couple weekends ago in pigeon forge. Your truck looks awesome, it was one of my favorites there
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
05-11-2017, 11:50 AM | #754 |
Thanks a lot guys. I love the truck a lot!
05-15-2017, 11:39 AM | #755 |
Those running 20's with a 5 7 do you have a c notch in the rear?
05-16-2017, 07:50 AM | #756 |
Yes my truck has a small notch in the rear. Bed floor and all is original though.
05-16-2017, 08:07 AM | #757 |
Post Whore
Looking good zach..
05-16-2017, 10:03 AM | #758 |
I started doing a notch on my truck and wanted to make it easier so i took the bed off. One thing led to another and now im like 1500$ into a coil over 4 link with watts link all inboard the frame.
instagram - @custom.chevy |
05-16-2017, 10:56 AM | #759 |
motor exploder
I'm running 19's, 5/7 drop with c-notch and stock bed floor/location.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
05-16-2017, 11:10 AM | #760 |
66clow I know we talked before but 5 inch springs and 2 inch blocks in the rear with 3 inch springs in the front. No C notch and no problems.
First pict just with 5inch springs 2nd after adding 2 inch clocks. |
05-16-2017, 12:10 PM | #761 |
Maybe its the angle of the photo but for some reason the truck pictured doesn't look low enough to have a 5/7 drop? Doesn't a 5/7 drop typically tuck the top of a 27-28 inch tall tire into the fender? What size tires are you running? Total diameter.
05-16-2017, 12:13 PM | #762 |
I thought it would have been lower too, only 3-7 drop. The 20's seem to keep it up more than I anticipated. Rocket Racing Booster 6 20x9 +0 wheels Toyo Proxes S/T 275/45 tires with Autospring Lowered 3F / 7R
05-16-2017, 12:14 PM | #763 |
The reason i say this is because i just did a 5 inch drop on the rear of a truck yesterday evening and it was tucking the top of a 30" tire, so my tire is probably taller but i also only did a 5 inch drop not a 7. Im probably tucking 2-3 inches of tire so a 7" drop would easily tuck a 27-28" tire.
Your truck look killer though. Love it. That color is awesome.
05-16-2017, 12:17 PM | #764 | |
05-16-2017, 12:28 PM | #765 |
05-16-2017, 12:33 PM | #766 | |
05-16-2017, 12:35 PM | #767 | |
I hear you. I finally got my truck to the height i wanted to keep it at just to find out exactly what you said. My long tubes are dragging on everything. Im having to use 2x4 to get in and out of my drive way. Sheared 4/6 collector bolts pulling out of a gas station. My next step for my blue/silver truck is mid length headers and exhaust that is closely tucked to the body,, im hopefully going to run the exhaust through the frame as close to the front of the truck as possible then run it outside the frame and dump it down at an angle towards the outside. Just ideas right now.
05-16-2017, 12:38 PM | #768 |
Now you guys have me second guessing myself. I ordered new springs when I did this but never checked the measurement.
05-16-2017, 12:41 PM | #769 |
Lol, you have any photos from underneath of how much room you have above the axle? I'm going to check mine this evening.
05-16-2017, 01:27 PM | #770 |
I will get some tonight.
05-16-2017, 02:21 PM | #771 |
motor exploder
Just for comparison, my rear tires are 27" tall as they sit on the truck (actual measurement), my rear fender lip is 27.75" from the pavement. I'm running a 6" Hotchkis drop spring and an 1.5" block in the pic here.
05-16-2017, 03:26 PM | #772 |
Pulled up some picts from the build. first before tear down. 2nd after 3 -5 drop and last sitting in the driveway with the 2 inch blocks added..
05-16-2017, 04:59 PM | #773 | |
05-16-2017, 09:43 PM | #774 |
Haha my little boy loved your truck at the show man.
Follow me on Instagram @rodsgreen10 Hit my YouTube page up http://www.youtube.com/c/RodsGreen10 |
05-17-2017, 07:27 AM | #775 |
RodsGreen thats awesome!!! Thats what its all about! Its definitely had its fair share a kid pictures thats for sure.
