Old 01-01-2016, 12:56 PM   #751
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: 1976 Square "Simple Green"
Originally Posted by RodsGreen10 View Post
The FiTech does not have a ground wire it ground thought the studs on the intake. And I will argue until I am blue in the face about how I have it hooked up. Lol. The junction block is tied into the battery.
I guess that's what I'm getting at.
Not that you've done anything wrong, but that they may have a design glitch. Maybe they shouldn't have attempted to use the base studs for grounding.
66 C20 Service Truck:
Old 01-01-2016, 12:59 PM   #752
swampbog
swampbog's Avatar
I have junction blocks in my Jeep, both for ground and 12V.
Because of that I think it has anything to do with the junction block. All the junction block does is act like a remote post for the battery, it's direct line to the battery.
I'm more leery on the ground, but I'm bias because that is usually the majority of the issues I run in to on my electrical problems on my Jeep. Hench why I have so many dedicated grounds
swampbog is offline   Reply With Quote
Old 01-01-2016, 12:59 PM   #753
RodsGreen10
RodsGreen10's Avatar
Originally Posted by diceman50 View Post
I have a friend who installed one on a Bronco. Engine would start and then die. Changed the battery and it ran great for a while. Then it wouldn't start at all. It burned up a couple of the pins in the power connector. (the yellow one) He sent it back to FiTech and I have not heard the outcome.
I am getting ready to put one on a friends 69 Camaro. We have already decided if we have any of these issues we will just use the throttle body and the injectors and run it with a GM computer like we are doing with the Retrotec throttle bodies on my Apache. I hope it doesn't come to that.
That blows. How did he determine he burnt up some pins in the connector.
I would like to see that setup on the Apache.
RodsGreen10 is offline   Reply With Quote
Old 01-01-2016, 12:59 PM   #754
swampbog
swampbog's Avatar
+1 and a beer
Old 01-01-2016, 01:00 PM   #755
RodsGreen10
I like you more and more everyday lol. I hear ya man that is what I am leaning towards more now after reading some other posts from other users.
Old 01-01-2016, 01:02 PM   #756
RUN GMC
RUN GMC's Avatar
So I started to really think about what was going on here and I just remembered in the "Hot Rod to the rescue"section that a guy with a truck had a cold crank issue (Greg says he had to “crank it forever” to get the truck started ) with a 502hp ZZ502 big-block crate motor.....well after re-reading the last statement stood out and it was...(Im not saying you are wrong at all about your grounding) but a good read non the less................
4. Improper electrical grounds: “EFI systems don’t work properly if the grounds don’t go back to the battery’s Negative post.” Sensors operate under minute voltage variations, so any voltage fluctuations, resistance, or drop can introduce erroneous readings. Remember, the circuit’s ground-side is part of the total circuit length, and hence, contributes to resistance and voltage drop. A standard chassis-ground won’t cut it.
.....at the end of the read was the top 4 EFI mistakes this was one.......here is the link to the article.......................
http://www.hotrod.com/how-to/engine/...over-internet/
.....I hope this shines a light on something we are not seeing...Rod Im sorry for your family's lost at this time........God speed and good luck......
RUN GMC is offline   Reply With Quote
Old 01-01-2016, 01:02 PM   #757
RodsGreen10
My bad wasn't trying to sound like I was snapping at you. I agree with you!! That is why when they told me add a ground strap from the carb stud and run it directly to battery I said why the **** didn't you all add a ground in the system. I got white noise lol.
Old 01-01-2016, 01:03 PM   #758
diceman50
This is how I described it to Jeremy from FiTech. Imagine it like this battery on the left junction box on the right starter in the middle. They all connect at the start which is the center point. So what would it make a difference connecting at battery vs junction box. It all runs to the starter.
There is a certain amount of resistance in every electrical connection. Sometimes they are so slight that you can't measure them with a common meter but they add up, so the fewer you have the better. Especially if it is a sensitive electronic system you are working on. All my power and ground connections will go to the battery.
"In an insane world a sane man must appear insane" ~Spock~
diceman50 is offline   Reply With Quote
Old 01-01-2016, 01:06 PM   #759
RodsGreen10
I really really think it is a ground issue. But that would be a design flaw on FiTechs part. Cause they sure as hell don't have a ground wire or anything of that nature for the system. They are using the carb studs as the grounds. But when I called and talked and BS with them it was o runs ground from the carb stud to the battery. WTF... Give me a ground already terminated in the harness and let me ground it to the block or frame.
Old 01-01-2016, 01:07 PM   #760
RodsGreen10
Yes I am still going to test it wired direct to the battery so if that and the new grounds fix it. I will let everyone know.
Old 01-01-2016, 01:11 PM   #761
LostMy65
LostMy65's Avatar
I think it's great.
I plan on helping anyway I can with my research.
If enough information is here, FiTech might like to get involved. It can't help but benefit them and the end user. (us).
Ken and Jermey know about this thread lol. I have sent them links and talked with them about it and my posts. Plus they like my YouTube video and my truck lol. They know a good truck when they see one lmao.
They would do themselves a huge service if they assigned one of their good techs to assisting on a forum level.
As it is, they're going to spend many hours doing phone support for people asking the same questions over and over. Assign one member of their team to assist on a forum level, and they can direct customers to their support Forum.
I did this years back when hundreds of employees on different schedules were discussing an upcoming contract.
There was no way we could of accomplished what we did unless we would have had several meetings. But then also, nobody's schedules would have lended to a scheduled meeting..
So, FiTech should take one of their phone support members, and assign them here to assist in a forum.
They are so limited trying to do their support over the phone.
Old 01-01-2016, 01:22 PM   #762
RodsGreen10
I agree with this 100% or do like MSD or Fast start a dedicated forum for support.
Old 01-01-2016, 01:30 PM   #763
LostMy65
LostMy65's Avatar
Perfect!
But if they are so swamped they don't have time to build their own, just get one of their guys in here.
Old 01-01-2016, 01:46 PM   #764
swampbog
swampbog's Avatar
Aww, I'm kinda sweet on you too
Old 01-01-2016, 01:51 PM   #765
RodsGreen10
Lmfao!!
Old 01-01-2016, 01:57 PM   #766
swampbog
swampbog's Avatar
Yeah that's one thing I didn't understand why they don't have one.
I do know they made a bunch of OEM stuff but everyone of those was for a known vehicle or component. When you get to guys (and gals) like us, no two vehicles are the same and we all don't wire things the same way. They need to make it so they can control how people hook it up, e.g. a dedicated ground wire.
Maybe when you call them back up on Monday you point them to this forum and tell them we all are trying to fix a problem with your (literately yours and theirs) EFI. Especially if it turns out to be a ground issue!
How hard would it be to add a wire in to the harness for a ground, or add a wire with a terminal ring to the body and add a slip of paper in the instruction packet stating to attach a dedicated ground wire to this.
Old 01-01-2016, 02:04 PM   #767
swampbog
swampbog's Avatar
But they need to support more than one forum site.
I only showed here because of my RodsGreen10 writeup, if I wasn't pulled in because of that I would be up ****s creek if they only supported one forum.
(i know you weren't really saying only here, I wrote this so if they do read this forum they will expand to different forums)
Old 01-01-2016, 02:06 PM   #768
ray1970
Ray here.
In the name of science-color cones-nerve endings and the drugs we did in the 80s
What color is it.
1.black.
2.white.
3.gray.
4.After last night every things a blur ask me tomorrow.
5.Dude am color blind don't ask me this stuff.
Put my old battery back in with a charger.. it did start once but not twice.
Just showing how it went and after having one or two Sam Adams am just wasting a little time before I go home..
Ray.(it did go black one time)
ray1970 is offline   Reply With Quote
Old 01-01-2016, 02:09 PM   #769
swampbog
swampbog's Avatar
Originally Posted by ray1970 View Post
Ray here.
What color is it.
1.black.
2.white.
3.gray.
3 with a little 4 toss in
Old 01-01-2016, 02:12 PM   #770
RodsGreen10
Mine is white like the FiTech writing on the handheld. Not that color.
Old 01-01-2016, 02:13 PM   #771
LostMy65
LostMy65's Avatar
Yes, the dedicated red wire and dedicated black wire going straight to the battery terminals on the other units are pretty heavy gauge wire.
Old 01-01-2016, 02:21 PM   #772
swampbog
swampbog's Avatar
That was an interesting read. It would be so cool if we could do that with the FiTech unit but from what Ray and Rod have found out about the data logging it's very doubtful, maybe their next generation will be better equip to do something like that.
Old 01-01-2016, 02:27 PM   #773
LostMy65
LostMy65's Avatar
Thank you again for this thread.
We've kinda wandered some, but all helpful information that will benefit many in the coming months.
I think once we all start getting our units around the end of January, we'll start building even more trouble shooting discussions.
On the topic of wiring, I ran across this somewhat related interesting read.
http://www.corvetteonline.com/tech-s...rancis-wiring/
Old 01-01-2016, 02:48 PM   #774
ray1970
Ray here.
It goes black when the cables fall out...This is normal just put more zip ties on it....
I really need to get over that....
Ray..
Old 01-01-2016, 03:03 PM   #775
RUN GMC
RUN GMC's Avatar
Thanks for that was a very good read...............Im preparing go through wiring on my 98 GMC due to cranking issues.....gonna redo the battery cables and alternator wires first........
