06-30-2020, 12:59 PM | #751 | ||
Re: TA_C10: Stage 1
They seem a little flimsy when you mess with them, but once they are bolted to seat and floor board they don't move.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
07-01-2020, 12:45 AM | #752 |
Re: TA_C10: Stage 1
nice update! who did you source those new seat brackets from?
07-01-2020, 09:09 AM | #753 |
Re: TA_C10: Stage 1
Update - PDU panel is complete.
Well here it is. v2 completed. Honestly I like it a little better since I got to move some things around that weren't great on the original panel. Things just function better now. I put rubber washers under the TAC module. All the distribution blocks installed. Bottom left(red) is my Key + coming straight from the ignition switch. Top left is the smaller gauge stuff. Top right is the larger gauge/power things like horn and starter and etc. This is the spacers and rubber washers for PCM mounting. The two terminals on the right are my PDU ground and power distribution. 1awg cable comes direct from battery positive fused of course, and ground is direct as well from battery. You can see my complete diagram back a few pages in my thread. These 2 feed everything for the engine compartment except for the vintage air and PCM, I ran a seperate power source direct from battery just for those. Panel mounting, getting ready to wire it up. Front panel wired up(minus the battery/ground feeds). The main engine harness from cab will be hidden in the fender. Getting there Here is where I ran all my core support grounds to. It a mounting tab made out of 16awg steel to mount the PDU panel to. It now doubles as a grounding tab on the back. That's pretty much it. I just need to zip tie everything up and during reassembly I can get everything completed like the parking lights and few other stragglers. Oh yeah, and I got rid of the remote battery posts. I couldn't fuse that direct 1awg hot wire back to battery because during charging from another vehicle it would just pop. I didn't want that hot all the time so I got rid of it. I will figure something else out for jump starting should I ever need it. Who else out there works like this? Gotta pull everything out to work, then put it all back at night... Ah. This hobby is gonna kill me. Or my wife will if I don't finish soon
07-01-2020, 09:10 AM | #754 |
Re: TA_C10: Stage 1
07-01-2020, 09:32 AM | #755 |
Re: TA_C10: Stage 1
WOW! You move fast. That is looking really nice. I apologize as I am new to this , but what does the TAC module do?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
07-01-2020, 09:39 AM | #756 |
Re: TA_C10: Stage 1
Throttle Actuator Control Module. It's the accelerator pedal control box for the GEN III LS motors. Drive by Wire gas pedal
Also handles cruise control .
07-01-2020, 09:41 AM | #757 | |
Re: TA_C10: Stage 1
Definitely not for everyone but man is it nice for the enthusiast. But, my shop still looks similar when multiple projects are disassembled.
07-01-2020, 10:04 AM | #758 |
Re: TA_C10: Stage 1
I have a much larger area than a 2 car garage and still feel like I spend more time cleaning and rearranging than working. I sometimes wonder if having a smaller area would be better.
07-01-2020, 01:24 PM | #759 |
Re: TA_C10: Stage 1
Oh thank you. I have a cable throttle so no TAC. I thought I had forgotten an important part LOL! So imagine for a moment your garage with two trucks stuffed in there. I have to take a truck out just to get to my ladder! My only workbench is when I open the tailgate on my pickup. I am used to working from a tailgate though. Might be a PITA when I lower it back down.
07-06-2020, 12:57 PM | #760 |
Re: TA_C10: Stage 1
Update - Headlight Buckets - Wrong Radiator Support
This is where research really pays off. And writing down your plan on paper and then going over it and all the parts you have first before ordering new parts. So my truck is a 70 with a 67-68 dog house. Turns out, the radiator support is different in those years.... All the parts I ordered I just defaulted to 1970 without even thinking about it. So GM got smart and instead of re-engineering the whole core support they just re-tooled their existing with a bracket to relocate the headlight buckets. You can tell that's what they did... More on this later. So I found this thread and basically did what he did, but I did a few things differently. http://67-72chevytrucks.com/vboard/s...d.php?t=399960 He gives you the basics, and enough detail to get it done, but he doesn't mention how DANG HARD IT IS TO ALIGN THESE THINGS!! And how many times your have to remove your grill and put it back on again. It's a LOT lol. So, long story short. I ordered wrong radiator support(1970 version), and didn't want to order a new one($200 down the drain) mainly because I already painted mine and modified it. So I cut the bucket brackets off and modified mine to work. Took be every bit of 8 hours to do this.... Here is the original bucket setup for the 69+ models. You can see the bucket mounts to the added "bracket" they spot welded on the rad support. I drilled the spot welds and removed the bracket. I then flattened that bracket and cut off all the excess I didn't need. I only kept the mounting points for the headlight bucket(2 square holes and the little spring hole). This is where I differed from the thread above, he cut all that off and cut into the rad support. I then marked and cut my center hole larger and moved it down and over to line it up correctly(install and remove grill several times when you don't get it right the first time.... It's a pain cuz it all has to be lined up just right. You know that means you gotta get all the other sheet metal lined up too(fenders and etc).... Here is the bracket, flattened out and trimmed. This to me was much easier to just re-use rather than cutting new holes into the rad support. The guy above cut all that off, but yet he still used sheet metal screws to fasten to the rad support for that nice 4" round hole.... Here you can see how much of the original hole I actually cut out of the rad support. And I ground down the edge of where I was going to weld on the flattened bracket. And here it is tacked on. I intend to go back and clean this up a bit, prime and paint. But you can see it's easier to keep this for all the mounting points, now I know it's perfectly aligned for when I go to install the headlight buckets back on later. And here are the final results after installing everything again. The headlights of course not aligned to their final spot yet but you can see this works rather well. Good enough for me anyway!! BEFORE pics: AFTER pics:
07-06-2020, 02:34 PM | #761 |
Re: TA_C10: Stage 1
Wow lots of fun! Looks good, glad you got it all figured out.
07-06-2020, 03:26 PM | #762 |
Re: TA_C10: Stage 1
What headlights are you running?
07-06-2020, 03:41 PM | #763 |
Re: TA_C10: Stage 1
Looks good so it was worth your effort.
07-06-2020, 03:44 PM | #764 | |
Re: TA_C10: Stage 1
I like to call em the T-bar LED's from LMC They are from LMCTruck, LED replacement bulbs. They are awesome. I have a post on them a few pages back I think. Shows the daytime runners vs low beam vs high beam. The pics don't do them justice however, they are badazz at night or dusk with just the daytime runners on. Just a sleek little bar of LED's running through the middle of the bulbs. They look mean from a distance with the look of this style truck lowered on the road. .
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". Last edited by TA_C10; 07-06-2020 at 04:24 PM. |
07-06-2020, 04:03 PM | #765 |
Re: TA_C10: Stage 1
I can say I learned something new today! Thanks for the lesson and solid work.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
07-06-2020, 04:23 PM | #766 | |
Re: TA_C10: Stage 1
07-07-2020, 06:18 AM | #767 |
Re: TA_C10: Stage 1
following
07-07-2020, 06:22 AM | #768 | |
Re: TA_C10: Stage 1
07-07-2020, 10:34 AM | #769 | |
Re: TA_C10: Stage 1
I sent a PM to the moderators 70LonghornCST last night but no reply yet. @70LonghornCST, @leddzepp .
07-07-2020, 10:39 AM | #770 |
Re: TA_C10: Stage 1
Update - Hood Letters
My original hood was pretty beat up, if you go back to first page on my thread you can see the hood dents and was in bad shape. It had so many "extra" holes in it, at the time, I didn't realize what they were so I filled them all. Fast forward a year or so later and I ended up seeing pics and decided I wanted the hood letters so I had to re-drill all the holes. Oh well, wasn't too bad, I just did a lot of measuring. Hood is now ready for filler and paint.
07-07-2020, 10:47 AM | #771 |
Re: TA_C10: Stage 1
nice work on the core support. Those headlights are sweeeet! I’m hoping to get something similar.
also, nice work on the hood. How’d you know how to layout the letters with the holes filled? template? |
07-07-2020, 11:57 AM | #772 |
A guy with a truck
Re: TA_C10: Stage 1
Clean work on the core support. I have done this job in my head a few times, nice to know it’s actually possible.
Posted via Mobile Device |
07-08-2020, 11:14 AM | #773 |
Re: TA_C10: Stage 1
Update - Bed Sides Shaved.
Not much to say here. Except this was the easiest welding I have ever done on this vehicle. I cut a strip of metal that was the "length" of the bed stake pockets opening. Then cut them all the same "width" with a template I made. Cleaned them. Put a little primer on the back side. Welded them in. I only have 2 more metal projects left to finish. Custom gas filler in the bed and I need to weld up the holes to get rid of the big bulky chevy emblem in center of grill. Then I am ready for filler and paint...
07-09-2020, 09:37 AM | #774 |
Re: TA_C10: Stage 1
I am also interested in your fuel system. Can't wait for those pics.
07-09-2020, 09:56 AM | #775 |
Re: TA_C10: Stage 1
I can't edit my old posts.... The button isn't there anymore. I sent a message to both our moderators and one sent message back telling me to start a new thread.... I sent another message to ask if they could open my thread back up so I could edit old posts. No response.... I might have to start a new thread if they don't get back with me. That would really suck.
