09-05-2013, 05:38 PM | #7851 |
RAT1968 '68 Cab/'71 Parts
Re: What did you do to your truck today!
I'm not a big fan of stick on stuff. But I found these letters in my parts stash while I was looking for something else.
I'm headed to the striper's tomorrow. He'll probably wring my neck for sticking these on. Hell, this ain't no show truck. And, I already had 'em. So, I stuck 'em on.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
09-05-2013, 07:09 PM | #7852 |
09-05-2013, 09:52 PM | #7853 |
Having some problems with the whole grill polishing the way we want Posted via Mobile Device |
09-06-2013, 07:19 AM | #7854 | |
1970 C10 Short Stepper with 71/72 front clip. |
09-06-2013, 04:45 PM | #7855 |
I have stainless trim on my windshield seal too. It took me almost a month and three glass guys before the windshield finally went in. It was the most frustrating part of my entire build.
09-06-2013, 05:01 PM | #7856 |
replaced the donut gasket between manifold and pipe with the help of a little heat ( fought it for a few days with just pb blaster) then I removed the giant step bumper and drilled some holes to mount the plate to the truck. it sounds so much better when the exhaust is coming out of the back instead of from the engine bay
09-06-2013, 08:47 PM | #7857 |
Kind of a big day for me. First "Long Run" of only 50 miles.
To take RAT to the pinstriper. Only one casualty on the way. A windshield wiper blade blew off. I knew that crap plastic connector was cracked....What do you guys and gals run? I can't seem to find anything substantial to hook on to the wiper arms. This'll be the last pic with no pin-stripes. Got the mirrors on, and a couple of clean-up items. Ran fine all the way. 3:07's with the 350/350 combo gave me 2200 RPM at 64 mph. Of course, I'm running the 20's...so..........?????
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 09-06-2013 at 10:07 PM. |
09-06-2013, 09:33 PM | #7858 |
CLR+Scotch Brite+Meguiars Wax= Happy Patina Truck....
Obviously, I just waxed the front clip at this point... Looks 100x better than the 10 years of grime it came with... For fun... Posted via Mobile Device
'70/C10/402/TH400. |
09-07-2013, 01:10 AM | #7859 |
Pulled my TBI off and did new gaskets, o-rings, filters, regulator gasket, and regulator spring. Truck still wont start. Back at it tomorrow, I'm thinking I've got issues with how much fuel pressure I've got. Everywhere online says I need 13 psi and my new fuel pump claims to be 10-14 psi. I think a fuel pressure gauge is next on the list.
1970 GMC |
09-07-2013, 01:12 AM | #7860 |
http://charlotte.craigslist.org/pts/4013661255.html
Well since the Acc.Pump throttle brace broke I'll be getting this to fix it ....
1971 GMC Sierra 1959 GMC 100 |
09-07-2013, 03:28 AM | #7861 |
The LMC exhaust came in yesterday. Tonight I started trying to install the head pipes. Each section has a label with the respective location such as "left downpipe" or "right tail pipe". I started with the right head pipe (passenger side in my book) and there was no way it was going on. The bend angle was all wrong. I gave up and tried the left (driver) pipe. Same issue. I wondered to myself if they mislabelled them, so I tried swapping them. BINGO! Like a glove! Intermediates were mislabelled as well, but at least they were consistent! I will need to cut the intermediate pipes down since the kit is for a lwb or swb and i have a swb. I also plan to buy some of the tailpipe pookie sealer stuff before permanent assembly. Debating on whether or not to use the pipe clamps on the joints or mig weld or both.
Posted via Mobile Device Posted via Mobile Device |
09-07-2013, 03:37 AM | #7862 |
Big question everyone on the stock Rochester 4BBL Carb, is there a plastic Vacuum Advance, because mine has a slight crack on it
09-08-2013, 02:18 AM | #7863 |
Finished installing a goose neck hitch in my 72 C20
09-08-2013, 10:41 AM | #7864 |
I had some dust installed yesterday and some more coming in today. I think it's going to be like this until I sell it.
1968 Chevy shortbed fleetside Pro Street |
09-08-2013, 05:02 PM | #7865 |
finally after ten years it has a new paint job. still have to wet sand and polish
09-08-2013, 05:28 PM | #7866 |
Looks great keep up the good work
Fuzzy |
09-09-2013, 01:27 AM | #7867 |
I got my frame painted....
09-09-2013, 02:50 AM | #7868 |
cleaned the c20 some and put it back in it's spot
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
09-09-2013, 08:49 AM | #7869 |
I looked at my still loaded truck in SWMBO's garage and wished Joey hadn't worked too hard and broken two of the screws in his spine so he wasn't convalescing from yet another back sugery and I could go borrow the towable cherrypicker and get the 292 out of my truck so I can begin working on it and working my trcuk again...
I have a 150 # Moto that needs to go to the CHP for VIN inspection to - day and I can't find anyone to truck it there for me ,I might have to rent a U-Haul pickup else I'll have to push it 5 miles each way in this dang heat..... Yes , I am whining again , I'll stop now .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
09-09-2013, 09:20 PM | #7870 |
Wet sanding and polish (cut-n-buff) is a PITA! I'm doing that now also. Don't kill yourself if you have some burn through...you might, I did/do. Anything can be fixed...I hope.
09-09-2013, 10:33 PM | #7871 |
I received my new cab supports!
09-09-2013, 11:26 PM | #7872 |
09-10-2013, 05:03 PM | #7873 |
for some unknown reason my computer will not show past page 315 , I am still getting e-mail that shows a new post, but it will not go to page 316 317 318.
anyone else having this problem with this on ( what did you do to your truck today ? )... |
09-10-2013, 05:06 PM | #7874 |
Proprietor of Dale's Corner
Yes, I have the same problem Dollor. Your post shows on page 315 but the thread is showing more pages
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
09-10-2013, 05:37 PM | #7875 |
Yes ;
It's been stuck on page 315 for a week now .
