Old 06-24-2012, 10:22 PM   #776
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Starter works. After I grounded my engine to the frame with some jumper cables. Still need to weld a bit before I put in some gas. Bottom of the exhaust in places and alittle on the bottom of the notch.
daverod is offline   Reply With Quote
Old 06-25-2012, 11:17 AM   #777
Layedoutsonoma91
Layedoutsonoma91's Avatar
Re: Daverods 52
I bet you are excited man, all that hard work is close to paying off big time!
1954 Chevy 3100 5 window, bagged on s10 frame,
6.0 ls swap/4l80e
Past build thread
http://67-72chevytrucks.com/vboard/s...=531261&page=3
1949 3100 s10 swap 5.3.
Instagram -@thejcates
Layedoutsonoma91 is offline   Reply With Quote
Old 06-25-2012, 09:37 PM   #778
Strodder
Daring to be Different
Strodder's Avatar
Re: Daverods 52
Originally Posted by daverod View Post
Went to Autozone and rented a oil pump primer. Got my new wires put on. Just bought a cheap gage and a tube kit so I can read my oil presure. Maybe I'll go get some gas.
You could have come over here for that pump primer. I would't even charge you.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 06-26-2012, 12:55 AM   #779
OrrieG
OrrieG's Avatar
Re: Daverods 52
Ok, I am confused, what is an oil primer? I thought you just used a 1/4" drill until it started smoking!
OrrieG is offline   Reply With Quote
Old 06-26-2012, 09:30 AM   #780
Strodder
Strodder's Avatar
Re: Daverods 52
It takes the place of the distributor to drive the oil pump with a drill. That pushes oil through out the engine before you start a fresh rebuild. Of course it has to have oil in it.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 06-26-2012, 10:08 AM   #781
mknittle
mknittle's Avatar
Re: Daverods 52
Thats the way I do it
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 06-26-2012, 10:10 AM   #782
mknittle
mknittle's Avatar
Re: Daverods 52
I made mine out of old distributors.
Mark
My GMC build.
Old 06-26-2012, 01:23 PM   #783
OrrieG
OrrieG's Avatar
Re: Daverods 52
Thats what I use too, I thought it might be some type of pressureized system that used the galley plugs, maybe with a heater and essential oils, oops I'm getting confused with my wifes spa treatments. Old age is not for the weak.
Old 06-26-2012, 03:34 PM   #784
99 to Life
99 to Life's Avatar
Re: Daverods 52
I just bought the tool, but you can use an old dist. also turn the engine over once or twice by hand when you are priming, it will help get oil to all the lifters.
Run your drill on the highest setting and make sure you got a good battery. You should be at 60-80 psi on a cold prime depending on your bearing clearance. Anything below 50 and I'd be worried. Just my advise.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 06-27-2012, 11:31 PM   #785
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
I just ran it with a 18 volt drill. Did it till I saw oil coming out of all of the pushrods. Turned the engine over a couple times. Still need to hook up my gas.Summers here and it sucks.
Old 06-29-2012, 12:10 AM   #786
99 to Life
99 to Life's Avatar
Re: Daverods 52
well hopefully your oil pressure will be good, I'm sure it will be. keep us posted. also nice to have someone there to help you with break in, 4 eyes are better than two. I like to hook up a vacum gauge to help see what engine is really doing.
Old 06-29-2012, 01:49 PM   #787
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Still need to hook up the vac. lines to my carb. not sure about that yet. holley550 street avenger. Fire started up were I was working they wont let me back up there so I have the day off.
Old 06-30-2012, 11:26 AM   #788
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Found a good pic of how the heater stuff use to work. Had some leakage were the fuel rail hooked up to the carb. The guys at auto## were a big help. Said I needed more tape and some gas resistant o rings. Funny thing is I knew they were full of it and I still bought and tried the o rings.The carb was missing the fuel inlet fitting. Ordered what I needed. Could just mcgiver it for now.
Old 07-01-2012, 04:52 PM   #789
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
classic.. Tried to start my engine thought I saw some fire. Stopped looked around abit. Tried again heard a bang and smelt like electrial burning. I ran to the engine to see where the noise was coming from I could'nt see anything but I could hear and smell it.Ran around looking for more light the noise was getting louder and louder I was in a panic I could believe how loud it was. Turned out I never grounded the engine I was using jumper cables to ground it before and I took them off. It grounded to my air hose.
Old 07-01-2012, 09:11 PM   #790
Strodder
Strodder's Avatar
Re: Daverods 52
DOH!!!!!
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 07-01-2012, 09:57 PM   #791
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
ya i thought i had a big fire and my harness was burning up. Did turn it over a few got some smoke out the carb.
Old 07-02-2012, 09:11 PM   #792
99 to Life
99 to Life's Avatar
Re: Daverods 52
dave,
wow yeah good you didn't blow your fuse box, do you run a fusible link between your starter and your pwr wire to your box, would be wise to.
also if you are getting smoke out of your carb and or flames, you could be 180 out, meaning it is firing on no.6. just take out plug no. 1 turn engine over with finger over spark plug hole till you feel air push your finger off. then make sure your line on your balancer is right around zero on your timing tab, before would be ideal. then check your distributor and make sure your rotor is pointing to number one plug. Your vac advance should be pointing towards no two cylinder at that point.
You should either unplug your dist power wire and or all power and do it by hand, or if you crank it over, def just unplug your dist power wire. def helps to have someone help you. more eyes the better. can't wait to see this thing on the road. i luv it
Old 07-19-2012, 02:03 PM   #793
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
pulled my plugs had some water in a couple holes,cant be good
Old 07-19-2012, 02:07 PM   #794
99 to Life
99 to Life's Avatar
Re: Daverods 52
def not good, who put the heads on? I'd retorque them and see if that doesn't help. Odds are you will have to put new gaskets in and make sure you put sealant on your head bolts. Assuming this never got water down the intake by any chance.
Old 07-19-2012, 02:12 PM   #795
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
I'll try the retorque thang. Yes I put the heads on. I think ill pull the bolt the put some sealer on it too. My other engine does have better heads.
Old 07-19-2012, 02:14 PM   #796
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
I did install a nice grounding strap. Turns over nice
Old 07-20-2012, 12:16 PM   #797
99 to Life
99 to Life's Avatar
Re: Daverods 52
dave, yeah def gotta have sealer on them bolts, also now that that gasket has been wet and not seated properly, it might be warped, but I'd def try that, let the engine set for a day if you put sealer on it and torque, then come in and retorqe, cause the bolts will relax. Then I'd try rolling it over without spark and then check every cylinder.
Old 07-25-2012, 02:25 PM   #798
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
stripped a head bolt wtf.
Old 07-25-2012, 02:28 PM   #799
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Took the antifreeze out dont know if I should take the engine out or not..hmm
Old 07-25-2012, 02:31 PM   #800
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
I looked at the threads on the bolt you could hardly see any of the rtv sealer on it at all i used the red stuff. I think I only put it around about ten threads or so.about a 1/4" Ill bet my other engine is the same way.
