Old 05-17-2017, 07:51 AM   #776
Mator
Mator's Avatar
Re: How about some pics of Static Dropped C-10's
Originally Posted by 66clow View Post
Awesome before after photos. Looks like I have about 4 inches between the axle and frame with 5 inch springs only. So not sure if that is enough clearance with 2 inch blocks or not. Also I have 20's with 40 series tires. Your fender gap looks about the same. You might not have 5 in springs.
I have 3 inch's at the frame and about 29 to the bottom of the wheel well on 5 inch springs. Sorry the picts are bad dang phone sucks at picts.
I am glad they don't look underneath at shows. Mine is a driver and gets as many miles as I can on the weekends.
Mator is offline   Reply With Quote
Old 05-17-2017, 08:18 AM   #777
66clow
66clow's Avatar
thanks for the info. I may be ok then with just blocks. I already have about 1 inch spacers on which are from my old shock brackets I put in there. Lol Once I take those out and put in the blocks I should be good. Now I'll need to get rid of this c notch kit I bought. Glad I don't have to do any cutting.
66clow is offline   Reply With Quote
Old 05-17-2017, 08:33 AM   #778
66clow
66clow's Avatar
Uh oh spoke too soon. I just measured mine with a tape measure, I only have 2 inches now. With blocks I'll have about a half inch. Mator sure you have 5 inch springs?
Old 05-17-2017, 09:02 AM   #779
Mator
Mator's Avatar
That's what I ordered but I never checked them. Just installed them. Are you sure you have 5 inch springs? LOL. My springs are 9 inch's compressed and installed roughly with the bed on. I measured that last night. Not easy to pull that but close enough for comparison.
Old 05-17-2017, 09:21 AM   #780
66clow
66clow's Avatar
Lol, I'm pretty sure they are. I bought a 3 5 drop kit. One of us got the wrong spring lol. I will measure my springs installed when I get home. I would hope they are considering how close the axle is to the frame. I always thought I needed a c notch with a 7 inch drop. A friend of mine has smaller wheels with a 7 drop and he has about a half in clearance. But he is driving it like that lol.
Old 05-17-2017, 04:59 PM   #781
66clow
66clow's Avatar
I just checked my springs and they measure 7 inches compressed. You may have 3 inch springs if your at 9. Don't think my bed would weight that much more.
Old 05-18-2017, 07:58 AM   #782
Mator
Mator's Avatar
Well crap, you cant trust anyone. This is my first C10 I have ever lowered or built so I didn't even question what they sent me. Being it was almost 3 years ago I am not even sure who I bought them from anymore. I will double check my spring measurement again.
I am hoping to install mid length headers and then look at lowering more and will have to address it then. For now it sits the way its is . I like the stance now and I cant do much about complaining, I guess I should checked what was shipped better. Lesson learned the hard way.
Old 05-18-2017, 10:38 AM   #783
knomadd
knomadd's Avatar
I've read (can't remember where since it's been so long ago) that there are different heights being sold as the same drop by different manufacturers. It would be like brand X selling a 5" drop spring that sits a bit higher than a brand Y spring. So just because you have a 5" drop spring, it's not necessarily going to be the same as the other guy's 5" drop spring.
Also, keep in mind that suspension settles over time, so a 5" drop spring that's been installed for a few years will be lower than a brand new 5" drop spring from the same company. It could be one manufacturer says the spring is a 5" drop when it's brand new (ultimately ending up with more drop) or the other guys say their spring is a 5" drop after the suspension settles in (starts out less than 5").
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 05-18-2017, 10:44 AM   #784
Mator
Mator's Avatar
Good point thank you.
Old 05-18-2017, 10:59 AM   #785
hewittca
hewittca's Avatar
*edit* I posted a question but saw that it was answered a few posts above. I am in for the discussion, however, because I am interested in the measurements you guys are taking. I've been trying to find references for rear to frame, and spring compression measurements with drop springs. Thanks!
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 05-18-2017, 11:51 AM   #786
ct67_72
ct67_72's Avatar
Me too. Been trying to figure out what is in mine and cant find good reference.
Dan.
Drivetrain parts and accessories.
68 medium green shortbed fleetside
ct67_72 is offline   Reply With Quote
Old 05-18-2017, 02:24 PM   #787
Custom.Chevy
Custom.Chevy's Avatar
From the very little experience i have with designing my own custom suspension and doing research 4" of up travel is basically all any road going vehicle typically has. 4" is an industry standard basically. As long as your springs are the correct Spring Rate for your application and your shocks are good you should never bottom out with 4" of up travel. That being said i believe the diff will hit the bed floor before the axle hits the frame with the bump stop cut off. So watch out.
instagram - @custom.chevy
Custom.Chevy is offline   Reply With Quote
Old 06-13-2017, 08:05 PM   #788
TCCGRIZ
Re: static drop pics
Originally Posted by 2500HD View Post
here is mine.
Nice ,I like it
TCCGRIZ is offline   Reply With Quote
Old 11-07-2017, 07:36 PM   #789
ghalperin
ghalperin's Avatar
4 1/2 front and 6 3/4 rear
Front suspension:
Early Classic Enterprises 2 ˝” Drop Disc Brake Spindles
Early Classic Enterprises 2” Drop Springs
‘68 Chevy C10 Sway Bar, Energy Suspension Urethane Bushings
Moog Bushings, Ball Joints and Steering Linkage.
AGR Power Steering Gear Box
Bilstein Monotube Shocks
Frame and Chassis:
Stripped Bare and Painted Epoxy Satin Black
POL Trailing Arm Crossmember with adjustable mounts for pinion angle setting.
CPP C-notch kit
Rear Suspension:
’72 Chevy C10 12 Bolt Rear End 2:76 gears.
CPP 5” drop springs
CPP 1 1/2” drop blocks
CPP adjustable track bar
Stitch welded trailing arms
Energy Suspension urethane trailing arm bushings
Z28 rear sway bar
Wheels and Tires:
’72 Chevy 15x6 stock steel wheels
Hanook Optimo H724 Whitewall P215/75R15 tires
'68 Chevrolet car stainless COPO hub caps
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
ghalperin is offline   Reply With Quote
Old 11-07-2017, 08:14 PM   #790
ghalperin
ghalperin's Avatar
Before
Glenn
Old 11-07-2017, 09:08 PM   #791
gringoloco
A guy with a truck
gringoloco's Avatar
Attachment 1705652
Front suspension:
Frame and Chassis:
CPP C-notch kit
Rear Suspension:
CPP 5” drop springs
Z28 rear sway bar
Wheels and Tires:
Well done, sir. She’s a looker! What did you do to get the color to pop?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-07-2017, 10:20 PM   #792
ghalperin
ghalperin's Avatar
All I did was polish, polish and then polish it again. It probably hadn’t ever seen wax, before me.
Glenn
Old 11-08-2017, 09:07 AM   #793
RDrancher
RDrancher's Avatar
Very nicely done Glenn!
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 11-08-2017, 10:43 PM   #794
ghalperin
ghalperin's Avatar
Thanks, but not done yet...
Glenn
Old 02-16-2018, 08:35 AM   #795
jkk
jkk's Avatar
5/7 Spindles springs / flip kit hangers
jkk is offline   Reply With Quote
Old 02-16-2018, 08:49 AM   #796
gringoloco
A guy with a truck
gringoloco's Avatar
Very nice truck!
-Chris
Old 03-11-2018, 12:01 PM   #797
77GMCTruck
JKK that truck is awesome!
77GMCTruck is offline   Reply With Quote
Old 03-11-2018, 12:22 PM   #798
66clow
66clow's Avatar
5 7 drop
Old 03-20-2018, 10:47 PM   #799
todds66
Originally Posted by mikes61 View Post
Heres my static 72 custom/10
I'm looking at an old post of the 72, can you share the size and backspacing of the wheels and also tire size. Awesome look and perfect stance
1966 Custom Cab SWB SBW Fleetside
1968 C10 BBW SWB Fleetside
todds66 is offline   Reply With Quote
Old 03-20-2018, 11:33 PM   #800
todds66
5 7 drop
awesome truck. Can you please share the size rims, tires and backspacing? Love to duplicate this look on my 68
