View Poll Results: Exotic wood bed or skinned smooth?
Wood? 164 78.10%
Metal? 46 21.90%
Voters: 210. You may not vote on this poll
Old 02-28-2015, 11:19 PM   #776
Brannon yazell
Brannon yazell's Avatar
Re: Wild C10 project
I bought some custom motor mounts from Speedway but they end up leaving an 1/8" for my steering linkage. So we decided to build them to work with the factory 01' mounts. They only sell kits to do the opposite of what I'm doing, nobody puts an old motor in a newer frame...so here's the template
Brannon yazell is offline   Reply With Quote
Old 02-28-2015, 11:21 PM   #777
Brannon yazell
Bolt holes to bolt up to the 400, threaded holes to bolt to the existing mount.
Old 02-28-2015, 11:23 PM   #778
Brannon yazell
Bolted to motor
Old 02-28-2015, 11:24 PM   #779
Brannon yazell
Old 02-28-2015, 11:26 PM   #780
Brannon yazell
Old 02-28-2015, 11:28 PM   #781
Brannon yazell
Old 02-28-2015, 11:30 PM   #782
Brannon yazell
Smile Re: Wild C10 project
Old 02-28-2015, 11:56 PM   #783
19GM71
19GM71's Avatar
In this last pic, am I seeing some kind of heat shield or is it just a cover up for the mounts?
This build is really cool and I enjoy following along.
19GM71 is offline   Reply With Quote
Old 03-01-2015, 12:27 AM   #784
jeffalbritton
You are correct, there is a heat shield on the factory 2001 motor mounts.
jeffalbritton is offline   Reply With Quote
Old 03-02-2015, 09:37 AM   #785
Brannon yazell
Lowered the motor mounts by 1".
Old 03-02-2015, 09:38 AM   #786
Brannon yazell
Old 03-02-2015, 09:39 AM   #787
Brannon yazell
Old 03-02-2015, 09:40 AM   #788
Brannon yazell
Motor set in frame
Old 03-02-2015, 09:41 AM   #789
Brannon yazell
Ready to begin the trans crossmember and mount.
Old 03-02-2015, 10:34 AM   #790
FRANKENSTEINC10
FRANKENSTEINC10's Avatar
This build ranks in my top 3 for my time on the forum! Looks great keep it up!!
FRANKENSTEINC10 is offline   Reply With Quote
Old 03-02-2015, 10:54 AM   #791
Brannon yazell
Wow, glad you think so. We will keep up the hard work and pics coming. I plan to leave no part of this truck untouched or custom in some way.
Old 03-02-2015, 11:43 AM   #792
FRANKENSTEINC10
Sweet!
Old 03-03-2015, 07:56 AM   #793
19GM71
19GM71's Avatar
Old 03-03-2015, 09:14 PM   #794
Brannon yazell
Start of the trans crossmember
Old 03-03-2015, 09:15 PM   #795
Brannon yazell
Access hole for bolts
Old 03-03-2015, 09:17 PM   #796
Brannon yazell
Notche's cut for exhaust
Old 03-03-2015, 09:18 PM   #797
Brannon yazell
Positioned
Old 03-03-2015, 09:19 PM   #798
Brannon yazell
Just needs plating and metal finished
Old 03-04-2015, 09:32 PM   #799
19GM71
19GM71's Avatar
I assume the trans crossmember will be removable. It looks right at home with the other metal work. Again, awesome work!!!
Old 03-05-2015, 12:36 AM   #800
jeffalbritton
Yes sir... It will definitely bolt in. Hopefully I can finish it up tomorrow and get some pics of it all bolted in.
bagged, c10, ls1, shaved, swap
