Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 02-13-2019, 12:43 AM   #776
First c10
First c10's Avatar
Re: Project 68 k10 LWB..aka "The Hulk"
I have been working late the past few days but am close to having the wiring done.
Received my new battery today. Optima blue top. Now need to run the custom cables to the starter and alternator and an under hood distribution block.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 02-26-2019, 02:00 AM   #777
First c10
First c10's Avatar
Was able to get the 1/0 pure copper cables made up. I added a 200amp breaker under the cab next to the battery box. It reads waterproof. Not like I am going to be driving this in the rain. I still have to mount a distribution block for the under hood power, like alternator, cab power, Headlight relays, etc.
Also my upholstery guy picked up my dash pad to make a custom cover.
Can’t wait to get it so I can finish the dash.
GO GO!!!
Old 02-26-2019, 09:12 PM   #778
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Please explain the last picture. Is that the distribution block?
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 02-26-2019, 09:30 PM   #779
renegade6
It will be interesting to see how the breaker works. I've heard that there almost isn't one large enough to put on the main lead.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 02-27-2019, 12:54 AM   #780
First c10
First c10's Avatar
Ok so I am sorry this was not described correctly.
This is a tee (if you will) to the starter. The one running towards the camera will go to an actual distribution block.
I hope this makes sense.
GO GO!!!
Old 02-27-2019, 12:59 AM   #781
First c10
First c10's Avatar
Dude! You are so right. I frigged up and put in the wrong place. I was supposed to put that after the starter. Damn! Now how to remedy it.
This is what happens when you plan something years earlier and forget how it was supposed to be installed.
What to do.... Make new cable???? Install a very large breaker?????
GO GO!!!
Old 02-27-2019, 11:12 AM   #782
derotoreut
derotoreut's Avatar
Sounds like your wiring is going to have to change. That sucks. Good luck with it and post your pictures. Keep up the good work.
~ Dan
Old 02-27-2019, 12:33 PM   #783
swamp rat
swamp rat's Avatar
Did you solder the cable ends to the cable and use shrink wrap?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-27-2019, 12:46 PM   #784
First c10
First c10's Avatar
Hey Mike, I used a Copper terminal, a Hydraulic crimper and heat shrink.
I think I am going to get a 500 amp ignition breaker so I don't have to make new cables.
GO GO!!!
Old 02-28-2019, 12:33 AM   #785
First c10
First c10's Avatar
Decided to get the under hood wiring routed and just think about the battery cable for now.
So had to install the radiator support and driver side wheel well.
I ran the wires from the bulkhead on the firewall down towards the steering column and down under the cowl back up to the void between the internefder and the outer fender.
GO GO!!!
Old 02-28-2019, 12:39 AM   #786
First c10
First c10's Avatar
Started string out the small groups of wires I sorted when I modded the stock harness.
I have been using molex connectors so I can just disconnect stuff if need be.
GO GO!!!
Old 03-02-2019, 02:49 AM   #787
First c10
First c10's Avatar
I started working on installing the ECM so I can finish the wiring to try and get this thing started. I need some motivation.
I used 1/8” aluminum plate to mount the under hood fuse block and ecm. I mounted the TCM relay and headlight relays behind the plate.
To mount the ECM I taped the holes on the housing of all he ECM. Not sure I have seen anyone do this. It should be fine.
I also recessed the fuse panel.
GO GO!!!
Old 03-02-2019, 12:42 PM   #788
derotoreut
derotoreut's Avatar
Nice idea. Should make for a clean install. You weren't interested in putting them under the seat or inside somewhere?
~ Dan
Old 03-02-2019, 01:14 PM   #789
First c10
First c10's Avatar
Since I would have to extend every wire in the harness or purchase a new harness I decided to keep the ECM under the hood like factory but tucked down low.
The ECM is designed to be in the elements and since I don’t plan on abusing the truck in water mud etc. I figured it would be fine. My other swap I did 7 years ago is running like a champ and it’s nothing as nice as this truck will be. It was a driver.
GO GO!!!
Old 03-03-2019, 01:48 PM   #790
First c10
First c10's Avatar
Started to button up the wiring to the ECM and connect to the truck under hood wiring. I will probably have to extend the wiring to the TCM so I can mount next to the ECM.
First thing was to get the passenger wiring to the passenger side so I ran the wires under the radiator. Head light, park and turn signal wires, a/c clutch, and ECM a/c wires.
Next was to install the radiator hopefully for the last time.
Then to connect the cab wiring.... breaker, alternator wire, and headlight relays etc.
Next I will have to run my cooling fan wires to the fans. But I have a Power Probe III coming today So I can test out all the circuits before running main power to everything. (Nice to have a brother in law as a Snap-On dealer).
Last photos are of the ground straps I made and installed under the passenger side cab mount. I also ran as set on the passenger side frame to radiator support and driver side cab mount. I will be installing a 4 gauge ground from frame to engine block.
GO GO!!!
Old 03-05-2019, 01:28 AM   #791
First c10
First c10's Avatar
Today I wanted to mount the TCM. I am thinking of mounting it under the engine cover behind the the throttle body. For now I zip tied it to the fuel rail. I will make a mount if I keep it there. If I do I won’t have about 20+ More wires running to the area of the ECM(lower front driver Fenderwell)
I decided to connect the power and use my new power probe 3RZ to test all the circuits man that thing is awesome. I have to say I am veryhappy so far not one problem. Fans, fuel pump, lights, dash etc. radio and ac fan all A ok..?? Next is to get the laptop and program the ECM.
GO GO!!!
Old 03-11-2019, 01:10 PM   #792
First c10
First c10's Avatar
Been working on a few little things until my dash pad got delivered after getting upholstered. Saddle color in leather with cream stitching.
Picture is with it sitting in place. Need to get different mounting screws for the 4 locations on the interior side mounting areas.
Once this is installed I can run the ac ducts and get the instrument cluster installed. Then is time to paint the column, glove box door, and ash tray.
GO GO!!!
Old 03-12-2019, 12:57 AM   #793
First c10
First c10's Avatar
Got the dash pad installed. I didn’t want to see the screws so I found some covers. I think it looks good.
GO GO!!!
Old 03-12-2019, 01:08 AM   #794
First c10
First c10's Avatar
Now that the dash pad is on it was time to get the headlight switch back in and finish the dash.
The speaker is in, duct work is in so decided to put he new Dakota digital dash together. I plugged it in and turned it on bingo. Worked great.
Looks good and now I need to finish the upper radiator hose and I think it’s about ready to start.
GO GO!!!
Old 03-17-2019, 03:24 AM   #795
First c10
First c10's Avatar
Well I tried to start the truck and it wouldn't start. Traced it to the injectors not firing. Come to find out it was the “starter fault diagnostics” under “OS” tab in the tune that needs to be “disabled”. After that she fired right up and purred like a kitten. Even though I put a cam in it. It’s started right up and idled great. I noticed the check engine light was on. Went to push on the pedal and nothing happened. Checked the code Found code p2138 pedal reference.
First picture the code.
Seconds was the pigtail I bought that has all the wires white. WTH.
Third and forth are how the wires are laid out in the plug
I grabbed the test kit and I traced the wires all the way back to the ECM everything was good. Not sure what to check.
But as I write this I am looking at the pictures of the plug with the f _ _ _ _ A
I look at it closer and notice I think I wired it from the top down A-F which is backwards.
So tomorrow I am going to switch it. I wish the pintail plug was color coded or at least had the letters stamped on it.
GO GO!!!
Old 03-17-2019, 03:38 AM   #796
First c10
First c10's Avatar
Ok so after I disabled the last of the vats stuff. Here is the first start up video for the hulk. Ran great and can’t wait to fix the pedal issue.
Hulk first start up video
GO GO!!!
Old 03-17-2019, 10:29 AM   #797
landarts
landarts
Great job on the truck, love the heavy duty wiring and the dash pad. Can't wait to see the finished project.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 03-17-2019, 05:17 PM   #798
derotoreut
derotoreut's Avatar
Congrats on the first start! That's a huge milestone. You must feel good about it. Keep it going.
~ Dan
Old 03-17-2019, 08:57 PM   #799
First c10
First c10's Avatar
Thanks guys. I feel great. Now I have to get the pedal wiring corrected and I am pretty confident it will work.
Then it’s upper radiator hose or piping as I am going to do it in STainless.
But it’s honeydos today. Back on it tomorrow!
Old 03-19-2019, 10:49 AM   #800
First c10
First c10's Avatar
So a quick fix of the DBW pedal wiring. Since I built most of the truck with connectors I just repinned the molex connector since I had wired A thru F when it should have been F thru A.
Short video of it.
I still see the CEL on so not sure what that is. Will check tonight.
2nd start up!
Now to work on the upper radiator hose.
GO GO!!!
