Old 04-16-2012, 11:57 PM   #801
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Finally starting my Longhorn 4x4 conversion
Originally Posted by 1985-GMC View Post
Lookin good! Wide power coated white steelies and caps for sure!
Thanks. I'll probably use these ford wheels for now unless I get a smoking deal on some 16x10 aluminum wheels.
Originally Posted by mcbassin View Post
Nice work Ryan! Keep up the hard work. You'll be driving this beast in no time.
Thanks, there is still a lot left to do. I have to figure out how I'm going to get my turbos in there with a stock a/c housing yet too.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-17-2012, 12:07 AM   #802
chevy71super
You might want to consider going with a Vintage Air unit, it eliminates the large AC unit under the hood. Creates a ton of room. Doug
71 Cheyenne Super 4X4 SB
72 Cheyenne Super 4X4 SB
72 Cheyenne 4X4 SB
chevy71super is offline   Reply With Quote
Old 04-17-2012, 01:00 AM   #803
Dieselwrencher
Not happening on this project as I need that for my 40 Ford and the funds are let's say dry. The 40 will get vintage air before this unit.
Ryan
Old 04-17-2012, 01:21 AM   #804
watahyahknow
watahyahknow's Avatar
sumtimes there are small multihookup units like the vintage air to be found in wrecked limo's where they regulate the cool air for the rear passengers it shouldnt be to hard to adapt the controlls for those to work with the standard chevy stuff either maibe look for that and use the stock compressor
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 04-17-2012, 06:27 AM   #805
Rodzzilla
Looking good! Kurt is good peoples.
Rodzzilla is offline   Reply With Quote
Old 04-17-2012, 07:59 AM   #806
ryanroo
ryanroo's Avatar
Originally Posted by Dieselwrencher View Post
Starting engine remock up. The engine and trans are resting on the Ryanroo approved mocking cross member. The engine still needs to brought up about 2* and it'll be pretty close. NV4500 in, now to get the tcase on and see what's up.
that one is nice. way more class than the stack of crap i have.
lookin good
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 04-17-2012, 10:37 AM   #807
mknittle
mknittle's Avatar
Where do I find a wrecked Limo?
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 04-17-2012, 10:43 AM   #808
mknittle
mknittle's Avatar
I have a heater/AC unit from a kenworth sleeper that I am going to use for my 52 gmc. I may just use it for parts. If that won't work I will go to pick and pull and do some shopping.There aer some small cars that have to have some good parts.
Mark
My GMC build.
Old 04-17-2012, 12:02 PM   #809
watahyahknow
i dunno im not from the states i figure there some yards that might have one or two i believe theres a website where you can search them online , there more places to find those small units like in the rear of ambulances just look beyond the row of chevies in the yard
Old 04-17-2012, 02:58 PM   #810
Dieselwrencher
I think I have a way to get both of them in there. My biggest concern is getting 4" or 5" exhaust through the frame and missing the trans and drive shaft. I'm guessing it'll have to go on the out side of the frame and cross back over before the RH saddle tank. We'll see if I ever get some more time to waste on it.
Ryan
Old 04-17-2012, 05:52 PM   #811
watahyahknow
there a couple of places that sell oval pipe straight and bended length or width wize and oval to round adapters if you can get a 3 inch pipe in there you could prolly fit that in there too
http://www.spintechmufflers.com/tubi...ng/cat_41.html
Old 04-17-2012, 10:22 PM   #812
ryanroo
ryanroo's Avatar
ive been worrying about that exhaust routing myself. ive also been inactively looking for a ford d60 for the front in hopes that i can miss the issue entirely.
Ryan
72 K20 12v build
Old 04-17-2012, 10:37 PM   #813
mosesburb
I had a V-8
mosesburb's Avatar
You *might* get a 4" pipe between the frame and transfer case, fuggidabout trying to put a fiver through there. Do you have any body lift on it?? One inch would get a four through for sure with good floor clearance, might be enough for a five, not sure though. I wanted to put a one inch in mine a few times, but came up with solutions for the problems in other ways, but I could have set the motor a little higher and got a bit more up-travel, then again, I was only putting a 3.5" through there too.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 04-17-2012, 11:36 PM   #814
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
It's a tight fit to get a 4" thru that hole, I tried on mine but only had 1/4" clearance around it and that didn't sit well with me but my engine sits higher than most put them. I ended up jogging outside the frame all the way back (no saddle tank). The hole was already in my inner fender so no big deal. You could loop it over the frame and under the bed to get it back in the center.
Also, the only thing I didn't take a pic of before I came back to cali was my exhaust. My bad.
But it does look good, makes me want to get back to the midwest and drive mine (and paint it as nice as yours looks!)
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 04-17-2012, 11:41 PM   #815
woodwright
Enjoying left field
woodwright's Avatar
Ryan, are you needing AC? or just a heater unit?
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 04-18-2012, 10:12 AM   #816
mknittle
mknittle's Avatar
Here are some pics!
Seat and carpet setting in there to get out of the way for the most part.
Removed the rear stock shackle bracket and tried installing the DIY4X flip kit. It wouldn't work due to the hanger difference in the 73-87 hangers. I thought I could make it work but no such luck. It almost sits level right now. I spoke with Kurt today and he is going to swap me out for the correct hangers. Can't beat that.
That's all the weekend allowed for on this truck.
Looking good Ryan, ! It motovates me to get going.
I like the custom rear cross member in the fourth pictire.
That reminds me The inspector is comming tomorrow {The garbage man}He is building a 67.He always spends about 20 minutes here.I better get somthing done today
Mark
My GMC build.
Old 04-18-2012, 03:28 PM   #817
Dieselwrencher
Yeah, on my brother's 88 V30 3" was the max on that baby. I knew this RH drive shaft was going to bite me, but I'll deal with it.
Ryan
Old 04-18-2012, 03:29 PM   #818
Dieselwrencher
Ryan
Ryan, make sure you get the 78-79 earlier style. It isn't super wide like the later ones and will bolt right in.
Ryan
Old 04-18-2012, 03:32 PM   #819
Dieselwrencher
Be on the look out for that white F-350 on base. That's my little bro. He'll be leaving Thursday for his month long leave though.
I'm thinking right now the out side the frame routing will be the way to go. We'll see what it looks like with a 241DHD in there though. I want to use the 205 because I know it'll bolt right on and so will my tcase shifter. But I know in the back f my mind, the skinny pedal is getting mashed once in a while. That being said, there may be a 40k sled behind it and I don't want to be searching for 205 parts or cases again.
And thatnks on the paint. If I ever get far enough, I'll throw the front clip on and take some pics. My poor running hood.
Ryan
Old 04-18-2012, 03:34 PM   #820
Dieselwrencher
Well, I have all the inside parts and the outer housing. I'm going to have to locate the other stuff. Like the heat valve, orifice tube or what ever they use, condenser, and I'll have new lines made. I'm unsure of what compressor I'm going to run at this point as well.
Ryan
Old 04-18-2012, 03:36 PM   #821
Dieselwrencher
Thanks, it might be good for one hard bounce.
Ryan
Old 04-18-2012, 07:49 PM   #822
woodwright
Enjoying left field
woodwright's Avatar
What I was getting at, is if you are not gonna need AC, you can adapt a 70s or 80s chevy non-AC truck heater. the outer air box is pretty small.
Clint
Old 04-18-2012, 09:34 PM   #823
ryanroo
ryanroo's Avatar
yeah, thats the reason i dont already have it. they are a little more scarce. i keep my eyes peeled though.
you really worried about the 205 sploding? ive seen far more blown up aluminum cased transfers than 205s. in fact ive never actually seen the case damaged. ive seen alot of funny other stuff blow. you are just worried about chasing down spare 29 sp cases? i think with a little time i could make a stiffener plate for the 205 case.
i am also wondering about the 47re pan to driveline clearance. i think it may be a little tight
ryan
72 K20 12v build
Old 04-18-2012, 09:56 PM   #824
6lcummins
ryan
For the hard to find part of it, but when you make over 500HP the gear to gear wont hold the 1000lb ft of torque very well. NP241DHDs hold well over 1800lb ft and are easier to find.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 04-18-2012, 10:29 PM   #825
Dieselwrencher
What he said.
I've broken inputs and outputs with a divorced 205 truck I had. Then I put a 29sp in it and did it again. Then I purchased the pro fab billet parts and broke those. No warranty and no money back from that deal so yeah I'm nervous of 205's with diesel power.
Ryan
