Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 07-17-2013, 08:48 AM   #801
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Re: Boyd Welding-67-72 Rear Mount Aluminum Tank
Originally Posted by Daveboyd View Post
Sorry we don't carry the regulators. The side fill is intended to fit between the frame and bed. There are no notches required.
Great.
Thanks for the info.
I will order today
chevyguy_72 is offline   Reply With Quote
Old 07-17-2013, 09:29 AM   #802
chevyguy_72
Vintage Evil
I placed my order today.
Thanks for all the Q&A
I am looking forward to it coming
Old 07-17-2013, 10:08 AM   #803
67c10rustbuket
67c10rustbuket's Avatar
Dave, I had to notch my frame rail for the filler neck to clear. The tank is mounted directly to the bottom of the frame. Did you guys change this or did I get a tank with a short neck? There is no way my tank filler neck would clear the frame. I can take some measurements when I get home later if that helps. Here are a few pics to show what I had to do. The notch plate is trimmed and welded in now but dont have a pic with the tank back in it. I am not complaining here, I love the tank but it was quite a surprise to find the filler neck would not clear. This is on my 67 C10 swb.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 07-17-2013, 10:09 AM   #804
67c10rustbuket
Pics only load one at a time...
Pic #2
Dan <---(my name)
Old 07-17-2013, 10:10 AM   #805
67c10rustbuket
pic #3 - the notch.
EFI stealth, side fill is the tank version.
Dan <---(my name)
Old 07-17-2013, 01:01 PM   #806
EZ SPEED
EZ SPEED's Avatar
Tank ordered !!!!
Eric
1967 C10 Small Window - LWB http://67-72chevytrucks.com/vboard/s...d.php?t=657509
2004 Silverado 2500HD - Turbo Diesel 603 rwhp / 1090 rwtq
2016 Camaro SS - Satin Pearl Nero wrap
My 2010 Camaro SS Magazine feature (SOLD)
http://www.superchevy.com/features/g...of-perfection/
EZ SPEED is offline   Reply With Quote
Old 07-17-2013, 02:06 PM   #807
Gus350
68 C 10
Gus350's Avatar
Just placed a order with Travis for a center fill.
Thanks Kevin
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 07-17-2013, 06:25 PM   #808
hozeman469
Got one on order...Thanks for the group buy
hozeman469 is offline   Reply With Quote
Old 07-17-2013, 11:44 PM   #809
mtnbikeman
Tank ordered! Thanks Dave!
mtnbikeman is offline   Reply With Quote
Old 07-18-2013, 12:29 AM   #810
kpc01
Dave, dont forget to add the a1000 bed fill to the listing on your site to make it an option
kpc01 is offline   Reply With Quote
Old 07-18-2013, 12:41 AM   #811
VA72C10
VA72C10
VA72C10's Avatar
It's on the site now...
http://www.boydwelding.com/shop/inde...7-72-c-10.html
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 07-18-2013, 08:42 AM   #812
Daveboyd
Daveboyd's Avatar
Thanks for showing me this. Every once and a while we run across someone with a frame that requires a notch and i cannot for the life of me figure out why. At one point in time we had an issue with the necks not being built to the proper height consistently so we made a fixture to ensure every neck is the same.
If you refer to Page 30 post #730 you will see this frame accepted the side fill without any issues.
If you look at Page 28 post #682 you will see this frame would not accept it on the bottom of the frame rail. He also noted that his frame was a 4x4
Is your frame a 4x4?
Dave Boyd
View Our 63-72 C10 Tank options https://fueltankparts.com/collections/63-72-c10-tanks
Boyd Welding Main Site : http://www.boydwelding.com/
Boyd Online Shop: https://fueltankparts.com/
E: Sales@boydwelding.com
Daveboyd is offline   Reply With Quote
Old 07-18-2013, 09:03 AM   #813
kpc01
Originally Posted by VA72C10 View Post
weird, for some reason I only see the A1000 in a bed fill? I only see 5 items listed. Can anyone else confirm they see it?
Old 07-18-2013, 10:03 AM   #814
67c10rustbuket
The A1000 pic is bed fill but when you click add to cart you have the option to choose side fill or bed fill
Dan <---(my name)
Old 07-18-2013, 10:10 AM   #815
kpc01
great thanks! I guess I didn't dig deep enough!
Old 07-18-2013, 10:18 AM   #816
67c10rustbuket
Details from your website:
Details
Frequently Asked Questions:
Q: How Far down are the mounting tabs?
A: 3" down from the top of the tank
Q: How Tall is the fill neck? What is the Diameter of the pipe?
A: The fill neck is approx 3" tall. The pipe is 2" OD
Q: Are there Baffles in the Tank?
A: Yes, There are 3 baffles in the tank.
Q: What is the Roll Over Safety Vent? Do i need it?
A: The Rollover Safety Vent is a simple ball check valve device that will allow the tank to vent when in the normal operating position. In the event of an accident causing a rollover the ball will drop and block off the vent port so that fuel does not leak out. For safety I would always recommend purchasing the Rollover Safety vent option.
Thanks Dave, I see post 730 looks like it is higher than mine, post 682 is a local guy "Crash" and I follow his build. His truck was originally a long bed and cut down to SWB so that may be part of the reason, thinking the frame is taller as it goes forward toward the cab? I think maybe a cab swap also. A lot of unknowns there and of course there were many variations in these trucks.
My truck has matching Vin/Spid/partial frame Vin. It is an original 67 SWB V8 283 3ott.
I measured the frame rail where the tank attaches and it measure 4.25"
The tank flange mount surface to top of tank 3" (just as your specs above show)
The filler neck (bottom) is 1" from the top of tank, the filler neck top is 3" above the top of the tank.
Tank mounting 3" + filler bottom height 1"= 4" where the frame is 4.25" so the bottom edge of the filler neck is .25" below the top of the frame rail. I decided I needed .75" notch to give clearance for the filler hose.
Dan <---(my name)
Old 07-18-2013, 01:17 PM   #817
Daveboyd
Daveboyd's Avatar
thanks for providing support. I think (Bed Fill) in the title was a little misleading so i just deleted them from the title.
Dave Boyd
Old 07-18-2013, 08:52 PM   #818
kpc01
thanks, just ordered!
Old 07-18-2013, 11:46 PM   #819
lchall
Thanks! Just placed my order.
1967 Chevy SWB
1972 Chevy SWB
1972 Chevy SWB K20 4x4
1991 Ford F-150
2013 Dodge Ram 1500 4x4
lchall is offline   Reply With Quote
Old 07-19-2013, 12:50 AM   #820
VA72C10
VA72C10
VA72C10's Avatar
Ordered one...sending a pm with some last minute detail questions. thanks
Old 07-19-2013, 01:37 AM   #821
Tuffy66
Tank Ordered...Thanks Dave for doing the Group Buy!
Tuffy66 is offline   Reply With Quote
Old 07-19-2013, 08:59 AM   #822
Daveboyd
Daveboyd's Avatar
Today is the LAST DAY to save money on these tanks.
Dave Boyd
Old 07-19-2013, 10:50 AM   #823
Daveboyd
Daveboyd's Avatar
i had a couple people ask what the silver looks like. This tank just came back from powder coat this morning.
Dave Boyd
Old 07-20-2013, 06:23 PM   #824
Sammy
Ordered through the group Buy on Monday, Friday it arrived. Standard bed fill with rollover vent and sending unit. Nice clean well made product was very easy to install after removing the small diagonal brace. Nice to see a good product without creating additional hiccups.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 07-20-2013, 10:15 PM   #825
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
I received my UPS notification yesterday, it'll be here Tuesday.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
67-72 truck, aluminum tank, boydwelding.com, fuel tank, tank relocation
