Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 12-21-2020, 12:29 AM   #801
russellrox
Re: D52 Caliper Rear Disc Brake Brackets
Do you make rear disk brake brackets for a 10 bolt camaro diff?
russellrox is offline   Reply With Quote
Old 12-21-2020, 10:54 PM   #802
Captainfab
60-66 Nut
Sorry, no I do not. All 6 of the rear disc conversion brackets I make are designed for the '64-'82 truck 12 bolt and '79-'87 truck 10 bolts.
Old 01-14-2021, 03:18 PM   #803
LeadfootLambert
Does anyone know where I can get the Powerstop AR8622XPR Astro rotors? Nobody seems to have them in stock. These are cross drilled and slotted
LeadfootLambert is offline   Reply With Quote
Old 05-12-2021, 07:03 PM   #804
LeadfootLambert
Has anyone had problems with the outer brake pad center lower edge rubbing on the brake rotor?
Old 05-12-2021, 10:45 PM   #805
Captainfab
60-66 Nut
Yes that has happened several times over the years that I have been fabricating these due to manufacturing tolerances with the aftermarket rotors. The Astro/Safari rotors did not come from the factory with D52 calipers/pads. I have revised the caliper brackets 5 times and I can not move them out any more or the pads will be past the outer edge of the rotors. That is not good either. I assume others have just ground/sanded the pads for clearance.
Old 06-27-2021, 08:24 PM   #806
Captainfab
60-66 Nut
Due to an increase in the cost of having my parts laser cut, I have been forced to raise my prices. I'm not making any more money, just trying to stay in business with these increases in my costs. Thanks for understanding.
Old 09-11-2021, 07:53 PM   #807
rawraw67
rawraw67's Avatar
I want to order a set of your c10 rear disc brackets for my 1977.
rawraw67 is offline   Reply With Quote
Old 09-11-2021, 10:12 PM   #808
Captainfab
60-66 Nut
PM sent........
Old 09-12-2021, 06:00 PM   #809
rawraw67
rawraw67's Avatar
I sent a message but I dont think it went through sent my email
Old 09-12-2021, 10:46 PM   #810
Captainfab
60-66 Nut
I received 2 PM's from you. The first had no reply from you. I replied to the second PM from you. I work 80hrs/7 days a week every week every month and I only have time to be here on the forum once a day after I am done working for the day. If you require a quicker reply, please send me an email to the address given in post #1 of every one of my for sale threads. I answer all emails multiple times a day.
Old 12-30-2021, 10:51 AM   #811
MDFarms
Do you have any kits for K10 and be able to keep E-Brake?
MDFarms is offline   Reply With Quote
Old 12-30-2021, 10:32 PM   #812
Captainfab
60-66 Nut
Yes I do and have been fabricating them for over 7 years. Here is the for sale thread for them. I fabricate over 26 products for the '60-'72 GM trucks.
http://www.67-72chevytrucks.com/vboa...d.php?t=637489
Old 03-17-2022, 07:15 PM   #813
Captainfab
60-66 Nut
Here is a link to my new website and online store where you can see and purchase all of the products that I fabricate for the '60-'72 GM trucks.
https://customfab-cda.com
Old 03-18-2022, 12:38 PM   #814
Joemomma1
Joemomma1's Avatar
about damn time
Joemomma1 is offline   Reply With Quote
Old 03-21-2022, 09:57 PM   #815
Captainfab
60-66 Nut
If it wasn't for my wife, it would never have gotten done.
Originally Posted by Joemomma1 View Post
about damn time
