Old 10-11-2013, 12:55 PM   #801
knomadd
knomadd's Avatar
Re: 1977 Chevy C10 known as SharkBite
Originally Posted by 77ChevySharkBite View Post
Were not seeing eye to eye on that
For the throttle cable bracket that's what I'm actually going to buy, what I'm going to try and attempt to make is a custom kick down/return spring bracket to have the return spring at the back instead of the front that does that make sense?
Maybe one of us is missing something. Could very well be me since I'm out of genius today.
Both of the brackets at advance and oreilly's have the kick down bracket already. OH OH OH!!! It just clicked... you're talking about the mounting point on the throttle lever attached to the carb, right? What does your connector on the end of your kick down cable look like?
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 10-11-2013, 12:58 PM   #802
77ChevySharkBite
77ChevySharkBite's Avatar
uh oh!! were onto something now
Because my genius ran out last night we'll use your picture from above as reference the piece I'm talking about is where your kick down cable is, so yes I'm talking about the mounting point, and my my kick down cable looks identical to yours. let me see if I can find a picture of it.
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 10-11-2013, 01:01 PM   #803
77ChevySharkBite
Here's the best picture I can get of how the stock set up was. The 2nd on might be better though there's a little interference from the Air Cleaner looks to be a better picture.
Korwin
Old 10-11-2013, 01:18 PM   #804
knomadd
knomadd's Avatar
did you ever figure out how you were going to attach either one to your carb? are they bolted to the quadrajet? It looks like it but I'm not for sure. And I'm guessing the stock bracket isn't wide enough for the edelbrock. Is that true?
-Duane
Old 10-11-2013, 01:24 PM   #805
77ChevySharkBite
Yeah the throttle linkage was bolted down with like a clip, but with the new one it's just bolted down. The kick down was held with a bolt too but the way I can use it on the new one is just a screw just a little bit longer and tighten I'll be fine. Everything is simple and done for the most part my biggest "hump" was trying to figure out the throttle cable "bind" it might be hard to see but the best picture is the 2nd one look towards the firewall you can see the cable kind of do like a little hump when I tried using the stock bracket and new intake it just binded it more because like we talked earlier it's 1" further back than the q-jet/intake manifold was.
the stock bracket works but like we talked with it being further back it kind of "crunches/binds" up the throttle linkage coming from the firewall it'll work. I mean I could always try to trim off some more of the throttle cable bracket try to push it up some maybe make up that 1" difference could work that way but I'm unsure.
Korwin
Old 10-11-2013, 01:47 PM   #806
knomadd
knomadd's Avatar
I see. You've got more length than I do. I don't think there's any adjustment in the factory throttle cable to shorten it. If the mount point is back an inch, you'll probably want to go ahead and get a new bracket like we've been talking about. That might solve your problem all together. Edelbrock makes a mount part #8036, search for some pics to see how it looks when it's assembled. It looks like it moves your cables near the valve cover, which might fix the binding problem by putting more of an "s" in it compared to now.
-Duane
Old 10-11-2013, 02:08 PM   #807
77ChevySharkBite
Yeah I'm looking at it now, it looks kind of goofy honestly
Here's the link at jegs.com that show it together but I just don't see how it could benefit the throttle cause in the description it says about cruise and kick down bracket. I think I'm going to attempt to get a throttle bracket like we've been talking and see if that solves it. Like you said there's no way to physically shorter the linkage without buying a new one or coming up with something.
http://www.jegs.com/i/Edelbrock/350/8036/10002/-1
Korwin
Old 10-11-2013, 02:15 PM   #808
77ChevySharkBite
Check this out Duane, looks like somone used it but on a camaro so not sure if I would be able to use it cause I still have to have clearance for my brake booster pipe and stuff that plugs into the back of the carb.
http://www.nastyz28.com/forum/showthread.php?t=159867
Korwin
Old 10-11-2013, 04:04 PM   #809
knomadd
knomadd's Avatar
Either bracket you use should be fine for the vacuum line from the back of the carb to the booster. You might need a new vacuum hose to get around the bracket if it currently runs through the space the bracket would occupy, but otherwise it shouldn't be a problem. It's up to you which one you want to use. It looks like mine is like the Mr. Gasket part found at Oreilly's, so there isn't a return spring mounting location on it. you could bend a piece of metal to accept the spring and bolt your fabbed spring bracket in one of the threaded holes in the back drivers side of the intake manifold. You'll just need to figure out how to connect the spring to the carb (eyelet we talked about earlier).
-Duane
Old 10-11-2013, 04:07 PM   #810
77ChevySharkBite
Thanks for all the help today Duane, I can't say thank you enough! I think I'm going to try your bracket and go from there and see what I can do about getting the spring set up correctly.
I'll keep everyone posted.
Korwin
Old 10-11-2013, 04:25 PM   #811
knomadd
knomadd's Avatar
Do you realize we went through 2 pages today? I hope after all of that you find something that works. Good luck!
-Duane
Old 10-11-2013, 04:28 PM   #812
77ChevySharkBite
Yeah if I don't find nothing that works that's 2 pages of nothing but talking
I imagine that when I go get that throttle bracket like yours it's going to solve everything and I'll just have to figure out how to run the spring, so until then I will probably go buy the part this weekend and see about getting it working and getting that baby cranked over!
Korwin
Old 10-11-2013, 06:35 PM   #813
67 c10 guy
67 c10 guy's Avatar
According to your last post you said "if I don't find nothing that works" means you might find something that will work. You used a double negative bro. Lol
I still think the solution to your problem is a shorter throttle cable
as for the kickdown I don't know.
67 C10 longbed 350/th350
13 Ford Fusion 2.0T daily
67 lwb build sold
67 c10 guy is offline   Reply With Quote
Old 10-15-2013, 08:21 PM   #814
knomadd
knomadd's Avatar
Hey Korwin, did you ever get the throttle cable figured out? If not, check out this thread I just found on Ginger, LoLife99's build from a while back. On page 4, last pic in post #87 has a picture of the lokar throttle cable and throttle cable bracket with the return spring connection I was trying to help you figure out.
Ginger
-Duane
Old 10-16-2013, 10:27 AM   #815
77ChevySharkBite
Ginger
Ahh I see thanks knomadd!! that's actually a really slick looking set up I like it a lot.
Korwin
Old 10-19-2013, 08:15 PM   #816
77ChevySharkBite
Well it looks like new throttle cable it'll have to be. Here's the pictures from today
Korwin
Old 10-19-2013, 08:17 PM   #817
77ChevySharkBite
But on the bright side I went to the junkyard today and sometime maybe this week for about $250 I'll have a new core support, front bumper, rear bumper brackets, and bed!
Korwin
Old 10-19-2013, 09:57 PM   #818
Claytona08
Claytona08's Avatar
Hey man, glad to see you making some progress!
http://67-72chevytrucks.com/vboard/s...d.php?t=580955
http://youtu.be/JYoQJYTXKqI
1984 Chevrolet Scottsdale C10 "Project Platinum C10"
1971 Chevrolet Chevelle "Project Car"
Claytona08 is offline   Reply With Quote
Old 10-19-2013, 10:56 PM   #819
77ChevySharkBite
Thanks man, yeah the carb intake has been rough but trying to stay positive about it getting a new throttle linkage tomorrow then I should be up and running so fingers crossed tomorrow it cranks.
Korwin
Old 10-20-2013, 02:26 PM   #820
77ChevySharkBite
I think I have found the solution a shorter cable!
Korwin
Old 10-20-2013, 07:27 PM   #821
jpnh
jpnh's Avatar
Good score-jeff
jpnh is offline   Reply With Quote
Old 10-20-2013, 07:31 PM   #822
77ChevySharkBite
Originally Posted by jpnh View Post
Good score-jeff
Yeah I´m happy about it man just ready to get it going.
Korwin
Old 10-21-2013, 03:30 AM   #823
chevybuilder18
chevybuilder18's Avatar
looks like your going to be doing some more sanding and painting
well looks like this problem hasnt gone away, fingers crossed here too.
sorry i havent been on lately to see your progress, damn phone company shut the internet off.. but im gonna to be on more now than ever
Her name is Quicksilver
1978 Chevrolet silverado, shortbox stepside currently being swapped IN is a LM7 5300 vortec, 4l80E, factory 4.11s, slammed, a dream ride and coined QUICKSILVER
gotta pay $$ if you wanna play
chevybuilder18 is offline   Reply With Quote
Old 10-21-2013, 08:31 AM   #824
77ChevySharkBite
Yeah my favorite thing in the world sanding and painting! Ahhhhh......the joys of restoring a truck on a semi budget
Yeah it seems to have fixed the problem, I just have to plug up something close to the pedal some black piece I'm not sure where it plugs to do just because my friend had taken it off initially so not sure exactly where it's located.
It's all good man, yeah things happen trust me glad your back!
Korwin
Old 10-21-2013, 08:36 AM   #825
77ChevySharkBite
Now another order of business as long as money looks right.....I have a deadline to meet now.
I'm being very hopeful about this so bare with me guys, this weekend is the yearly Air Show here in Houston, last year the truck was supposed to be there well it didn't make it this year we're really going to try and make it. Also there's a truck show down in the Clear Lake area that night as well.
So if you haven't figured out my deadline it's to have the truck in running and driving condition by Saturday morning/noonish to make it to the Air Show and Truck Show that night. Now I have one great thing on my side as long as is sticks I will have this Friday completely off. Which means I can have a full day dedicated to the truck which also means taking a visit to the junkyard and spend the day pulling parts to get it ready. If everything goes smoothly I will have the truck all buttoned up and running without a grille by Saturday. Oh also have to do a semi paint job on it too, the bed I'm looking at getting is black so going to do just a simple matte black on the cab of the truck
So fellas lets have a little faith in me wish me well!
Korwin
