Old 05-24-2024, 02:24 PM   #801
6DoF
6DoF's Avatar
Re: Project: Tow-Rat (Lil' Blue)
it's a cummins ... it'll forever mark it's spot
6DoF is offline   Reply With Quote
Old 05-28-2024, 07:46 AM   #802
6DoF
6DoF's Avatar
turbo drain seal fixed, no leak. the stupid o-ring wasn't thick enough for the groove they put in the part. i just cut a new paper gasket from a roll i had, left the oring, and tightened her back up. guess that worked.
catch can had an internal filter that was restrictive, ditched that. i also forgot to put the steel wool de-mister in the can, so added that. then added 2 more breathers off my 2 oil caps in the front of the engine, no more breather oil. just the front main and rear main leaking oil
added some firewall insulation, as you could imagine that was getting uncomfortably hot inside with the hot pipe basically touching. the wrap does a lot, but not quite that much. it's just warm now, so huge game on.
Old 05-28-2024, 07:57 AM   #803
6DoF
6DoF's Avatar
the wife had a dream recently that i had 3D printed mounts for a Bluetooth speaker under the dash. she woke up and ordered me this little Bose unit. no way i wasn't going to then print mounts for it! so far no latch of any kind, just cradles it. the rubber like body seams to keep it from moving at all.
with a mount, seamed like a great place to put and hide my "AFC Live" fuel control. should work just like the production version from Power Driven Diesel, but was like 10x cheaper. one bypass valve, an orifice valve to slow the boost signal to the injection pump, and one pressure regulator to set max boost the pump sees. allows you to set the springs and screws in the pump for max power, then dial it back for no smoke and smoother daily driving. or if lazy, have the screws n springs set wrong, and dial in appropriate fueling. in my case, i need to keep the power in check as i should have enough turbo and fuel capacity to yeet the head gasket before i shift gears.
Old 05-28-2024, 08:00 AM   #804
6DoF
6DoF's Avatar
finally the wife got bored and decided to see why i kept talking about washing the truck with CLR and a soft scotchbright pad. so far, so good! she wants to go over it again with the CLR, and i need to order some patina sauce ASAP.
a fair bit of brown reduction, not sure if it worked more or less than i was expecting haha. the nicest part is everything getting a TON smoother after the rub down. but now it almost looks weird with less blotch blue.
Old 05-28-2024, 08:26 AM   #805
6DoF
6DoF's Avatar
Friday night i got out to the first cruise, had an absolute blast talking to everyone. no one really knew what it make of it! there was a huge parking lot behind where i'm taking the picture, i was "late" and in the overflow. ended up with a few rows of cars in the grass yet that evening.
Goal Achieved! grass shut in the door
Old 05-28-2024, 09:49 AM   #806
youngrodder
youngrodder's Avatar
Looks like your having fun with it. Sometimes showing up fashionably late to a show/cruise yields the best parking spots. By then they quit policing it quite as bad and you can dump it any ware.
My son knows the drill. A) Find a sweet spot. B) Pull in dump, it on the ground. C) Walk away (casually). Come back later. By then there will be no one there to ask you to move it.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 06-12-2024, 08:40 AM   #807
6DoF
6DoF's Avatar
this is such crap ... bottom of my driveway we needed fixed, Monday a week and a half ago they did demo but no pour yet! the '55 has been stuck at the house! it's 1-2weeks cure before i can drive that heavy thing on it too.
hard to tell in the picture, but it's a huge hill. where i'm standing for the pic is like 65feet above the cul-de-sac. it's also a shared driveway full concrete below my gravel t's in, and the grass on either side of my gravel is 2 different neighbors. we had a little old concrete in the corner to the gravel, but made the whole corner wider with gravel. the 2 tires on different surfaces would murder a modern traction control. now it'll be all concrete for the first 60-80ft before gravel. the fully concrete shared section was badly broken in one place by a cement truck during the build for my house, so also fixing it. there's a 2 slab long, 3ft wide, 8" deep hole that the neighbors have to drive around now in the other neighbors yard ...
uuuggggghhhhhhh
Old 06-12-2024, 08:58 AM   #808
6DoF
6DoF's Avatar
it's like having an umbrella! not 10min later now and they showed up to confirm measurements, will start 6am tomorrow morning. game on.
Old 06-12-2024, 10:17 AM   #809
youngrodder
Hopefully you get freedom soon...
Marc
