Old 11-26-2011, 08:42 PM   #826
rfmaster
rfmaster's Avatar
Re: Tbi swap build thread
Originally Posted by dju91001 View Post
I was under the impression due to an anti theft program or something in the ecm. If not, great! It should work. The rest of the drivetrain is 73-74 blazer with turbo 350. I know about the vss, the park neutral switch, and the detent cable. Going to use the caprice fuel cell with pump unit and lines. The schematics are all similar, so i've found. The cab and bed are 70 c10, just dropped onto a blazer chassis. Thanks
Yes, the 92 'may' have VATS anti-theft system. Check ECM I/O connector pin B6 which is input from VATS module. Two ways to get around it. First is to burn a new EPROM that disables this function. Requires some cash outlays for EPROM PCBA adapter, EPROM (or FLASH memory chip) and burning equipment or knowing someone to do it for you. Second approach is to build a 30 Hz pulse generator to provide 50% duty cycle pulse signal to pin B6. Once ECM sees this pulse signal during cranking it enables fuel injector driver circuits. Alternatively, find 1227747 ECM from 305 truck and use it as is - trucks did not have VATS system. The 7747 ECM will plug into Caprice harness and will work fine. I presume that you are going to omit AIR pump - it is only used during cold starts and later trucks did not have AIR system.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 11-27-2011, 08:54 PM   #827
dju91001
Thanks. I better save myself some time/trouble and go ahead and obtain the 7747.
dju91001 is offline   Reply With Quote
Old 12-11-2011, 09:06 PM   #828
65Guy
Finally got mine running. cranked on the first try! Any way i i found a 4l60e how would i wire it to work with my comp? i dont have the number with me but i know it is from a 90 4.3 truck but my 350 runs fine with it stock.
65Guy is offline   Reply With Quote
Old 12-11-2011, 09:37 PM   #829
BigBlocksRule
That '90 model tranny is a 700R4, the 4L60E didn't appear until 1993.
Kudos on getting it running!
BigBlocksRule is offline   Reply With Quote
Old 12-12-2011, 05:23 PM   #830
68 TT
Still plays with trucks
68 TT's Avatar
Are you running your 350 with a 4.3 ECM? If so it should be reprogrammed for the right injector size & engine displacement. It is probably dangerously lean as is.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-13-2011, 05:14 PM   #831
65Guy
well i havent had the exhaust done yet but it seams to run good. but who knows.
Old 12-13-2011, 05:19 PM   #832
rfmaster
rfmaster's Avatar
Just post the contents of the part number label attached to ECM cover - this should tell us the ECM family and calibration type. If it is missing remove the EPROM cover held down with two screws and note the four letter code on EPROM chip.
//RF
"The Beast"
Old 12-13-2011, 05:25 PM   #833
65Guy
16144288 atkn
Old 12-13-2011, 07:08 PM   #834
rfmaster
rfmaster's Avatar
16144288 atkn
BCC: ATKN
Year 1990
PROM Size 32724
ECM #16144288
Program ID: 160 ($A0)
Product Line: C1/K1/P1
Engine: LB4 4.3L
Transmission MD8 AUTO (700R4)
This ECM was specifically developed for V6 application. ECM will run V8, but limp mode will not work and calibration is off for a typical V8. However, you can modify VE and SA tables together with larger injectors. As is good enough to start your motor, but as for driving - very iffy.
//RF
"The Beast"
Old 12-13-2011, 07:57 PM   #835
68 TT
68 TT's Avatar
Originally Posted by rfmaster View Post
BCC: ATKN
Year 1990
PROM Size 32724
ECM #16144288
Engine: LB4 4.3L
//RF
The 1227747 ECM's are so common you should be able to find a 5.7 OD auto version pretty easily and save yourself a bunch of time & effort.
Old 12-15-2011, 08:46 AM   #836
MalibuSSwagon
Hey gand, great thread, really helps me in my journey. I am currently working on a TPI swap for my 86 C10.
I am fairly certain I have the VSS figured out. Could someone confirm or deny. I was feeling around on the back of the cluster and felt a square hole right behind the speedo, seems that is where the optical VSS sensor mounts. Would this be true?
If so, how do I remove the cluster without breaking it? That was my biggest fear, as I am well aware how fragile this old GM plastic is!
MalibuSSwagon is offline   Reply With Quote
Old 12-16-2011, 12:14 AM   #837
68 TT
68 TT's Avatar
That is where the optical VSS goes. The only sure way to not break off the left hand tab is to pull the dash pad. The rest of the cluster housing is pretty tough.
Old 12-16-2011, 11:12 AM   #838
MalibuSSwagon
ok cool. I have already pulled the pad so I'll give it another try today
Old 12-16-2011, 05:27 PM   #839
MalibuSSwagon
You guys rock. Saved me $75 on a JTR sensor.
There it is, the speed sensor hole.
Installed an 80's Malibu VSS I had lying around. Perfect.
The four wires coming off the VSS, My guesses are:
Brown - 2k signal to ECU
Blk/wht - ground
Pink/blk - Hot in run/start
Yellow - 2k signal to cruise
Yes or no? There isn't much info on retrofitting an optical VSS.
Old 12-29-2011, 11:56 PM   #840
camaney
suscribe
camaney is offline   Reply With Quote
Old 01-02-2012, 03:48 PM   #841
65Guy
ok i decided on the nv3500. So my question is do i need a drac to make my vss work or can i wire the tailshaft mounted vss right to the ecm?
Old 01-02-2012, 04:16 PM   #842
rfmaster
rfmaster's Avatar
I did a bit of search on this subject since I have never dealt with NV3500 trany. From what I could find the NV3500 employes a 40 pulse VSS (per shaft revolution), so that you'll have to sue a DRAC or Dakota digital buffer module to arrive to 2000 ppm signal that TBI ECM (aka 1227747) is expecting.
The Dokota Digital converter module is a Swiss army knife equivalent of GM DRAC minus the PITA. This module is pricy, but time and effort may justify the initial cost. Check their website SGI-5 Universal Signal Interface Unit.
//RF
"The Beast"
Old 01-02-2012, 04:40 PM   #843
65Guy
ok, also i have a question about dynamic efi. I have browzed there web site how hard is it to learn how to use.
Old 01-02-2012, 07:28 PM   #844
rfmaster
rfmaster's Avatar
It is a lot easier than trying to burn own chips. There is a main thread (as well as several smaller threads) on thirdgen.org that deals with EBL user questions. Unless you have a fire breathing monster of a camshaft+engine EBL can handle.
I run EBL on all my conversions - see youtube videos. The key to TBI is selecting camshaft that provides about 14-16 in-Hg at idle and steady idle. After market camshaft with LSA of 112deg and higher with up to 214deg at 0.050 will do the trick. Tighter LSA (<112deg) results in lumpy idle which screws up MAP sensor readings and ECM will over fuel the engine. Long duration camshafts >220 deg also create havoc for O2 sensors at idle. Our trucks need low end torque, and high RPM HP is never really needed in a street truck. What we need is flat torque from 1500 to about 4500 RPM to get the weight going (and keep it going). A good RV cam will do this trick without creating problems for TBI system - for example CS1014R (flat tappet).
//RF
"The Beast"
Old 01-02-2012, 07:35 PM   #845
beamn7
Great thread guys! Looking to TBI my 85 here in the near future....
beamn7 is offline   Reply With Quote
Old 01-09-2012, 11:33 PM   #846
lahnen
looking to do a tbi swap to my 86 k30 dump. i got a 89 c2500 that used to be my dd. i plan on pulling the motor, wiring and all relays/sensors from under the hood, and computer soon. is there anything else that i will need from the donar truck. also am i gonna have to replace the 86 wiring under the dash or will i be able just to put power to the computer to run all engine componets.
lahnen is offline   Reply With Quote
Old 01-12-2012, 11:15 PM   #847
65Guy
Im redoing my wiring on the 65 tbi, i would like some pictures of the swap done on 60-66 trucks please.
Old 01-12-2012, 11:38 PM   #848
rfmaster
rfmaster's Avatar
One of the key components is VSS. Depending on the donor vehicle VSS can be PITA. Do you have donor identified? Also, you do not have to replace any of the under dash wiring - EFI is a standalone system and is adapted to your 86 harness - fuse box.
//RF
"The Beast"
Old 01-13-2012, 09:15 AM   #849
Low Elco
A guy a few posts back asked about 700r4/4l60 integration. What's involved? I have an 87 sb, 350tbi/350 and of course I want the od. Any info on what might be involved? Really kinda thinking of getting a 94/95 computer and running tbi/4l60 like I had in my 95. Is this easy? A pipe dream? Anyone done it? I have 2 90 2wd burbs in a yard not far away that are still fairly complete with electronic speed outputs for the 700's. My 87 t350 is a cable. Will the tailshafts swap? Can I just put a later cluster in my truck? Sorry for all the questions, but I've been wondering. Thanks, Chip.
Low Elco is offline   Reply With Quote
Old 01-13-2012, 12:03 PM   #850
rfmaster
rfmaster's Avatar
Hey Chip
The 93-95 PCM's are (were for their day) advanced powertrain computers and much more powerful than C3 ECM found in 87-92 C/K's. The PCM can control TBI and 4L60E/80E as well as 700R4. It can also be used with manual gear boxes - all of this requires modifying EPROM. This is a long discussion (PCM mods) and better be done else where. There is a lot of information available - TGO, moates and elsewhere.
Regarding Spedo. This is where it gets a bit tricky since 93-95 used electronic speedometers. The VSS produces 40 pulse per shaft revolution which gets passed to DRAC module. DRAC module has three outputs which feed into anti lock brake system computer, cruise control and PCM.
To swap into 87 I would look into converting 4L60E VSS from electronic to mechanical drive with addition of inline VSS module to drive the PCM (assuming that there is no cruise control). This swap would require removal of reluctor ring pressed onto tail shaft and installation of drive gear to drive driven gear. You'll also need speedometer gear housing. For more info see link below.
http://www.transmissioncenter.net/sp...n_______va.htm
//RF
"The Beast"
