Old 07-03-2015, 02:05 PM   #826
aotte1
Re: Intro from an old Assembly Plant guy
Keith,
Have answer to one of the questions, via trial - added module and it works.
"Keith,
Thanks for the brace location on the engine/ bell housing. Follow-up question, will they work on my replacement 350 block, e.g. Are the motor mount in same position from rear of block on a 350, as on a 4.3? Also, do you know what force they are counteracting? E.g. Engine torque rotation or stronger engine/bell housing connection.
Intermittent Wiper Function
One other question, I am changing out the steering column from standard to a tilt one on my 1986' C10, as part of my interior R/R. The tilt column has the intermittent wiper function, however, original did not. To make the intermittent function work, on the tilt column, is it correct thinking, that I need to add only the "intermittent" module to the wiper wiring harness that come out the lower part of the column, and then plug original dash wire harness into module?
Thanks,
Les
The intermittent wiper (IW) module was all that I needed to add to standard wiper (Hi-Lo-Pulse) dash wire harness to make the new column with IWs work. Got the module from my Chevy dealer parts department. These modules were used for many years. Got a new one because they are known to go bad, for some reason.
Connected the wiper wire harness from the lower part of the steering column to one side of module and connected the other side of module to the existing wiper plug from dash wire harness. Very easy.
Les
aotte1 is offline   Reply With Quote
Old 07-06-2015, 09:10 AM   #827
Keith Seymore
Keith Seymore's Avatar
Les - not sure on the mount location (anecdotally the V6 is just a V8 with the front two cylinders lopped off, which would imply the mounts are in the same location from the rear face of the block).
The braces are to counteract a powertrain "beaming" mode, and provide more support across that engine/bell housing interface.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-06-2015, 09:16 AM   #828
Keith Seymore
We did something a little different this year for the 4th of July:
Our local Pontiac club participates in one of the nearby 4th of July parades. By definition, then, I usually bring one of the old Ponchos but this year I thought it might be fun to bring the pickup and let the kids ride along in the back.
They seemed to enjoy it, plus I was parading in air conditioned comfort.
The last pic was pretty much everyone's response to seeing the little red truck in the parade.
K
1979-1986
1986 - 2019
Old 07-06-2015, 02:16 PM   #829
Motor City GMC
Hey keith/neighbor down the road..lol
Just figured i would share a pic with ya of the newly painted truck, incase ya seen it around town youd know who it was lol
Motor City GMC is offline   Reply With Quote
Old 07-06-2015, 02:55 PM   #830
Keith Seymore
Looks great; duly noted...
1979-1986
1986 - 2019
Old 07-13-2015, 12:03 PM   #831
Keith Seymore
Peter Frampton and Cheap Trick last night at the venue formerly known as Pine Knob.
I slept with the bedroom window open and got a free concert...
K
1979-1986
1986 - 2019
Old 07-14-2015, 02:07 AM   #832
aotte1
LMC door panels question?
Just got mine from LMC and the original chrome door handle insert do not fit as molded. Especially in the door handle area. Did yours fit or did you have to remove some of the material near where the door handle comes through? If removing material does it effect the fastener screws? Your pictures look like screws are correct on yours.
Did read earlier post from around 2010, on LMC door panels.
Thanks,
Les
Old 07-15-2015, 04:29 PM   #833
aotte1
Keith ,
Found instructions in bottom of shipping box on how to modify panel, to accommodate bezels.
Thanks,
Les
Old 07-15-2015, 05:30 PM   #834
Keith Seymore
Keith ,
Thanks,
Les
Excellent. Sorry for my delay in posting; I don't recall having to do anything specific to install my bezels (but I could be forgetting).
K
1979-1986
1986 - 2019
Old 07-24-2015, 07:48 AM   #835
Keith Seymore
GM Tech Center Employee car show this past Wednesday.
No brakes on the Grand Prix so Red had to do show duty, too.
Made sense, anyway, since I had to do a Home Depot run on the way home. I wouldn't have been able to do that with one of the Pontiacs...
K
1979-1986
1986 - 2019
Old 07-25-2015, 03:07 PM   #836
Hankster
Hankster's Avatar
Man that sure is a pretty truck!
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 09-21-2015, 07:31 AM   #837
Keith Seymore
Am I a bad person for going to the races and only taking pictures of pickup trucks in the parking lot?
(lol)
I went to the Pure Stock Muscle Car Drags in Stanton Michigan as a spectator on Friday. http://www.psmcdr.com/
The photos below are what I saw when I came back out.
It’s an ’85 GMC out of Flint (VIN FF717xxx); beautiful paint, probably a fresh restore, including rhino liner in the bed, cowl hood. P255/70 tires.
Could stand to drop down a couple inches…
K
1979-1986
1986 - 2019
Old 09-21-2015, 07:41 AM   #838
J Knight
J Knight's Avatar
Did you talk him into a mild drop like yours?
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 09-21-2015, 07:51 AM   #839
Keith Seymore
No, we didn't connect.
I would have liked to visit with him; I probably put the fenders on that truck (50/50 chance that it came through on second shift).
K
1979-1986
1986 - 2019
Old 09-21-2015, 08:23 AM   #840
J Knight
J Knight's Avatar
My 82 is a Flint built truck also.
John
Old 09-21-2015, 07:17 PM   #841
TravisMartin
Curmudgeon of Poor Means
Call me weird; I like 'em stock height...it's a pickup! Only thing I'd fault it for in the picture is the roll pan...I like bumpers too!
TravisMartin is offline   Reply With Quote
Old 09-22-2015, 03:08 PM   #842
oakstcustomz
oakstcustomz's Avatar
Hey Keith, great read! I have read about all of your threads here and py, my dad has a 64 GTO we have had since 89 when I was born he had a 68 lemans my grandpa bought new, and another 68 lemans vert.....loved the story's about John Z and the kid on the bike!! He worked with a guy who was a factory line builder for Chevrolet cars I believe and he told him that most employees would order a car as a stripper and secretly build the luxury options as they followed it down the line....
1965 Chevy C-20 slammed 292 L6 TH400
1967 Chevy C-20 on 91 suburban frame project(wife's)
1972 Chevy K-20 Mild 350/th350/np2o5 dd
1952 Ford Customline 2door kustom project
1967 Cadillac Superior Hearse (wife's)
1998 GMC Saffari (wife's dd)
oakstcustomz is offline   Reply With Quote
Old 09-23-2015, 10:09 PM   #843
harrisoncole4
harrisoncole4's Avatar
Very cool story!
harrisoncole4 is offline   Reply With Quote
Old 09-24-2015, 12:46 AM   #844
86454k30
86454k30's Avatar
I bet I have read your build thread 3 or 4 times since it began. Thank you for all the GM truck history you provide and excellent job on your truck.
86454k30 is offline   Reply With Quote
Old 09-29-2015, 07:14 AM   #845
Keith Seymore
Someone has a birthday!
29 years ago today.
Went in to the plant at 4:30pm and it was just coming down out of paint and into the Trim area.
Followed it all the way through the process and left the plant at 1 am Tuesday morning.
K
Originally Posted by Keith Seymore View Post
The invoice shows the truck being invoiced and shipped on 9/29/86. This is pretty consistent with my literature, which shows the warranty information taking place on October 2nd, 1986. Pulling up an old calendar reveals that 9/29 was a Monday, which sounds familar. I seem to recall working during the day Monday and then going in Monday evening to follow it down the line. Apparently it was documented as being shipped on Monday even though I know it was not physically moved until Tuesday during the day.
1979-1986
1986 - 2019
Old 09-29-2015, 08:08 AM   #846
J Knight
J Knight's Avatar
So it takes 8 1/2 hours to complete assembly?
John
Old 09-29-2015, 08:21 AM   #847
Keith Seymore
From that stage of completion, yes (depending on any other downtime, rolling breaks, etc).
The cab/box would have started probably a day or two ahead of that, in order to be completely welded up and through the paint process where I started with it.
I must have had the build sequence number so that I could track it down. I wish now I had kept all that stuff (build manifest, inspection tickets and such).
K
1979-1986
1986 - 2019
Old 11-04-2015, 08:09 AM   #848
Keith Seymore
Well....I have news.
I sold the red truck.
It all happened kinda fast.
My friend/engine builder had a really nice truck that I have been lusting after for many years. It's an 04 Chevy, crew cab short box, diesel. All set up for pulling trailers, etc. I've had my eye on it for as long as I have known him.
He sent me a text over the weekend that he was (finally!) selling his truck. I originally told him I was not interested but, after agonizing over it all day Sunday I wrote him back saying I would be - IF - my brother in law would be interested in the red truck.
My b-i-l immediately said "yes" so as of this morning I have the check in my pocket and the red truck still in my garage. I think it will probably sit in my garage over the winter and I'll finish up a couple odds and ends that still need to be done.
Looks like a pretty good deal for all those involved.
K
1979-1986
1986 - 2019
Old 11-04-2015, 08:26 AM   #849
Donnie Mabe
Cool story i am installing a my-6 in my '68 long step 2wd it has 98 vortec engine. You think it will be driveable with 4.56 ,holley780,hookers i need ideas for roller cam replacement choice
Donnie Mabe is offline   Reply With Quote
Old 11-04-2015, 08:44 AM   #850
Keith Seymore
4.56 sounds a little steep, but the powertrain should be a good package.
K
1979-1986
1986 - 2019
