01-24-2023, 12:26 AM | #826 | |
Re: What did you do to your truck today??
I just had to run to my wife's work to put an alternator on the S10, so that was a little bit away from my driveway. At least I had that brand new one sitting on my back seat because I still haven't found my dual alternator bracket. And it's warrantied so I'll exchange it tomorrow.
01-26-2023, 10:55 PM | #827 |
The other day I had my air cleaner off to access something behind it. After I reinstalled the air cleaner, the engine barely started and didn't want to idle. I started panicking because I was going to have to admit to a friend who advised against getting a truck with TBI that he was right. On further inspection, I discovered that three of the four retaining clips on the injector connectors were missing. One of the connectors had popped loose. Whew! Spared from admitting he was right until another day! Anyway, this evening I replaced the connector housings with a set I got from a late '80s van at the wrecking yard. It was fairly straightforward to pop the pins out to transfer them over.
01-27-2023, 09:28 AM | #828 |
I had a similar experience. I flushed my coolant system. I had pulled the thermostat, gutted it, and reinstalled before flushing. Mind you, I am unfamiliar yet with the workings of this TBI/EFI system. When I went to start it to help with the flush it only cranked. I had already had two times it failed to start after, or during, rain. This was the morning after a rain, so I put the rotor and cap on I had for that problem. It still only cranked. Shoot, now what? I had power at the pink wire going into the coil but none coming out. So I started a thread asking how this system works, because I knew the ECM was involved somewhere. Before seeing the replies I decided to replace the coil anyway. The coil wire and contact on the coil were very crusty anyway. Still only cranked! Then I decided to fasten those three connectors to the thermostat housing stud. Maybe those wires had some purpose? (It was an oversight) Fired right up!
01-27-2023, 07:58 PM | #829 | |
Moderator
The GM part number on that injector connector is 12102568. AC Delco PT285 is the terminated injector connector pigtail.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
01-28-2023, 03:20 AM | #830 |
Thank you. Those connectors do seem to get pretty crispy over the years. I think the connectors I got from the wrecking yard were replacements because there were splices in the wires. Hopefully they will hold up for a while. The previous owner of my truck broke every plastic component he touched. I have replaced countless connectors and trim pieces at this point.
01-28-2023, 02:58 PM | #831 | |
I went to the junkyard and picked up a non cracked a/c box for the van with resistors and relay, and the wiring harness near it. I also got a seatbelt end for the 93 because it doesn't like to unhook easily. The first one I grabbed was from a bench seat regular cab which has the center seatbelt. The second is from a Suburban with buckets. I was told mine had a bench but the power 60/40 was swapped in. Mine has the bucket seatbelt end, I bought both anyways. $30 for everything.
01-28-2023, 09:07 PM | #832 | |
Moderator
Some folks just have the demolition touch I guess.
01-29-2023, 12:09 AM | #833 | |
Nice scores there, Sean |
01-29-2023, 07:54 AM | #834 |
Bought a grey denali console and sub (as well as its EC rear view mirror)
Tried it out for a few days and decided it was a keeper. Upgraded it with LED lighting cannibalized from the town and country console for the OEM+ look… as well as installed a lightning cable for my CarPlay into the upper section, and wired it so it goes to a single 4pin for power,ground and audio +/- on drivers side, plus usb on right side so it is easy to unplug and remove in the future… like when I get new carpet. I used a 1-2 ft usb extension so the join to the apple cable is accessible by just removing the lid and thus serviceable in the future. Oh and I stripped it down to bare parts, sanded the leather with 400 and 800 grit to get rid of the plasticizer layer, and changed the color to SEM lt neutral to match the Escalade surround and color matched dash. Overall it’s 100 times better than when I pulled it out of the junkyard!
CrewCad
1995 C3500 CCLB DRW W/T 7.4L + 4L80e + Doug Nash overdrive, 22” custom Alcoas, Escalade clip, De Ville tails, shaved handles, Sir Micheals roll pan Last edited by attack eagle; 01-29-2023 at 08:00 AM. |
01-29-2023, 01:21 PM | #835 | |
I finally found the dual alternator bracket I made. I left it bolted to the van. Unfortunately it won't work on the truck because the accessory brackets are different.
01-29-2023, 08:59 PM | #836 | |
The van is together and while running it I found the upper radiator hose leaking. I changed it and saw the thermostat housing leaking. I recently changed the thermostat and it has the rubber gasket which was cut up somehow. So that might be good news for me, that's where the water was going so maybe I won't have to change the head gaskets. I still have to straighten out the wiring and I ordered the steering box seals but I can drive it again.
01-30-2023, 09:08 AM | #837 |
That's good news on the thermostat rubber seal. No bubbles in radiator? I wish I was that lucky. I'm next in line with a blown head gasket. My coolant had come down a couple times last year, like twice in a year. I've been looking for evidence of leaking and not finding any. Never a drip. But it started using it a lot around the holidays. No white smoke and the oil looks normal, but there are bubbles. I can see now between #2 and #4 now at the block is evidence. Time to yank the heads
02-02-2023, 02:50 AM | #838 |
I've been looking and looking for a good set of dash speaker covers with clips, and I finally found some at the wrecking yard this past weekend. The passenger side was missing one of the two clips, so I reattached a clip by melting chunks of a zip tie with a soldering iron. That clip actually feels more solid than the other clips. It's nice to no longer have covers held on with putty.
02-02-2023, 08:17 PM | #839 | |
I would like to just be able to lay my speaker grills in place, but I can't do that until I get the right sized speakers.
After checking out my 99 with the same front seat as my 93, I have determined that the 93 is missing the front center seatbelt. So I went back to the junkyard and got the other side. I don't know why someone would mess with the seatbelts, the rear seat had an incorrect seatbelt end too.
02-02-2023, 08:59 PM | #840 | |
Moderator
I have a set of them in the package tray side supports in my 1984 Rabbit GTI. The dash in the MK II Rabbit will only accept 3.5" speakers so I used the coaxial 2 way Infinity Reference speakers. They're reasonable sounding speakers.
02-03-2023, 01:17 AM | #841 | |
Yea I bought a pair of Sonys for the dash but decided to put them in the rear at the time since they were the difficult ones to do. Then never got another pair.
02-04-2023, 03:46 AM | #842 |
I found a 1991 tach gauge cluster at the wrecking yard that I'm going to put in my '89. I'm following the guidance in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=313815 I opened up the gauge cluster this evening and swapped around the little fuses on the PCB to set my rear end gear ratio and tire size for the speedometer. I also disassembled the odometer and set it to match my current odometer. My plan is to run the tach signal wire through the bulkhead connector on the firewall. I pulled a bulkhead connector from a truck at the wrecking yard this afternoon just to figure out how it's constructed and to harvest a set of contacts from it. Took me a while to figure out that there is a white plastic comb-shaped piece that locks the contacts into place. Everything is covered in black caulking. There was one empty slot in that connector, so hopefully it is the same way in my truck. I also grabbed the gauge cluster connector out of the truck at the wrecking yard so I can use one of its pins for the tach signal. The truck that this tach gauge cluster came out of had the tach wire routed in a big bundle of wires through a firewall bulkhead pass-through (not a connector) on the passenger side. It then passed through a connector behind the glovebox, and then entered another bundle of wires that ran along the dash over to the gauge cluster. Last edited by pjmoreland; 02-04-2023 at 11:49 AM. |
02-04-2023, 07:12 AM | #843 |
Good Find!! Those are hard to come by.
02-04-2023, 07:58 AM | #844 |
laying low
'91 must have been a changeover year for the instrument cluster. My original 91 has the "moonies".
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
02-04-2023, 09:01 AM | #845 |
I ordered the tach in my '92. Then I guess they became standard after that. Must have been in '95 with the new dash. I ordered a few options that within a year or two I was seeing on every truck.
02-04-2023, 11:27 AM | #846 | |
I'm assuming the gauge cluster change in '92 was in preparation for the upcoming change from the 4L60 (700R4) to the 4L60E, which required changing from an ECU to a PCM. Last edited by pjmoreland; 02-04-2023 at 11:52 AM. |
02-04-2023, 12:59 PM | #847 |
That could be. Mine was the late in '92 introduced 6.5TD with an NV4500. Minimum electronics. At first I had to call it a '93 at parts places. It took a few years for listings to show for '92.
That truck took just about 6 months to be delivered. I never got an explanation. I got false alarms at least three times before it actually came. Actually, I knew there would be an extra wait up front, which ended up being about 6wks to start. I got them to give me the fleet color Woodland Green, but had to wait for enough orders for a batch to came in. Ordered in Jan, received in June.
02-04-2023, 04:28 PM | #848 |
PJ/Special-K, I have one each, of those clusters. The '91 cluster differs from the '92-'94 in that the odometer/trip meter on the '91 shows a 6 digit trip meter, whereas the '92-'94 has 7 digits. That's on the cluster face. At the rear, the '91 has a steel backing plate, and the '92-'94 has an open back. Also, the harness interfacing connecters are different. I've included pics of all of this. Sorry for the blurred pics of the odometers. What you CAN do is swap the odo/trip from one to the other simply by removing the cluster face, remove a couple of little screws and unplug the odo/trip motor. The '91 cluster actually hides the tenth of a mile digit. The cluster on the left is '92-'94, the right, '91. So, PJ, if you want to keep the truck mileage original, just take the Moonie odo/trip and swap it into your tach cluster. Even that can be done. Ain't GM grand?
02-04-2023, 04:35 PM | #849 |
I forgot to mention, the '92-'94 speedometer uses an external DRAQ that receives its signal from the VSS. The '91, like the Moonies, has internal circuitry that must be altered for the speedo to read correctly. But I have to assume you knew that going in
02-04-2023, 06:43 PM | #850 | |
That's good to know about the compatibility of the odometers. |
