Old 02-16-2012, 03:03 PM   #851
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: My 68 swb build.
Excellent placement of those lights. They look perfectly at home there. Nice work!!!!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 02-16-2012, 07:25 PM   #852
77chris03
77chris03's Avatar
Originally Posted by nlped View Post
That's gonna look good when finished!!! Good progress!
Originally Posted by LEX View Post
Those taillights are bad arse.
Thanks guys. For all of Yall this is a pain in the rear. Seriously a pain. Plan on starting the other one tonite maybe. Might try to take a break from cutting and welding and do some stuff for the shifter assy and column or door.
68 C10 Stepper #1- GONE 68 C10 Stepper #2
1977 Chevy Cheyenne...gone...was my first Chevy
04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD
99 Sierra Stepside, 17 Denali HD, 84 K10
My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333
My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310
77chris03 is offline   Reply With Quote
Old 02-16-2012, 11:52 PM   #853
77chris03
77chris03's Avatar
just got back and this is what i got done...oh btw, when you go from solid wire to flux core, reverse the polarity on the leads...oh so much better....you can tell by just looking at the pics....
not pictured, i did somewhat get the shifter linkage hooked up...its a little tight but i think it will loosen up over time...need to adjust for the reverse lights...
Old 02-17-2012, 09:10 AM   #854
Slick67
Sofa King Crazy!!
Slick67's Avatar
It looks much cleaner! Are ya gonna fix the little crease in the blue fender before you install the light buckets?
Old 02-17-2012, 01:22 PM   #855
77chris03
77chris03's Avatar
I might if i can get a decent body hammer. If not paint and body can do it
Old 02-18-2012, 10:02 AM   #856
77chris03
77chris03's Avatar
heres what i got done last night...im a little off but filler will make up the difference in the inperfection...
Old 02-18-2012, 10:08 AM   #857
77chris03
77chris03's Avatar
and heres the last few....i didnt have enough sheet metal to replace the hole, so i did what i had to do and pieced it together...phone died so no pic of the weld up...too bad it is ugly.!!!!!
Old 02-18-2012, 11:15 AM   #858
Slick67
Sofa King Crazy!!
Slick67's Avatar
Lot's of work there Chris! It looks cool, very clean layout on those tailights bro!
Old 02-18-2012, 12:24 PM   #859
YBNORML
YBNORML's Avatar
Nice work! They look like they belong there.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 02-19-2012, 11:57 PM   #860
77chris03
77chris03's Avatar
thanks guys...you should see it in person...i think they look better in person. i just wanna get it finished. i was gonna get out there bright and early this morning but decided since Britts dad was over, why not finish the dang kitchen? britt and i painted 3 weeks ago and i told her it needed crown molding and bam....she got it today to finish the room off...heres what it looks like...now all we need to do is get her some natural slate on the floor, granite counter tops and shes set to go on a beautiful custom kitchen, what ya think? so far in total its cost me about 180 bucks to do the kitchen and start in the living room with paint....
Old 02-20-2012, 12:06 AM   #861
77chris03
77chris03's Avatar
back to my build...we got out there and got a few things done...not much but a little progress.... got the passenger window felt and glass in...i found it easier with help from another person to hold the glass in the door, unbolt the motor, slide the rollers in the sash and door track, rotate the motor around and voila!!! its in...got it in in 10 mins with 0 problems. you should see it roll up and down on a 18volt drill battery...weeeeee!!!lol
got the door latch out of the door, cut the two tabs off so it wouldnt ever lock on me(i wanted to keep the door locklever in) got a small hole drilled in the latch to accept a cable for the door popper and mounted the solenoid.. tried to run the cable and crimped it too loose, so i gotta redo it....dang...heres some pics...
Old 02-20-2012, 12:11 AM   #862
Slick67
Sofa King Crazy!!
Slick67's Avatar
We were both gettin stuff done since the weather was great! Cool you got the windows in!!
Old 02-20-2012, 12:27 AM   #863
77chris03
77chris03's Avatar
the passenger is better than the driver window...damn...ill have the bear claw latches in tomorrow...so ill be cutting on the bed tomorrow or tuesday..i think im gonna cut the top rail off and put a piece of plate all the way down the length of the bed...get rid of that water trap from the factory///
Old 02-20-2012, 01:16 AM   #864
77chris03
77chris03's Avatar
the green 4 wheeler is gone...sold it to a guy with one leg..seriously. he drove 4 hrs to get it. he lost his leg in a bike wreck and now is stuck on quads... i test rod it for him, and his wife looked at him like he was crazy...she said really? he cant even keep the front tires on the ground!!!
Still gotta get the other windows....wink wink...lol
Old 02-20-2012, 10:05 AM   #865
Slick67
Sofa King Crazy!!
Slick67's Avatar
I know....I know....I'll throw some dough yer way next check. Dang windsheilds. errrrrr.
Old 02-20-2012, 10:19 PM   #866
77chris03
77chris03's Avatar
heres what i got in the mail today...
Old 02-20-2012, 11:41 PM   #867
77chris03
77chris03's Avatar
Old 02-20-2012, 11:53 PM   #868
77chris03
77chris03's Avatar
and thats what i got done tonite...the cable is looped on each end after drilling a hole in the latch to accept the cable...the cable is crimped just enough for the loop and then braided and heat shrinked and crimped again...
Old 02-22-2012, 12:01 AM   #869
77chris03
77chris03's Avatar
i got an a total of 40 mins to work on the truck today...heres what i got done....installed the door lock lever on the passenger door, adjusted the window track, got the drivers door latch back out, drilled the hole for the cable, remounted it, hooked the linkage back up and crimped the loop on the door latch. wouldve finished but i ran out of crimps for the cabling...also got the steering shaft in and secured...thats it for tonite...maybe more tomorrow, and hopefully ill get my door loom set in from brothers and my steering wheel soon so i can button up the doors...
Old 02-22-2012, 12:59 AM   #870
Slick67
Sofa King Crazy!!
Slick67's Avatar
It was like a bad 80's video......pop.....pop....mmmm.....pop!!!!! That's super cool! Got em workin!! 2 weeks bro, I'm countin!!
Old 02-22-2012, 01:22 AM   #871
late68
late68's Avatar
Where did you get the door glass from?
1968 C10 SWB Dropped 5 in tha back 3 in tha front
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902
late68 is offline   Reply With Quote
Old 02-22-2012, 08:56 AM   #872
77chris03
77chris03's Avatar
it is a kit from brothers truck parts ITEM # PWR0P72 price in the catalog is 749.99 plus 28.00 shipping....get ahold of Jaime on here (vendor for brothers) and see if he could help ya out if ur interested...they have a manual window kit # OPWK200 for 399.99 plus 28 shipping
Old 02-23-2012, 07:24 AM   #873
slick copper
slick copper's Avatar
Hadn't been on in a while. Great work on everything! Especially like how the tailights worked out.
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline   Reply With Quote
Old 02-23-2012, 10:23 PM   #874
77chris03
77chris03's Avatar
I have one pic....and its a mess of wires....and before i left my storage unit i armed the truck....lol i got the alarm and keyless entry wired...all im waiting for is the dang door loom for the doors....brothers is taking forever....i want to button up the dang doors already...!!!!!
Old 02-24-2012, 08:51 AM   #875
77chris03
77chris03's Avatar
btw i wouldnt mind the help...
