Closed Thread
Old 12-11-2013, 09:02 AM   #8851
Hipper
Hipper's Avatar
Re: What did you do to your truck today?
pulled motor and trans (454-th400) out of downer 78 suburban, also pulled out fuel tank and outside mirrors. Was going to just pull it and stick it into the 65 1 ton camper, but soft plug above starter is starting to leak and rear main seal leaking. So decided to pull heads and replace all gaskets, seals and check out. Cam &lifters look good , cylinders and brgs look good, timing chain not so much! So gasket set, soft plugs, timing set, flywheel, and harmonic balancer ordered. will try to remember to take picks of assembly, forgot to take picks of removal and tear down.
71 GMC Long Bed, 454,factory everything, lowered, and shaved.
64 GMC Short Bed (great grandfathers truck)
65 Chevy 1 ton Dually a/c p/s p/b v8 auto
89 Jeep Cherokee 3" lift
79 MG Midget (My 7 year old vehicle)
29 Ford Model A Rat Rod (in the works)
86 pontiac fiero 2.5 manual18 year olds)
87 pontiac fiero SE 2.8 auto (18 year olds)
90 Mitsubishi eclipes turbo AWD (18 year olds)
69 BMW 1600 (wifes toy)
Hipper is offline
Old 12-11-2013, 01:48 PM   #8852
Rich 5150 69
Rich 5150 69's Avatar
Originally Posted by Trsmotrhed View Post
Got my new LED taillights today from Summit Racing. To dang cold to try them out.
Found this MFG`r the other day...front LED and some others...
http://www.rodworx.com/product.php?item=766
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 12-11-2013, 07:00 PM   #8853
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re-adjusted my rocker arms and put a new valve cover gasket today. Discovered a slightly bent pushrod....far from scary and a possibility of a blown head gasket. Still running strong though! Like a chevy does so well!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline
Old 12-15-2013, 04:46 AM   #8854
Hipper
Hipper's Avatar
pressure washed under hood and transmission to get ready for installation.
Hipper is offline
Old 12-15-2013, 07:16 AM   #8855
glos55
glos55's Avatar
Starter is on and motor turns over
LIFE IS SHORT HAVE FUN
glos55 is offline
Old 12-15-2013, 10:58 AM   #8856
Grizz1963
Grizz1963's Avatar
Posting up on behalf of Martin my mate who cannot be bothered with posting, as he is too busy building
His step sons twist and go scooter was stolen at work on Thursday evening at work, literally behind the filling station building where he works.
So his manager gave him three days "off" to find another mode of transport, because he lives about 20 miles from where he works.
This left martin holding the an, as he knows a bit and has the truck, his tow car that we used a few weeks ago to fetch the V8 engine and gearbox with is not well at the moment...... so the Chevy was put into service, doing about 200 miles on Saturday to go look at and ultimately buy another 125cc learner sized bike for Mikey.
Little bike looks minute on the back, so hopefully the V-Rod will fill the space better when the truck is done.
Truck used as security anchor for the little bike.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 12-15-2013, 11:56 AM   #8857
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Worked on gutting the interior of my cab, getting it ready to come off the frame.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline
Old 12-15-2013, 05:49 PM   #8858
racecougar
racecougar's Avatar
I had a couple hours available today, so I swung by the shop and deleted the factory firewall holes for the engine harness, oil pressure line, and headlight/horn harness, along with a few other small holes (six holes total thus far). The engine harness and headlight/horn wiring will be relocated so that the wiring is hidden from view.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline
Old 12-15-2013, 06:17 PM   #8859
Grizz1963
Grizz1963's Avatar
Pics I did not have earlier.....
Martin had a tyre de-laminate last week, lost most of its tread.
Then he got lucky on Ebay and bought two 1 inch white walls, almost new for £80,00 fitted....... now that is called making your own luck.
Old 12-15-2013, 06:18 PM   #8860
mud.man.rj
mud.man.rj's Avatar
Nice idea on getting rid of the firewall holes and hiding the wiring harness, have done a lot of that on builds and most customers are so happy with how clean it looks and don't exactly know what I did, but like the underhood a lot better. I usually don't tell them either.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 12-15-2013, 06:28 PM   #8861
mud.man.rj
mud.man.rj's Avatar
Traded $2,000 labour on a TJ Jeep lift and engine mods for a 99 S10 ZR2 4x4 and did a quick going over on it and a few mods of parts I had saved then sold it for $2,800 cash to pay for my 40" Mud grapplers I ordered 2 weeks ago for my truck, have to do the barter system to keep the wife happy these days now that my twins are graduating this fall and leaving for school will be a bit low on cash. Next Mods will have to be thrifty.
Mudman.
5.0 4spd std.
7" lift w 35's.
Old 12-15-2013, 07:55 PM   #8862
jayoldschool
Moderator
Wow, I hated slot mags in the 80s when I was in high school, and I love them now. Looking good, grizz!
jayoldschool is offline
Old 12-15-2013, 10:11 PM   #8863
Chevy Fleetside
Chevy Fleetside's Avatar
My son likes the hole filled in firewall too...
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 12-15-2013, 10:28 PM   #8864
tincan1966
tincan1966's Avatar
What did I do to my truck today?.....Drove it! Just like every other day-the 'ol '65 daily driver is just that.
Been gone a while, re couping from surgery on my hand and the Mrs getting a 2nd total hip replacement this year(now has a matched set of shiny new ones, LOL)
Did do a dual reservoir master cylinder upgrade and all new brake lines and hoses. Kept with the drum brakes. Had to opt out to the recommended ECM that Painless suggests for a Camaro. Mine was from the '91 Olds donor and wanted to keep setting an "intake air temp low" DTC(of which there was no sensor or harness for) Check engine light off all the time now, running great and getting and average 15 MPG, but that is all stop and go, in town only driving. Highway numbers get closer to 19 mpg,but lockup on the TH350C not always engaging. Switching to computer controlled 700R4 soon.
tincan1966 is offline
Old 12-16-2013, 12:11 AM   #8865
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Thought about mine today.....waiting for the future hotrod rebuild of the 6 banger!
Old 12-18-2013, 04:06 PM   #8866
Grizz1963
Grizz1963's Avatar
This is a bit of a cross over reply.
I bought a 210 liter compressor from a mate for £100.00 a while ago, but the thing is £&%$$%£ Heavy.
So I decided to add some wheels.
Original plan was to buy four with single bolt fixing......
But then I said to Mickey next door that a shopping trolley would work well.
He then got me a broken bakers trolley from a skip at a job he was on.
So the trolley was the Tip Treasure.
[img src="http://i294.photobucket.com/albums/mm90/niknakpix/Billybob178_zps45c5bf60.jpg" alt=" "]
Said trolley
Stripped wheels off.
Had some 10mm steel plate to cut to size for mounting the wheels onto
Was going to engineer and drill holes, recess the heads etc, to recycle the allen head screws and nuts, but decided it was a PITA not worth pursuing. So welded the holes onto the plates and tacked the corners and edges.
Went out for the afternoon, getting home around 16.00 and then back to the garage.
It was already getting dark, but then who needs light when you weld??
I used the small jack to lift the tank to the right height and a couple of magnets to hold the wheels in place.
View from outside.
JOB DONE......Mobile compressor.
Close up time for today.
Tomorrow I need to get under and about the truck to see what bits of patch panels I need to order in from the USA.
Looking forward to getting on with the body work and of course paint in the new year.
Old 12-18-2013, 05:29 PM   #8867
wjjeeper
wjjeeper's Avatar
Today I took pictures of the truck and whored it up on this forum. Yesterday installed rear trac bar, lowering blocks and new u bolts.
wjjeeper is offline
Old 12-18-2013, 11:28 PM   #8868
jbgroby
jbgroby's Avatar
Grizz,
You know if you ever get a flat on one of those compressor tires, its gonna be a bear to change.
jbgroby is offline
Old 12-18-2013, 11:44 PM   #8869
dwcardfan
dwcardfan's Avatar
Started running fuel lines on my 65.
dwcardfan is offline
Old 12-19-2013, 02:29 PM   #8870
Grizz1963
Grizz1963's Avatar
Opinions and advice sought please.
When I bought the truck, I knew it would need a complete resto and repaint to get it looking the way I want it to be.
I originally had a colour change in mind to a traditional mint green and white combo, or a real farmer brown green colour with off white detailing. But within a week of buying the truck, I knew it would stay the "in your face" red that it had been painted 10 years ago before leaving California.
I also knew it had some rust, and that is was very little for a 47 year old vehicle.
However, I was surprised at the rust when I started looking around under the truck.
There are a few holes that will need new metal welded in after surgery, and then some dents and scrapes to fix. All of these I am prepared to give a go, however, I will be buying and importing some steel patch panels.
I am happy to hear from anyone who has experience in using the panels that are available in the market from the likes of LMC, Top Banana and others, which are best for quality and fit.
Below are a few pics of my fenders and also the front, bottom corners of both doors.
Passenger door underside. The fender on this side seems fairly intact, but I may just bite the bullet and replace that whole side while on the metal work and paint.
Driver side fender corner...... this is bad, it is loose, and the inner support is rotten as well.
I suspect you could pull the whole bottom off without much effort.
Inside view...... made me want to cry. I will get the whole support for this side, rather than patching it up. The passenger side seems totally solid.
Drivers side lower door front corner. I am happy to make up path panels for the two doors as they are out of sight.
As mentioned above, please do add any comments and advice you may have for me regarding repairing the rust.
The trucks sills and cab corners are completely solid, and there are small bits of rust on the inner fenders just behind the grille and front support.
As can be seen in this pic.
The other thing I looked at today was the placement of the rev counter my buddy Tim gave me in August.
I did not want to fit it till the truck was painted, but realized that placing it and wiring it up will not stop me from the paint and prep. I plan on going for a satin black dash, or satin black and red combo.
My question is this......
Where do most people place rev counters?
Sensible, practical, visible etc.....
Here is mine, just held in place or placed in position to get and idea.
Opinions, advice ??
Somewhere in the left hand corner.
Over to the right ??
Looking forward to ideas etc....
Thanks, Rian.
Old 12-19-2013, 02:35 PM   #8871
1963c-10
1963c-10's Avatar
Hey grizz1963....id get replacement doors if possible. If not definitely get new door skins and lower inside patches.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline
Old 12-19-2013, 02:43 PM   #8872
davbowen
davbowen's Avatar
put the tach on the column. I personally don't look at the speedo much...
davbowen is offline
Old 12-19-2013, 02:56 PM   #8873
luvbowties
luvbowties's Avatar
Wink Re: What did you do to your truck today?
Originally Posted by jbgroby View Post
Grizz,
WRONG! I met grizz on here, and being the jack-of-all trades that he is--wood, vans, campers, house-construction, cars, hvac, trucks, just to name a few--I'd bet he's already got a space-saver spare hidden on that comp. somewhere! (Good luck, grizz, with your new truck.)
Sam
luvbowties is offline
Old 12-19-2013, 03:07 PM   #8874
racecougar
racecougar's Avatar
Grizz, you'll find a LOT of recommendations for Top Banana when it comes to patch panels here on these forums. I've installed a bunch of their panels on the '65 C10 I'm working on, and I'm happy with the panels I received.
As for the tach, personally, I'd get a smaller one with a more appropriate range. Wherever you put it, it would be less obstructive to your view, and with a smaller range, it will be easier to read.
Old 12-19-2013, 03:12 PM   #8875
Grizz1963
Grizz1963's Avatar
Grizz,
I have a small trenching tool (folding spade) that I would use to lift up the side that needed a spare fitted..... that's how I got the jack in last night.
Closed Thread
