Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 01-31-2014, 09:59 AM   #876
Daveboyd
Daveboyd's Avatar
Re: Boyd Welding-67-72 Rear Mount Aluminum Tank
Travis at Pro Performance has structured a group buy for you guys. This offer is only available for a limited time through his website.
Link to his thread: http://67-72chevytrucks.com/vboard/s...20#post6499920
Link to his Website:http://www.azproperformance.com/Boyd...nks-67-72-C10/
Dave Boyd
View Our 63-72 C10 Tank options https://fueltankparts.com/collections/63-72-c10-tanks
Boyd Welding Main Site : http://www.boydwelding.com/
Boyd Online Shop: https://fueltankparts.com/
E: Sales@boydwelding.com
Daveboyd is offline   Reply With Quote
Old 01-31-2014, 04:16 PM   #877
Booya
Booya's Avatar
Got mine ordered today, just in time...
Booya is offline   Reply With Quote
Old 01-31-2014, 04:24 PM   #878
lynnfield
The Waco Kid
lynnfield's Avatar
Order it with the powder coating. This will be your cheapest option unless you paint it yourself, or leave it bare. I got mine bare and it was $120 for powder coat or $130 for lineX coating.
lynnfield is offline   Reply With Quote
Old 01-31-2014, 08:26 PM   #879
Kennuck
Kennuck's Avatar
Put my order in with Travis, Great guy good to deal with.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 02-01-2014, 10:36 AM   #880
smoky02
Location: Sunny, Florida, some might call it South Alabama
I wanted to be part of the group buy but I need the gas cap centered so I guess I'll do custom order when you are ready.
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 02-05-2014, 10:08 PM   #881
Pmarti69
Im down for one as well, but has to be with fuel neck to fill from license plate flip down on my 72
Houston Area Lawman
72 GMC Fleetside (AKA: MERLIN)
ZZ4 Crate Engine
TH400 with Stage two kit
Pmarti69 is offline   Reply With Quote
Old 02-05-2014, 11:23 PM   #882
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
I think I'll be doing the same thing.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 05-20-2014, 04:18 PM   #883
utee05
Any word on another group buy? I am looking to buy a tank for my '72 non-efi side-fill with sending unit and rollover vent.
'72 GMC Super Custom 1500 350 V8 w/AC
utee05 is offline   Reply With Quote
Old 05-21-2014, 09:50 PM   #884
jondancer
These tanks are the ****, buy one
jondancer is offline   Reply With Quote
Old 05-21-2014, 11:38 PM   #885
jtp67-72
jtp67-72's Avatar
I have to agree...........jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 05-30-2014, 09:15 PM   #886
brian1971
brian1971's Avatar
Just put my order in this week should arrive in a few days.Side fill
Brian
1971 c10 custom deluxe fleetside swb
LS3 w/BTR stage IV cam,4L85E w/3600 stall
67-72chevytrucks.com/vboard/showthread.php?t=558024
brian1971 is offline   Reply With Quote
Old 06-01-2014, 05:41 PM   #887
t76turbo
The tanks are awesome. I ordered one from pro performance. Waiting to install on my friends lift.
Has anyone come up with a no fabrication required way to access a bed fill tank in a metal bed?
I have seen some guys cut squares out of bed and fabricate flat sheet metal to create a flat area to bolt in a door. I don't have a welder and before I search out someone who does, I would love to find a door solution that would work.
1970 Shortbed 2wd C-10
t76turbo is offline   Reply With Quote
Old 06-02-2014, 09:39 PM   #888
brian1971
brian1971's Avatar
Hi Dave I received my tank today and it looks great.I have one small issue if I mount the tank from the bottom the filler neck does not clear frame,if I set it in frame it still does not clear but is usable I am going to mount on top of frame and space with some rubber gasket material.Just wanted to let you know.
My truck is a 1971 c10 factory shortbed.
Thanks for building such a nice product.
Brian
Old 06-17-2014, 09:36 AM   #889
Daveboyd
Daveboyd's Avatar
We now have Universal Tank Mounting Kits available on our website. They are in-stock and ready to ship.
http://www.fueltankparts.com/67-72-u...nting-kit.html
Dave Boyd
Old 09-14-2014, 04:00 PM   #890
lynnfield
The Waco Kid
lynnfield's Avatar
Dave, I'm having a problem with my roll over vent interfering with the cross support on the bed. When I ordered my tank I talked to both you and Kristen and informed you that I was planning to mount my tank above the rail. You both told me this would not be an issue. The tank is also as far forward as it can go. So my question is, is the roll over vent in the wrong location? This is a real problem now because I have had the tank line-x coated. Greg
Old 09-14-2014, 04:15 PM   #891
lynnfield
The Waco Kid
lynnfield's Avatar
Dave, if this is the correct location, why so close to the support? Looks like there's plenty of real estate to put it anywhere. I have posted pics for your reference only, not downing your product I like the tank, just want to get it working and on the road. Greg
Old 09-14-2014, 05:25 PM   #892
brian1971
brian1971's Avatar
Greg I had the same problem as you did I mounted mine on top of frame rails.What I did is run a tap in to make the threads deaper pretty much had to bottom out tap but it worked for me.Just put a lot of grease on tap to catch shavings.Hope this helps Brian
Old 09-14-2014, 09:26 PM   #893
lynnfield
The Waco Kid
lynnfield's Avatar
Brian, thanks that worked. I bottomed the roll over vent as much as possible earlier, but never thought about running an NPT tap deeper into it. Greg
Old 09-14-2014, 10:20 PM   #894
wwgolferdog
Is anyone else waiting for a group buy on these tanks?
wwgolferdog is offline   Reply With Quote
Old 09-15-2014, 01:12 AM   #895
full foot notch
I'm wondering if you can do a rear tag exit like this camaro tank setup. Would rather not cut into the bed. http://67-72chevytrucks.com/vboard/s...=Aluminum+tank
full foot notch is offline   Reply With Quote
Old 09-15-2014, 06:01 AM   #896
full foot notch
I also just realized your in ocala, I'm in orlando
Old 09-17-2014, 05:35 AM   #897
Chris Coufal
Is there going to be another coupon or grp buy? I have mine in "My Shopping Cart" and decided to search before I clicked submit. Geeez $800 is a hefty chunk from my wallet.....
Chris Coufal is offline   Reply With Quote
Old 10-05-2014, 09:36 PM   #898
hubba033
hubba033's Avatar
I` m in if theres a group buy
72 C10 swb LS 5.3 LSA Blower/4l60 performabuilt
01 Pontiac Trans Am WS6
hubba033 is offline   Reply With Quote
Old 10-07-2014, 11:22 PM   #899
FL71C10
Hi, Dave,
I have one of your tanks, a brand new never installed tank, for my truck, and now I am switching to an LT-1 setup. Can I bring my tank to you and have it converted to an EFI tank?
Thanks.
John
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 10-09-2014, 09:23 PM   #900
BrentRS1985
BrentRS1985's Avatar
I am also in for the group buy.
1969 C-10 Short Bed
BrentRS1985 is offline   Reply With Quote
67-72 truck, aluminum tank, boydwelding.com, fuel tank, tank relocation
