Old 03-09-2013, 04:17 PM   #901
JohnC
JohnC's Avatar
Re: project 62
Those are indeed scary doctor's visits, but make for fun times later on
JohnC is offline   Reply With Quote
Old 06-18-2013, 03:20 PM   #902
mcbassin
Still Learning
mcbassin's Avatar
Re: project 62
What's up Scott? TTT
mcbassin is offline   Reply With Quote
Old 06-19-2013, 09:56 AM   #903
scotts62
One day...
scotts62's Avatar
Re: project 62
Hey Mike, um notta whole lot.... i need to work on this dude because then the side work will flow again, never fails
Scott
93 crew cab build
Project 62
Old 12-09-2013, 08:32 PM   #904
scotts62
One day...
scotts62's Avatar
Re: project 62
Well if i keep at it like i am then ill have quite a few pics to show off..
Scott
93 crew cab build
Project 62
Old 12-10-2013, 01:17 AM   #905
Captainfab
60-66 Nut
Re: project 62
That's good to hear......I was beginning to think you had abandoned us over here.
Old 12-10-2013, 10:57 AM   #906
scotts62
One day...
scotts62's Avatar
Re: project 62
Haha no not quite, the whole life and priorities thing keep getting in the way
Scott
93 crew cab build
Project 62
Old 12-20-2013, 06:41 PM   #907
scotts62
One day...
scotts62's Avatar
Re: project 62
Well i got a thought by looking at them like this and figured i could make it look a little cleaner than zip ties to frames that i have seen rolling around here
Made a manifold to cut down on all the lines
Not Completed but you get the idea
Also mocked up the radiator and air cleaner so that i can fit it all under the hood and build a core support
Scott
93 crew cab build
Project 62
Old 12-20-2013, 06:51 PM   #908
scotts62
One day...
scotts62's Avatar
Re: project 62
Got ahold of a complete 6.0 that pushed out a cam bearing (apparently not uncommon for) Checked the block and it was not hurt so im going to use a dab of Loctite on some durabonds and go with it. My helpers lending a hand tearing it down.
Scott
93 crew cab build
Project 62
Old 12-20-2013, 06:53 PM   #909
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: project 62
Just read through yer build thread. MAN! Wish I joined this club on 2009!!! I missed out on some comical conversation! Nice build and keep up the good work!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 12-20-2013, 06:59 PM   #910
scotts62
One day...
scotts62's Avatar
Re: project 62
Got started on the core support and its going to turn out like i am hoping it will. Here is the bender i made in action on one of the frame to core support brace. Ill post more when it makes more sense to others
Crooked $30 piece of metal that i hope works out
Scott
93 crew cab build
Project 62
Old 12-20-2013, 07:00 PM   #911
scotts62
One day...
scotts62's Avatar
Re: project 62
Yeah we get off topic a little but oh well it adds character
Scott
93 crew cab build
Project 62
Old 12-20-2013, 07:05 PM   #912
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: project 62
Gotta have fun right!
Old 12-20-2013, 08:33 PM   #913
mcbassin
Still Learning
mcbassin's Avatar
Re: project 62
Very nice progress Scott!
Old 12-20-2013, 10:31 PM   #914
scotts62
One day...
scotts62's Avatar
Re: project 62
Thanks Mike, thanks again for the help with the tank!
Scott
93 crew cab build
Project 62
Old 12-22-2013, 03:08 PM   #915
scotts62
One day...
scotts62's Avatar
Re: project 62
Used some plastic line around the shop and hooked air up to try the valves out just using the fancy way of touching wires together but it worked
Going to run stainless line to everything later.
Scott
93 crew cab build
Project 62
Old 12-22-2013, 08:33 PM   #916
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: project 62
Cool!! Progress no matter which way you look at it.
Alan's Classic is offline   Reply With Quote
Old 12-22-2013, 09:28 PM   #917
67c10rustbuket
67c10rustbuket's Avatar
Re: project 62
I always liked the SMC diaphragm valves and the box should keep it all neat. Much faster than the fancy stuff but quite a bit of plumbing. Make sure to keep moisture out of them when it's cold outside. One truck I had with those mounted under the bed would freeze/stick when below freezing because it didn't have a water seperator. Several times I had to wait for the exhaust to warm up the tank and valves to work properly. Sold it before I fixed that problem. Not the smartest thing to drive in the snow anyways...
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 12-22-2013, 10:44 PM   #918
scotts62
One day...
scotts62's Avatar
Re: project 62
I have a couple driers/filter and a separator that is going before the tank and another after it to the valve box as you could say so i think that part will be ok. And as far as freezing up i dont think it will do that in the garage during the winter
Scott
93 crew cab build
Project 62
Old 12-24-2013, 07:29 PM   #919
JohnC
JohnC's Avatar
Re: project 62
Looking good man!
Old 12-24-2013, 07:57 PM   #920
mcbassin
Still Learning
mcbassin's Avatar
Re: project 62
Nice work Scott. I'm looking forward to the custom core support coming together.
Old 12-25-2013, 01:41 PM   #921
scotts62
One day...
scotts62's Avatar
Re: project 62
Yeah me too. I got the rear going my way (well i think) just not pic worthy yet... Soon though very soon.
Scott
93 crew cab build
Project 62
Old 12-27-2013, 12:07 AM   #922
scotts62
One day...
scotts62's Avatar
Re: project 62
It got some fresh air tonight
Scott
93 crew cab build
Project 62
Old 12-29-2013, 02:36 PM   #923
scotts62
One day...
scotts62's Avatar
Re: project 62
Bent some pieces for the wish bone, the 180 degree was just a test piece with the bender
Just tacked up and sitting but you get the idea. Hope to get out there in a bit and try and finish it up but we'll see.
Did 4 of these to mount the battery and valve box, everything is tacked in right now and will weld up once the body parts come off for the frame to be done.
It was a nice day yesterday to get it out and work on it some
Scott
93 crew cab build
Project 62
Old 12-29-2013, 04:53 PM   #924
mcbassin
Still Learning
mcbassin's Avatar
Re: project 62
Very good progress Scott. It looks like you're focused now.
Old 12-29-2013, 05:54 PM   #925
scotts62
One day...
scotts62's Avatar
Re: project 62
Thanks Mike, yeah im starting to see some progress and it come along so i better keep the fire rolling
Scott
93 crew cab build
Project 62
