03-03-2012, 10:58 PM | #901 |
Re: My 68 swb build.
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 |
03-03-2012, 11:01 PM | #902 |
03-03-2012, 11:06 PM | #903 |
PROJECT 7DEUCE
What door poppers are you running? Also you need to upgrade to some better window switches those remond me of and 80s chevy car..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
03-03-2012, 11:26 PM | #904 | |
60lb electric life solenoids..
03-03-2012, 11:26 PM | #905 |
67cheby
I still need to drill my holes for my wiring any reason why you went high and low like that ? As opposed to straight across ?
Posted via Mobile Device |
03-04-2012, 12:05 AM | #906 |
VA72C10
Looking good!
Looking for a 67-72 swb or blazer project in or around VA. |
03-04-2012, 12:53 AM | #907 |
ya..when you close the door, and if you put it in the jamb like i did, you need a place for the wiring to go...or it would bunch up and the door wont close. in all honesty, i think i screwed up but it ended up working in the long run....one reason is i dont have the vents anymore...and i think thats where most people run the wiring...
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 Last edited by 77chris03; 03-05-2012 at 12:19 AM. |
03-04-2012, 01:02 AM | #908 |
and it was really the only place to clear the one piece window track...just remember that if you drill in basically the same area, you have to go thru the inner support brace inside the door....and i did this with the doors on with a 3/4 hole saw...one in the door, one in the jamb, and one on the inside of the cab directly under where the dash and kick panel meet for the wiring to run through
03-04-2012, 01:06 AM | #909 |
thank you thank you...but all the chips in the paint dont....lol
03-04-2012, 12:16 PM | #910 |
low n' slo
i think its coming out nice man...that column looks good in there
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
03-04-2012, 03:35 PM | #911 |
i do have an IDIDIT indicator still in the package....has OD on it...
03-04-2012, 03:46 PM | #912 |
thanks...i should have the steering wheel back this coming week...
03-04-2012, 08:45 PM | #913 |
got a little done today...seat is in and bolted down...then had to pull it back out to attach the cable for the other track...started working on the tailgate latch...got the windows wired up.
03-04-2012, 08:47 PM | #914 |
03-04-2012, 11:18 PM | #915 |
Sofa King Crazy!!
Man! That is some huge progress! Congrats Chris it is coming along quick, you'll be driving it in no time. We'll be cruisin this summer!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
03-05-2012, 12:05 AM | #916 | |
03-05-2012, 12:11 AM | #917 |
one thing that is weird, and ill figure it out....i can use the drivers door switch to roll the drivers window up/down, but the other switch, as soon as i hit it, it blows the fuse...but i can roll it down from the passenger switch no problem..i believe i have a problem with the switch...now on the engine side i have to get another breather or install a pcv valve, finish the damn fuel line i keep putting off because i dont wanna crawl under the truck..lol now if i can just get the painter to do something...
03-05-2012, 12:17 AM | #918 |
any tips on exhaust dos and donts?
03-05-2012, 12:20 AM | #919 |
and emergency cable for the doors? i need someone to chime in so i can button up the drivers door ....
03-05-2012, 07:36 PM | #921 |
lol its the only station i can get clearly inside the storage unit with the light on..whoever did the electrical only ran the switch leg up to the light and shared the neutral on the timer....so there is a crap load of noise in the 120v line..
03-05-2012, 11:55 PM | #922 |
not much but i did get a little bit done tonite, despite it only being 2 hrs...and half that time was dealing with the welding bunching up the wire and me having to dig it out for 30 min...heres some pics.
03-05-2012, 11:58 PM | #923 |
not perfect at all, but for what i got to work with, it should do.
03-06-2012, 12:01 AM | #924 |
Still Learning
I love your new interior. It looks great. I may need some more info on the power window setup you are using. Also, nice work on the bed. Can't wait to see it done.
03-06-2012, 12:02 AM | #925 |
anyone got an idea for the rest of the top rail to match the contour of the lip or a transition?
