11-19-2016, 05:45 PM | #901 |
Re: How about some pics of bagged 60-66
11-19-2016, 07:09 PM | #902 |
1962
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
01-02-2017, 03:43 PM | #903 |
sold now but until last june this was mine!
96 s10 static drop smooth and blue 99 silverado nothing stock layed out on 24s 65 c10 bagged patina driver http://www.myrideisme.com/Garage/az480 half-assed build thread http://67-72chevytrucks.com/vboard/s...=1#post5206828 |
01-02-2017, 08:53 PM | #904 |
Active Member
Finished up my air valve install.
04-25-2017, 04:07 PM | #905 |
1966 Chevrolet 5.3L LM7, cammed, ported and polished 4l60E, manual valve body Throbros front dropmember,Custom 2 link rear with watts link Ridetech control arms, Accuair air management |
12-26-2017, 09:04 AM | #906 |
my 63'. trucks on choppin' block front with my own setup in the rear.she's a garage queen for another 6 months (hopefully)
12-26-2017, 10:36 AM | #907 |
02-10-2018, 01:39 PM | #908 |
Yes, please - how loud??
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
02-10-2018, 02:41 PM | #909 |
Me, too! I've heard that if you run exhaust tubing from manual valves to the exterior it's quiet in the cab.
02-11-2018, 08:39 PM | #910 |
My 64 hoping to drive by summer
02-11-2018, 09:39 PM | #911 |
02-12-2018, 06:01 PM | #912 |
04-07-2018, 12:03 AM | #913 | |
04-07-2018, 04:41 PM | #914 |
I've run these little silencers on dump valves before.......so quite, you hardly hear the air when you lower your truck.
04-11-2018, 09:58 PM | #915 |
Are you guys doing drop spindles and cups in the front. What is your ride height. I'd like.to.keep.my ride height close to where it is now with my 5 and 6 static drop
04-12-2018, 07:54 PM | #916 |
62 Short Fleetside static dropped 5 1/2 x 6 - floor channeled 3" inside the bed box - stock 62 chassis with 78 front clip
Hope to be converting to a basic Air Ride System soon, since I have sufficient pavement samples for my research work... when taking measurements and looking for hiding places to stuff equipment I found that I have 3" inside the c-notch to the bump-stop, but my rear tire is about 1-2" from inner bed side and will definitely hit when I drop it on bags. 73 K10 12 bolt posi rear is slightly wider than original so I'm guessing I have to trim inner bed panel or change wheel offset. Anyone else encounter such doings??? Too much talent on this board to ignore |
04-13-2018, 09:33 AM | #917 |
04-13-2018, 11:29 AM | #918 |
Miayota is that your green truck? Man I love that thing.
04-14-2018, 04:56 AM | #919 |
04-26-2018, 11:37 AM | #920 |
My 1965 C10 - newly bagged and finally on the road. Paint coming soon...
07-31-2018, 12:40 PM | #921 |
Got mine on the ground, finally. Still haven't done the c notch yet. I will probably tackle that when it cools off some. I have a few things to finish before I drive it.
05-05-2019, 12:05 AM | #922 |
Few pics of my 66
03-22-2020, 10:21 AM | #923 | |
03-22-2020, 10:23 AM | #924 |
im interested in some 62s that has been bagged.. either crossmember swap or on stock suspension doing the torsion bar delete
03-23-2020, 04:24 PM | #925 |
Some pics of my 60 GMC long bed (slowly being turned into Chevy) project.
I removed all the X frame stuff from the 60 chassis, Z'd the front frame,made and installed a step notch and shortened frame and bedsides. It will be getting a 377 sbc and a 4 speed tranny. The maroon 65 c10 was bought as a parts truck for this project. The frame of the 65 c10 already had a step notched installed as well as a pancaked front crossmember and an aftermarket trailing arm mount when I bought it. I will be selling most of that stuff and several parts from the GMC.
My build link.. http://67-72chevytrucks.com/vboard/s...d.php?t=285353 |
