10-23-2017, 10:40 PM | #926 |
At the body shop.
Re: Trucks Are Beautiful
This was the beautiful ride i get to wheel to the show.
" That didnt make it any newer " " Dont antique the equipment " |
10-23-2017, 11:11 PM | #927 |
Nice looking truck.
Tell us more about it.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
10-24-2017, 12:34 AM | #928 |
Here's a little guy I picked up over the weekend. 1965 chevy c80 viking.
10-24-2017, 01:21 AM | #929 |
At the body shop.
1979 359 peterbilt standard hood 1974 40' fruehauf 8' wide 400 BC Cummins 13 speed on air leaf. Neat little truck to drive around with 3 golf carts a bbq and tables and chairs.
10-30-2017, 08:03 AM | #930 |
Former fire truck, ey? What engine?
10-30-2017, 11:39 AM | #931 |
Yessir, you can still see the outline of "we make house calls" on the front bumper. As far as the engine goes, im pretty sure it was the inline 292 and the 4 speed; however, it has been fitted with a sbc and a dana 5 speed. I just so happen to have a 292 and 4 speed from my 63. I plan on putting the 292 back in for sure, but I may keep the 5 speed dana.
There's not much informaton on the cabover series of trucks that I've found so the validity of my statement could be way off. I've been scrounging this forum, the stove bolt forums, and the big bolt forums, but the cabovers are like hens teeth, hard to find. |
10-30-2017, 04:52 PM | #932 |
I'd be pretty surprised if a Fire Truck only had a 6-292. My guess would had been a 409 seeing that it is a Chevrolet.
By the way, although I'm not too knowledgeable on the COE Tilt, I believe you have a T-80 there. Looks to be in pretty nice shape.
10-30-2017, 04:57 PM | #933 |
10-31-2017, 05:45 AM | #934 | |
Next!
With picture
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
11-01-2017, 01:45 AM | #935 |
So after a little bit of research the title does start with a t code so it seems that the information about this being a "t" series truck seems to make sense. As far as the engine goes, I'm still not sure what exactly came in it. The heads on the engine that's in it currently don't look like 409 heads, maybe the 348? Honestly it still "looks" like a sbc to me, but I haven't dug into it. More research will need to be done to decipher block.
11-01-2017, 01:59 AM | #936 |
What I always imagine when seeing a 409/348 block.
And... |
11-01-2017, 08:04 AM | #937 |
You have a Small Block for sure. It is also not very original and probably not the original block. Let us know the Numbers on the Front Pad and we can tell you for sure.
The 2nd Picture is a GMC V-6 Engine.
11-01-2017, 08:18 AM | #938 |
Yep, SBC for sure and I'm guessing (even though this one may be swapped) that is what it originally had. Notice where the fan is mounted? If not originally a SBC they would have had to scrounge the parts from a T configuration.
You are correct on the 345/409 appearance with the W-heads/valve covers, which at a glance appear the same as a GMC V6.
11-01-2017, 09:03 AM | #939 |
Here are some good examples of what the 348 and 409 look like:
http://www.superchevy.com/features/s...409-w-engines/
11-01-2017, 11:32 AM | #940 |
Yeah I had a feeling something wasn't right about it... also I guess I was a little tired last night I didn't even realize that the center manifold wasn't split... silly gmc's.
Found this website last night: http://www.caaarguide.com/sub1/id435.html For 65 looks like the tilt series could be outfitted with a: 230 I6, 292 I6, 283 v8, 327 v8, 348 v8, and the 409 v8. Maybe it has some potential of being the 327. Next time I'm up at the garage I will pull the tag. |
11-01-2017, 11:51 AM | #941 |
If the chart is accurate, like it looks like it is, the only Gas Engines available in the T-80 was the W-Block. Therefore it looks like your truck was either a 348 or 409 originally.
11-01-2017, 12:26 PM | #942 | |
Well then it's settled, w block for originality.... 292 because that's what I have edit: picture |
11-01-2017, 06:59 PM | #943 |
11-01-2017, 08:08 PM | #944 |
11-02-2017, 08:30 AM | #945 |
Little big Dodge. Have you ever seen this special T?
11-02-2017, 12:10 PM | #946 |
special-K..... I haven't stumbled upon that one yet! The "bed" on that looks awesome. Almost like a pipeliners truck bed. You wouldn't happen to have any more pictures would you?
11-03-2017, 10:31 PM | #947 |
The guys talked me into working today. They were a driver short.
WE had a good day, breaking ground on a new law enforcement center (jail). I think I will stay retired.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
11-04-2017, 12:27 AM | #948 |
At the body shop.
But 1st a pic before we go home.
#600
11-04-2017, 03:20 AM | #949 |
I always liked the Chevy and GMC steel tilt cab. I thought the cab was more solid than the Ford C series, and the GM's had a much better gear shift. Some of the 1960-65 GMC versions had the 702 gas V-12 in them, and some were built with Toro-Flow's, Detroit 6V-53's, and 6V-71's. Legend has it a limited number of GMC tilts were even built with 8V-71's for auto transporter service. The Dodge 'L' series was a neat little truck, Dodge used the sheetmetal from their small van for the cab. Most all of them were gas powered, I think a few had small Cummins V-8's in them.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
11-04-2017, 03:55 AM | #950 |
At the body shop.
Like this PMT truck?
Pacarhauler pic via Flickr
