Old 11-14-2013, 01:47 AM   #926
rollin thunder
rollin thunder's Avatar
Re: 1977 Chevy C10 known as SharkBite
Jealous of the progress man! haha Good to see things are moving and ofcourse the headaches that come with it.
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373
1984 Chevy C10 short bed
2001 Chevy Impala police cruiser
2001 Chevy Silverado 1500 Z71 4wd extended cab dd
rollin thunder is offline   Reply With Quote
Old 11-14-2013, 10:12 AM   #927
77ChevySharkBite
77ChevySharkBite's Avatar
thanks man! Yeah I've come to learn to live with the headaches just trying to get a truck of it's age to a good runner is going to come with plently of headaches etc so I know when it runs it's going to be a monster so anxious to see what happens.
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 11-14-2013, 11:55 PM   #928
chevybuilder18
chevybuilder18's Avatar
Originally Posted by 77ChevySharkBite View Post
Also I think we found the heart and soul to the issue of this truck not running right ever! you can't see the bottom but if you look at the timing chain the top gear you can see a little tiny circle that's there well for y'all that may not know that's supposed to be lined up with the bottom gear well that's not exactly how that's working the bottom cam sprocket gear is lined up correctly, so being that the top gear was 180 degrees off I think it's safe to say I have found the issue with the truck.
i said whoa! thats messed up, but then i seen someones reply reminded me the cam sprocket is 2 to one ratio
Her name is Quicksilver
1978 Chevrolet silverado, shortbox stepside currently being swapped IN is a LM7 5300 vortec, 4l80E, factory 4.11s, slammed, a dream ride and coined QUICKSILVER
gotta pay $$ if you wanna play
chevybuilder18 is offline   Reply With Quote
Old 11-14-2013, 11:59 PM   #929
chevybuilder18
Okay, then if that's not the issue what would be my issue? Not sure if you had read it all but my truck was timed at 0 advance which it idled fine but wasn't exactly drivable. We've verified tdc, made sure the rotor was where it's supposed to be, what could be causing this hiccup?
it could be a vacuum leak, manifold air leak. could be rocker arm specs..
Old 11-15-2013, 12:18 AM   #930
77ChevySharkBite
Yeah I didn't know that myself until someone told me and sent me to an article to read it
my money is that it's the balancer part of the reason I bought a new one, so this weekend going to put it on and then if that's not it going to troubleshoot from there. I think the odds are looking toward the balancer though.
Korwin
Old 11-15-2013, 03:28 PM   #931
77ChevySharkBite
here's some more detailed pictures of the balancer, you can see where the PO marked and on the new balancer it's roughly at 30degreees advance.
Korwin
Old 11-15-2013, 03:51 PM   #932
rollin thunder
Was looking back through the build everything is looking real good. And thats a nice new balancer you got there. I hope thats what the issue turns out to be.
Old 11-15-2013, 03:56 PM   #933
67 c10 guy
67 c10 guy's Avatar
I also believe it could be the balancers fault since a worn balancer outer portion can spin and throw off timing when trying to adjust but it never hurts to replace all other possible worn timing parts
67 C10 longbed 350/th350
13 Ford Fusion 2.0T daily
67 lwb build sold
67 c10 guy is offline   Reply With Quote
Old 11-15-2013, 03:56 PM   #934
77ChevySharkBite
Thanks man! I appreciate it the compliment! Getting ready to hopefully solve all this timing stuff it's stressful.
Korwin
Old 11-15-2013, 09:36 PM   #935
rollin thunder
I know it. It once took me 3 weeks to figure out all the issues with the timing and get it situated on a 49 ford flathead v8. although it only turned out that a broken distributor cap clip and clamp down at the bottom every time the motor started it kicked the dist out and way out of time. yup i was one cool customer through whole deal
Old 11-16-2013, 09:42 AM   #936
Jabes1
Jabes1's Avatar
The factory balancer doesn't look like its slipped in comparison to your new balancer. Look at the keyway on both balancers and the timing mark of 0 degrees on both balancers. They are the same. How are you timing your engine?
Welcome to my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=574370
Jabes1 is offline   Reply With Quote
Old 11-16-2013, 11:24 AM   #937
Ron S.
i like the look of those rims
Ron S. is offline   Reply With Quote
Old 11-17-2013, 10:46 AM   #938
77ChevySharkBite
I borrowed a friends timing light and that what I'm using to time the motor sorry for the late response.
Korwin
Old 11-17-2013, 10:47 AM   #939
77ChevySharkBite
Thanks man, there MB Motorsports Razor I believe is the name of them I got them from discount tire.
Korwin
Old 11-17-2013, 10:49 AM   #940
77ChevySharkBite
Haha yeah I feel like a cool custom right now especially knowing the way it runs has been mostly correct but hey it makes for a learning experience.
Korwin
Old 11-18-2013, 12:34 AM   #941
77ChevySharkBite
Okay fellas I know it's late but here's some videos for y'all to try and assist me if possible.
First one will be at 8 degrees advance not sure if you can hear it audible through video but sounds a little like its stumbling. I am doing like a power brake since I'm not driving it.
2nd video is at excatly 0 degrees timing and doing again a power brake and it doesn't seem like it skips a beat.
3rd video is to show y'all exactly how much throttle I'm putting into it.
Is there anyway y'all can help and give me advice on whether it needs to be timed differently and I'm also adding in a picture of what the #1 plug looks like just for help as well.
I do owe a big thanks for 67 c10 guy for coming over and helping me work on the truck and get everything set up good as new.
Here's pictures of the install from today enjoy guys
Korwin
Old 11-18-2013, 05:45 AM   #942
Jabes1
Jabes1's Avatar
I'm not sure what procedure you are using to time your truck...
1. Warm the truck up to operating temp.
2. Pull your vacuum advance hose from the carb and plug the port on the carb.
3. Utilizing a timing light, see what you have the timing set at. (If you set the timing with the vacuum advance hooked up to the carb you are running your timing super retarded.)
4. Loosen the distributor clamp. Advance the timing 12 to 14 degrees initial. (I ran mine at 14 degrees advanced initial, so once you hook up your vacuum advance canister you will have about 26-30 degrees of advance/ ignition lead at idle.)
5. Tighten down the distributor clamp, recheck your timing and reconnect your vacuum advance canister.
You can also recurve your HEI distributor, which will wake up your truck. I used the lightest springs in the kit and my advance was all in by 2000 RPM. Its personal preference for you as well as if your engine will tolerate it. Some people like these kits, some don't. I guess I just want to see you get your truck running so you can start to make some real progress. Your plugs indicate you are running rich. You could safely jet down your carb, but that's a whole other story.... Good luck, hope this helps tremendously!!!
Old 11-18-2013, 06:09 AM   #943
Jabes1
Jabes1's Avatar
Well it looks like new throttle cable it'll have to be. Here's the pictures from today
Looking at your carb install and the way you mounted the cable to the carb concerns me. You should not need a shorter cable. Edelbrocks/Carter's are pretty much a direct swap. That plastic piece that covers the cable behind the sleeve that mounts to the throttle lever can be troublesome and jam things up. You can remove that plastic safely.
The cable should not be bolted to the throttle lever so that it is forced to be in a fixed position. The ball at the end of the bolt your using is supposed to be a pivot point for the linkage so that it has freedom of movement. Your throttle cable is supposed to snap onto that ball. I suspect this is part of the problem. The big hole where you have your return spring is where the throttle cable is supposed to go. Next... If I were you I would find another place to put that throttle return spring, it looks like an accident waiting to happen as in it popping off due to the amount of stretch you're putting on it. Also with the truck shut off, take off the air cleaner, look down the carb while having a buddy press all the way down on the gas pedal, verify that the gas pedal is opening the butterflies all the way.
Old 11-18-2013, 09:44 AM   #944
77ChevySharkBite
Thanks Jabes!
I always before I messed with timing got the truck to operating temp before I did anything.
On revurving my HEI I think I might wait on that, just for the simple fact I really would like to get the truck running as "flawless" as can be and then I'll tinker with other parts as well.
We left the cord on that carb port but had it plugged so does that matter? Also should I/we have plugged the vacuum advance canister? Or is that fine to stay unplugged?
Korwin
Old 11-18-2013, 09:50 AM   #945
77ChevySharkBite
Yes I thought it was going to be a direct swap myself but on the intakes ended up comparing them the original intake manifold just sits about an 1' further forward which the cable would of been fine.
As far as the throttle cable goes I'm not saying I'm right about it, but it does have free movement I haven't had any issues with it thus far it's hard to see maybe but it does indeed have a clip at the end to allow free movement. As the throttle return spring yes I'm not happy about where it's at I do plan on moving it to give it a more safer location once I get all of this figured out. Alright I'll have to check it out.
Thanks for the helpful advice I greatly appreciate it!
Korwin
Old 11-18-2013, 10:34 AM   #946
knomadd
knomadd's Avatar
I just watched the videos you posted and I can't really hear anything wrong with it on either video. I do notice your idle rpm sounds higher on the 0 degree video. If you're thinking the engine sounds like it's not running right because of the different engine speeds, try adjusting your idle speed to about 800-1000 RPM in park or neutral at any timing setup. Tap the throttle a couple times to make sure it seats and recheck timing and idle RPM. When you put the truck in gear, it should be idling around 600-800 RPM (higher if it doesn't like to run that low, but usually just under 1000 RPM).
If your idle RPM is different with the different timing setups, you won't really be able to tell which runs better. If Idle is too low, the engine will sound like it wants to die.
Hopefully I'm not missing something in the videos your trying to get us to hear.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 11-18-2013, 10:38 AM   #947
77ChevySharkBite
I'm not sure if you watched but the 3rd video is just to tell me pushing down the gas and it's at 8 degrees advance, maybe I'll have to retake some videos and get closer to the exhaust and carb, but is it just me or does it sound like it has a sputter?
Korwin
Old 11-18-2013, 10:44 AM   #948
knomadd
knomadd's Avatar
I watched all three videos. I can hear the lope of the cam, but I don't notice a sputter or stumble. Maybe I just can't hear it in the video. I'm at work so I can't turn it up really loud.
-Duane
Old 11-18-2013, 10:53 AM   #949
77ChevySharkBite
Yeah it's all good no worries Duane, my only issue still what seems odd to be is that at 0 timing it turns over fine but now I will admit that on 8 degrees advance it's not as bad still takes about half a crank to start but not horrible like it once was so maybe I should kick it to about 6 degrees advance?
Korwin
Old 11-18-2013, 11:21 AM   #950
knomadd
knomadd's Avatar
Without being there and seeing exactly what's going on myself, I can't give you an honest opinion on what you "should" do. All I can say is set it where you think it runs best. If you notice small issues when its running/driving/starting/shutting off, then you may tweak it some more until you get it just right. If timing isn't fixing the issues, then it might be something more.
-Duane
