11-07-2019, 06:53 PM | #926 |
Old member
Re: What did you do to your truck today.The 3rd chapter
Refurbed the dash for my daughters 68 truck today.
Took it a part and cleaned it and painted the iside Chrome spray paint. Installed new LED bulbs. I used pipe wrap and put inside for the lens cushions and also to block out the light from bleeding through. I used black tape around the steering column area to stop it from shinning through there as well. They also dim down. https://www.youtube.com/watch?v=FYEE6VDmwo0
11-08-2019, 12:07 AM | #927 |
Still Green but learning
Tanks in, put in the driver's side shoulder belt, found some rust under the carpet I need to look and paint.
Gonna try to button it all up tomorrow.
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
11-08-2019, 01:01 AM | #928 |
At the body shop.
Does this count?
Hauled our pops 78 stepper cab with his 68 to the shop that is doing his restoration.
" That didnt make it any newer " " Dont antique the equipment " |
11-08-2019, 09:45 AM | #929 |
I'll count it
11-08-2019, 11:06 PM | #930 |
I installed new grill moldings and headlamp bezels.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
11-09-2019, 12:53 AM | #931 | |
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
11-09-2019, 09:51 AM | #932 |
Visited the K10 shorty at the paint shop. Getting closer.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
11-09-2019, 08:48 PM | #933 |
Old member
Thanks we got the cab off the LWB frame also and have the short frame sitting in the waiting area. We started blasting some small parts for it after I fixed the blaster cabinet.
11-11-2019, 09:52 AM | #934 |
Guest
Posts: n/a
It was a good weekend. My springs showed up. The big girl is gettin down.
11-11-2019, 10:57 AM | #935 |
May sound crazy to some but I skipped opening weekend of modern gun deer season to get the rear frame section rust encapsulated and painted. Not sure she I’d see another two days in a row of 65-70 degree weather.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
11-11-2019, 11:13 AM | #936 |
That color looks great!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
11-11-2019, 11:25 AM | #937 |
Got the freshly rebuilt TH400 put back in the truck yesterday. My body realizes it today.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
11-11-2019, 08:41 PM | #938 |
That old girl is looking good!!!
11-12-2019, 08:47 AM | #939 |
Nothing as exciting as many of yours, but I did get some general stuff done that I wanted since I bought the truck.
Changed plugs, wires, cap and rotor. Converted points to Petronix Ignitor III. Did my best to keep factory look and thanks to advice here, kept the factory wiring (just wrapped it all up) in case I want to go back to original. Put the all the parts in a box and leave them in the truck. Also, thanks to great advice from this board I changed my glass fuel filter to a metal one.
1968 C-20 CST Vermillion http://imageevent.com/happy_dan/dantoys/68c20 2019 Silverado 2012 Camaro ZL1 |
11-12-2019, 09:24 PM | #940 |
Wiped down the smooth exhaust manifolds with some solvent, blew dry with air and got a couple coats of high temperature cast iron paint.
11-14-2019, 06:31 PM | #941 |
I switched from my summer wheels and tires to my "snow" wheels and tires today. I don't store the old girl for the winter but drive it whenever it's decent outside
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
11-16-2019, 01:24 AM | #942 |
Nice..I posted about the same on my Blazer yesterday in the blazer forum. I made a panel to cover the gap in front of my radiator and behind the core support .
11-16-2019, 05:46 PM | #943 |
Got my Truck back from the Painter.
11-16-2019, 06:31 PM | #944 |
11-16-2019, 07:33 PM | #945 |
Old member
That sir is a good looking truck!
11-16-2019, 07:51 PM | #946 |
Old member
I did some painting of small parts and I did some grille work on the 68. I think it's going to be fine once I clean it up and sand it down and primer it. The ramp truck makes a nice work area to by the way.
Oh I fixed my neighbor's tail lights for him on his 94 truck. He had no tail lights when he showed up. When he left he had all his lights working. I had to work on the spot light on the ramp truck to it wouldn't come on. Had to take it a part and clean the contacts inside the light fixture and inside the handle. I also sprayed it down with lithium grease to make it move better.
11-16-2019, 08:52 PM | #947 |
-Chris
Installed the transmission, radiator and power steering hoses. Also installed the transmission dipstick, new filter and new pan cover.
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt. BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481 2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's 2017 Chevy Suburban (Wifes Car) - Fully Loaded & Stock "Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem." Ronald Reagan, President of the United States; 1985 |
11-17-2019, 12:08 AM | #948 |
Installed wiring harness today in hopes of test firing my engine. Also I temporarily installed the cab and front clip to ascertain where my computer, airbox, and battery will eventually go. I’m not sure if I want more of a factory look or a custom look under the hood.
Man, it feels good to look at something that resembles truck instead of only pieces of a truck!
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
11-17-2019, 07:51 AM | #949 |
This week I wet sand and buffed the truck. Yesterday I painted the seat cover for now. I struggled with a color to eventually do my seat. I think black leather would be fine.
11-17-2019, 08:55 AM | #950 |
What year are those saddle tanks off of?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
