Old 06-14-2013, 06:14 PM   #951
gdavis
gdavis's Avatar
Re: 1968
I just can't stand to be idle, it is to bad that my gas tank is some where but here. Now it liiok like the 17th. I did paint the tailgate today. omorrow I am planning on installing a longet bolt on the rubber motor mounts. I am afraid of the distance between the header and the perch. only about 1/2 inches. Then I will add some washers or a spacer on each side to bring up the motor. Just a little insurance if the mounts give any.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 06-15-2013, 12:49 AM   #952
Bomp
Bomp's Avatar
Re: 1968
Gate looks really good.
You've whirled that paint gun enough you ought to paint the whole truck yourself.
Great job
Bomp is offline   Reply With Quote
Old 06-15-2013, 02:22 PM   #953
gdavis
gdavis's Avatar
Re: 1968
Great job
I am going to paint my own truck. If I can paint and repair 18,000.00 harley Davidson I sure can paint this 100.00 truck. This truck is like a hardley Davidson. The HD in Harley Davidson means H= hundred D= dollars You can't do anything on a harley that it don't cost you a 100.00 and this truck seems like the same thing. But on the lighter note thanks for the vote of confidence. I had to quit riding the harley because of my back. I need 4 wheels rather than 2 in my old age.
Check out Patches
Old 06-15-2013, 02:41 PM   #954
gdavis
gdavis's Avatar
Re: 1968
also painted items in my inventory. and my new grandson
Check out Patches
Old 06-15-2013, 10:45 PM   #955
Mustard72
Mustard72's Avatar
Re: 1968
Grandson doesn't look painted to me.
Did you do a search on the gas tank thing? With the scores of folks that have done this same type of thing, I'd think that info would be out there somewhere.
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 06-16-2013, 04:30 PM   #956
gdavis
gdavis's Avatar
Re: 1968
No I have not done a serch on the sending unit. But thanks I will try that.Someone said that both o-rings go on. Still looking maybe someone has done it here
Check out Patches
Old 06-16-2013, 05:03 PM   #957
cubber
Re: 1968
Hey, George! Paint work looks good. I should have asked you to paint that tailgate! Haha. When I put my new gas tank in, it only had the o-ring with the little tab on it, but my tank was the metal one. What company sells that tank? Also, what did you decide to do about a power steering pump?
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 06-17-2013, 08:06 AM   #958
gdavis
gdavis's Avatar
Re: 1968
I am still looking for a pump with the pulley. As far as the o-ring still haven't found the instrutions for installing the sending unit.
I don't know who sold the tank. I bought it from a guy that changed his mind. About using it I guess.
Check out Patches
Old 06-17-2013, 08:10 AM   #959
Low Elco
Re: 1968
Work looks great, George! Keep it up!
Low Elco is offline   Reply With Quote
Old 06-17-2013, 04:59 PM   #960
72bowtiestepper
Re: 1968
Real nice work George from a fellow "Old guy". We can show those youngsters a thing or two anytime ! I am hip deep in my 72 short stepside project and definetly like to "do it all myself" like you. Best of luck finishing up your truck !
Glenn
72bowtiestepper is offline   Reply With Quote
Old 06-17-2013, 06:00 PM   #961
gdavis
gdavis's Avatar
Re: 1968
Glenn
thanks a lot guy for coming by and looking at my build. I have done all of this myself
Check out Patches
Old 06-17-2013, 06:00 PM   #962
gdavis
gdavis's Avatar
Re: 1968
thanks so much
Check out Patches
Old 06-17-2013, 08:10 PM   #963
cubber
Re: 1968
Just plug the extra. As long as you have 1 vent, it's ok. Also, does that metal ring that the sending unit ring snaps under come off? If so, one of those rings (the smooth one) might go there.
=MATTHEW
Old 06-18-2013, 05:51 PM   #964
gdavis
gdavis's Avatar
Re: 1968
Hey guys here are the instructions for installing the sending unit in a poly tank #2042 and more
http://www.mtscompany.com/images/jeep/tabsheet.pdf
http://www.mtscompany.com/images/lockrings/gmor-2.jpg
http://www.mtscompany.com/images/lockrings/jwlr-1.jpg
Check out Patches
Old 06-18-2013, 06:18 PM   #965
gdavis
gdavis's Avatar
Re: 1968
I didn't do anything on my truck today. Just took it easy and trying to get motivated a little. To hot here to work.
But, I guess I did do something. I made a deal with a fellow board member on a black dash pad and a set of black arm rest. They look real sweet
Check out Patches
Old 06-19-2013, 04:16 PM   #966
gdavis
gdavis's Avatar
Re: 1968
I had to take it easy today. My blood sugar dropped to 38. That is way too low.I was seeing black spots and my vision was fuzzy. So now I am down untill I get it up to at least 100. Maybe tomorrow I can do something. I need to run my gas lines and finish my brakes lines.
Check out Patches
Old 06-20-2013, 01:07 AM   #967
cubber
Re: 1968
Hope you feel better, George.
=MATTHEW
Old 06-20-2013, 02:53 PM   #968
gdavis
gdavis's Avatar
Re: 1968
Today I over sleep due to my sugar count. It is coming up. But on a lighter note. My drive shaft came in today. I pulled all three u joints off and I will sand blast the shaft after it cools off a bit. around 6.oo. I have to change the yoke on the transmission side. It seems that 72 has smaller yoke than the 68. And 1 1/2 inch shorter. But it will still work. I now need to figure out the center carrier bearing support for the drive shaft. My 68 did not have it. If anyone has a 2 piece drive shaft could you take a picture of the cross member. So I will know where and how to make one.
Check out Patches
Old 06-20-2013, 08:51 PM   #969
gdavis
gdavis's Avatar
Re: 1968
I sand blasted the two piece drive shaft, primed and painted the first coat of gloss black. It came out rea nice. Now I need to get three u-joints to put it back together. I need a lot on motivation. Not getting much done it seems like.
Check out Patches
Old 06-20-2013, 10:36 PM   #970
Mustard72
Mustard72's Avatar
Re: 1968
Post 171 in my build thread has a pic of the cross member with the 2 piece drive shaft still installed. That one has the larger midship bearing that mounts to the bottom of the cross member.
Nick
Old 06-21-2013, 10:32 AM   #971
gdavis
gdavis's Avatar
Re: 1968
I seen it on post 171 and now I see what it attached to and thanks.
Check out Patches
Old 06-21-2013, 05:14 PM   #972
gdavis
gdavis's Avatar
Re: 1968
Today I painted the drive shaft. And did some clearing out of old parts. Took them to the salvage yard to make some new fords.
Check out Patches
Old 06-21-2013, 05:16 PM   #973
gdavis
gdavis's Avatar
Re: 1968
drive shaft
Check out Patches
Old 06-22-2013, 11:04 AM   #974
gdavis
gdavis's Avatar
Re: 1968
I had to remove the spark plugs today to turn the motor over. I have a lot of compression on this enging. I need to get my started looked at to see if it is strong enough.
Check out Patches
Old 06-22-2013, 01:56 PM   #975
Bomp
Bomp's Avatar
Re: 1968
Nice job on the drive shaft.
Your starter is probably okay, the battery cold cranking amps makes the difference. just my .02
