Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 04-22-2005, 02:01 PM   #76
jon johnson
For you that have put the blazer tanks in do you put the lines back in that go to the canister in the engine compartment ?
72 chevy super cheyenne
70 4x4 project blazer/F.S
66 chevelle
56 chevy sedan delivery
57 pontiac safari wagon
jon johnson is offline
Old 04-23-2005, 05:53 AM   #77
willow72
willow72's Avatar
if you decide togo with the stock blazer tank for our trucks be warned you are going to have too notch a cross member on the bottom of the bed if you have a steel bed which can be pretty hard if you dont plan removing the bed if you have a wood floor in your bed you can just remove the cross member i wish sombody would have warned me about this
willow72 is offline
Old 08-15-2005, 07:18 PM   #78
old gearhead
I moved mine 'cause I got tired of the smell of gas inside my cab and spilling down the side of the cab after a left turn following a fillup. I guess I'm just getting old and prissy.
1969 1/2 ton CST the never-ending project!!
350
muncie m21 4 spd
3.73 posi
and a box of extra bolts
old gearhead is offline
Old 08-15-2005, 09:47 PM   #79
ChevyMex
ChevyMex's Avatar
So, we need to be afraid of drunk people in the road instead of the fuel tank in the back. The trucks with the fuel tank in the chassis in this type of collision have more probabilty to find a spark than the ones inside of the truck.
ChevyMex is offline
Old 08-15-2005, 10:16 PM   #80
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Well I dont plan on driving mine much, so I put the tank in the back, I ran the cannister with all new lines, the crossmember will be cut, but i hate to the spilling of fuel after filling it up and turning even replacing the gas cap twice a year. piss poor tank design. oh well......
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline
Old 08-16-2005, 08:46 PM   #81
Kas68c10
Kas68c10's Avatar
i bought the tank from GMC paul, got the straps made and sending unit from a salvage yard....Tank holds over 20 gallons..22 i thhink..i also have a smaller 12 gallon tank that is the depth of the frame rails if someone wants it,would be good for a lowered truck that doesnt get driven a whole lot...or if you dont mind fillin it all the time...
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline
Old 08-18-2005, 03:16 PM   #82
GlennBrittain
I plan to put the tank in the bed on the daily driver I am building. I will put my spare under the bed. I have not contacted this vendor yet, so I only know what thier site states. http://www.auxtank.com/auxtank/home.asp
GlennBrittain is offline
Old 08-18-2005, 03:43 PM   #83
Joe67
67 is sold
Interesting tanks. Is there any issue having them bake in the sun all day?
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline
Old 08-22-2005, 09:14 PM   #84
GlennBrittain
None that I know of. They are faily common for fuel transfer tanks.
Old 10-06-2005, 01:41 AM   #85
bs25j
bs25j's Avatar
How tough is it to build a fuel cell. I dont really know what kind of technical stuff is in the cell but 400 dollars seems like a lot of money for a tank.
bs25j is offline
Old 10-06-2005, 12:56 PM   #86
71swb4x4
71swb4x4's Avatar
I looked at building my own, but after materials, time, and peace of mind it was an easy choice to get a Fuel Cell Guy tank. It mounted easily, and was literally plug and play.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline
Old 10-07-2005, 12:54 AM   #87
72Short_Cut
72Short_Cut's Avatar
LMC's rear gas tank sucks, don't get it. it hangs way to low and looks like crap.
1972 Chevy Short Box
Ls1 swap
1977 chevy Chevette
72Short_Cut is offline
Old 10-19-2005, 10:09 PM   #88
BubbaGreen
Re: Rear Fuel Tank swap
Let me add my opinion....since it IS worth so much. :-)
First off, the blazer replacement will force you much work....the 1-3/8" filler
and the fact that if its intended for a fleetside bed, major modification of the underbed support rail.
The ECE version may seem pricey in the beginning, but...in the end you will be happy with it. 2" filler tube (at least for a side fill set up) Bolt right in using the stock holes (if a short bed will require removal of the original frame cross member, and the include a nicely made replacement) You can also specify carb or fuel injection (my recommendation, get the fuel injection version....it can be used with a carb and gives you the option of upgrading later) Comes with a 0-90ohm fuel level sending unit made by VDO. Holds 22~23 gallons. Made out of stainless, so it wont rust.
Here are a couple of pics I have of my install. Only thing I requested on the tank is a 1/2" NPT bung installed apprx 2" in front of the side fill port, for the vent during refueling to prevent backfill issues. (this is non-standard to the ECE, special request) The filler door is from an S-10, not sure of the year.
here are a coulpe of links (since I cant figure out how to add pics anymore)
http://www.prismnet.com/~grzanich/ECE_FuelTank.JPG
http://www.prismnet.com/~grzanich/71...iller_door.jpg
Will be glad to answer any questions in regards to this.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline
Old 10-19-2005, 10:20 PM   #89
boraxman
Keepin an eye out
boraxman's Avatar
Originally Posted by lock
I have the ECC FI version.. not cheap but its a very nice product.
Is that a ECE hidden hitch..looks tight, did you have to mod anything?
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline
Old 10-21-2005, 11:37 AM   #90
matthufham
i got my relocation kit from gmcpauls. it's the poly version and so far i love it.
matthufham is offline
Old 10-21-2005, 01:57 PM   #91
BigMike
BigMike's Avatar
Originally Posted by MACKL
I installed the marker light fuel filler and love it too.
Where do I find more information about the side marker fill conversion??? I have tried searching for it but nothing comes up.
Mike
BigMike is offline
Old 10-21-2005, 04:02 PM   #92
70rs/ss
70rs/ss's Avatar
Originally Posted by junkyardjohn
JOHN FABRIS-- IN 1977 I WAS HIT BROADSIDE AT AN INTERSECTION BY A DRUNK DRIVER (I WAS DOING 55 OR 60) CAUSING ME TO ROLL END OVER END IN MY 72 3/4 TON FORD. AFTER ROLLING ABOUT 80 YARDS, I STOPPED WITH THE TRUCK UPSIDE DOWN WITH MY HEAD PINNED TO THE GROUND. IT STOPPED IN A LITTLE DEPRESSION IN THE GROUND, & EVERYTHING WAS FROZEN(IT WAS DEC. 23rd IN MICHIGAN). THE BEHIND THE SEAT TANK WAS JUST FILLED. IT SPLIT, & ALL OF THE GAS DUMPED OUT OVER ME, & ALMOST DROWED ME IN GASOLINE, AS MY HEAD WAS PINNED TO THE GROUND. I WAS PINNED IN THE WRECKAGE FOR ABOUT 20 MINUTES, I HAD PLENTY OF TIME TO PONDER THE PLACEMENT OF SUCH A FUEL TANK. THE ONLY REASON IT DIDN'T CATCH FIRE WAS MY BATTERY WAS THROWN OUT DURING ONE OF THE ROLLS. LUCKY ME-- I GOT OUT OF IT WITH A BROKEN BACK, 14 BROKEN RIBS, A BROKEN COLLAR BONE & ABOUT 300 STITCHES ON MY MELLON. SO YA .... IT IS KINDA A SAFETY THING. I CONSIDER THESE TANKS A BIG BOMB BEHIND THE SEAT ALSO. THE REASON YOU DON'T HERE ABOUT ALOT OF THE PROBLEMS WITH THEM IS THAT MOST OF THE PEOPLE WHO EXPERIANCED PROBLEMS WITH THEM ARE DEAD. JOHN
As if this weren't reason enough, smelling fuel is not good for you either! I am going to do the swap for the above reason and that I once had a 67 (years ago) and it leaked fumes into the truck regularly and I need all the brain cells that survived college so Blazer tank here I come. I may even fab one up myself. I have access to a TIG welder and I can buy the SS, I plan to run an LT1 and need the intank pump.
mike
70rs/ss is offline
Old 10-21-2005, 06:36 PM   #93
matthufham
Mike
that's a beauty in your avatar!
http://67-72chevytrucks.com/vboard/s...699#post599699
stepsides will be this easy. fleetsides are trickier
go here for the fleetside install
http://www.classicheartbeat.com/mark...t_gas_door.htm
Old 10-21-2005, 07:29 PM   #94
Striker169
Car O'Holic
Striker169's Avatar
Didnt someone on here put the filler neck though the rear post hole on the back of his truck?
Also I was wondering would it be possible to have 2 reasonably sized tanks in our trucks? One behind the wheels and one infront? I was wanting to do this (454 gets like 9mpg want to be able to go somewhat far without refilling) but having the filler necks in the driver side corners on the front and back.
Do you get what im saying?
Striker169 is offline
Old 10-21-2005, 11:49 PM   #95
BigMike
BigMike's Avatar
Thanks...Too bad it is only a 1/8 scale RC truck body that I custom painted (I do that as a hobby)
Mike
P.S. Thanks for the links...I had found the stepside version but not the fleetside.
BigMike is offline
Old 10-22-2005, 12:04 AM   #96
qksilver
Who is fcg? Do they have a web site?
Thanks,
Steve
qksilver is offline
Old 10-22-2005, 08:47 PM   #97
matthufham
too bad there's a driveshaft in front of the axle. they make saddle tanks to go on the sides. don't ask me where they're sold, because all the one's i've seen are originals.
@big mike
again here's a fleetside installation of the sidemarker filler.
Old 10-23-2005, 03:58 PM   #98
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
Thanks,
Steve
(fuelcellguy) he is a member of this board. if you do a member search you can find him
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline
Old 10-24-2005, 02:13 PM   #99
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
Here's a link to his website
http://www.aluminumfuelcell.com/index.html
68? It's all figured out untill you get it apart.
Is it Sunday yet???
68 Project
68 SWB frame off/98 Vortec with stock FI/power everything.
95 ECLB 2500 with 346,000 on the clock(the original HD)
99 Lesabre-wifes ride
08 Crew Cab LTZ-All Mine
89 SWB 5/7 drop-Son's first ride.
TEXAS 68 is offline
Old 11-05-2005, 01:57 PM   #100
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Hi Lock.. I have the ECC tank and hitch forr my truck in the basement ready to install next spring. What are you going to do for a gas tank filler? Maybe by now you have it done and could post some pics of what you have for that. I also notice you have a Super Track bar , did you get that from ECE as well? What ,if any, suspension plans do you have for the truck. I'm planning a 2 1/2 drop spindle with a 1" front dropped coil and 5 coil drop in the rear with the Super Track bar & shock relocaters.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
