Old 07-03-2007, 03:39 PM   #76
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: 72 2wd blazer build
Yikes, I guess it will lay frame eh?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-03-2007, 03:47 PM   #77
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I've always wondered why more people don't raise the wheel wells like that rather than use those lame store bought round tubs. The raised wheel wells look so much better in the bed IMO.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-03-2007, 05:06 PM   #78
bagged74
its just $$$$$
bagged74's Avatar
Probably becuase, as I found out yesterday, its alot of work...lol
bagged74 is offline   Reply With Quote
Old 07-03-2007, 05:07 PM   #79
bagged74
its just $$$$$
bagged74's Avatar
No it wont quite "lay frame" just gotta make room for a 22x10 with a 285/35/22
Old 07-10-2007, 11:45 PM   #80
bagged74
its just $$$$$
bagged74's Avatar
Here are a couple of teaser pics. Raising the stock wheel wells has turned out to be alot more work than I originally thought, But I am getting a little closer to being finished.
Dont mind the messy shop..
Old 07-11-2007, 12:06 AM   #81
72CSTC5
72CSTC5's Avatar
Damn that looks Nasty clean! What are the specs on the wheels and did you cut any of the floor towards the frame for the 22x10's
72CSTC5 is offline   Reply With Quote
Old 07-11-2007, 12:07 AM   #82
72CSTC5
72CSTC5's Avatar
Oh I just spied the chevy dash in there. 55, 6, or 7?
Old 07-11-2007, 12:12 AM   #83
bagged74
its just $$$$$
bagged74's Avatar
No I didnt have to cut anything on the inside, but I will tell you that a 22x10 is a really tight fit. I actually might have to narrow the rearend slightly. When I measured for the wheels I was concerned with rubbing on the lip of the wheelwell, well I have clearance there( after some creative rolling) but it looks like with a tire on it it may rub the the quarterpanel where it rolls in at the top......only if I were t drive it at full dump.........would I ever do that?????? probably
and thats a 55 dash, but not for long
Old 07-11-2007, 12:20 AM   #84
72CSTC5
72CSTC5's Avatar
Remove your wheel tub and then grind out the spot welds of the inner quarter panel in there and make it flat and then a small arch at the top so the tire will not rub on the inner "filler" of the quarter panel. Try that and see if it works for you.
Old 07-11-2007, 12:23 AM   #85
bagged74
its just $$$$$
bagged74's Avatar
Oh the inner filler is way gone......
Old 07-11-2007, 12:34 AM   #86
PBFAB.COM
PBFAB.COM's Avatar
The mock-up pics look awesome! For some reason this is the part of building these things that I like the most... once they're all done and shiny you can't see all of the cool, hard work that went into them (at least most people can't). BTW that dash is going to look GREAT in there!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 07-11-2007, 12:39 AM   #87
72CSTC5
72CSTC5's Avatar
Yup, looks like that is not going to work. Could you send the rear wheels back and go 5.5 on the backspacing?
Old 07-11-2007, 12:43 AM   #88
bagged74
its just $$$$$
bagged74's Avatar
Thanks man, It should look even better when I get a dropmember in the front.
It will work, I have a plan. I would rather not send them back I LOVE the look of the deep lip on that wheel.
Old 07-11-2007, 12:47 AM   #89
72CSTC5
72CSTC5's Avatar
Let me know what you have planned as I want to run 22x10's on all 3 of my projects.
Old 07-11-2007, 12:55 AM   #90
bagged74
its just $$$$$
bagged74's Avatar
I cant confiirm it till tomorrow, but Im almost positive that an earlier 6 lug housing is about 1"-1.5" narrower. I have one over at my dads shop. I will measure it tomorrow, if so I will buy new axles or redrill to 5x5
The easier solution would be to order the right backspacing from the get-go, but that would be way too easy for a guy like me.
The 5" backspacing would actually work if my truck wasnt as low, it would be fine with a bolt-in notch.
Old 07-11-2007, 01:01 AM   #91
72CSTC5
72CSTC5's Avatar
If you do not mind post if that is true and I will just finish building the posi unit rear end for my blazer and throw it under my truck.
Old 07-11-2007, 01:40 AM   #92
gringoloco
A guy with a truck
gringoloco's Avatar
'Tis true. Look here.
Also true. I'm running a 20x10 with 295s and it is OK with c-notch.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-11-2007, 01:49 AM   #93
bagged74
its just $$$$$
bagged74's Avatar
Thank you, just as I had suspected.
Old 07-11-2007, 02:21 AM   #94
GREASEMONKEY72
GREASEMONKEY72's Avatar
looks pretty sweet, cant wait to see more of it
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 07-11-2007, 01:52 PM   #95
crzngmychvy
"1972 C5"
crzngmychvy's Avatar
That is looking great!
I think it would really be something if all the 2wd blazer people got together for a cruise and a few pics.
- 72 2wd Blazer ...sold...
2wd Blazer Page
crzngmychvy is offline   Reply With Quote
Old 07-11-2007, 02:17 PM   #96
bagged74
its just $$$$$
bagged74's Avatar
just name the time and place. I plan to drive this on vacation with my wife and kids next summer. Possibly to San Diego
Old 07-11-2007, 02:41 PM   #97
Simonstrucker
Big Block Short Bed Stepside
how close dos the front wheel com to the lip of the inner fender.
Simonstrucker is offline   Reply With Quote
Old 07-11-2007, 05:17 PM   #98
72CSTC5
72CSTC5's Avatar
That would be trick but uhhhhhhhhhh, I don't think I would drive mine that far and in the blowing sand and all down the highways.
Old 07-11-2007, 06:46 PM   #99
1LoC10
Insert Title Here
1LoC10's Avatar
that looks really sweet.. good job
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 07-11-2007, 07:22 PM   #100
hyde
hyde's Avatar
You know who also wants to run Big rollers....Carlos take notes...lol...
06 Crew Cab GMC[/B] on 22's
07 Duramax 4x4 Lifted Maxed Out!
1972 2WD K5. 89k miles. Soon to be bagged, LS1 and bad!
1967 Short and Wide. Soon to be an LS1 and bagged
hyde is offline   Reply With Quote
