Old 03-25-2007, 08:03 AM   #76
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: progress pics
Jared, I'm definitely interested in seeing pics of that as I'm getting ready to put my 1.5" sectioned crossmember in my 67.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 03-25-2007, 08:12 AM   #77
jlaird
jlaird's Avatar
Re: progress pics
Originally Posted by Jaredm82 View Post
Thats what I did. My crossmember is sectioned 1.75" and thats how much I moved all my steering up. We just basically sliced the side off the frame off and raised it 1.75" and welded it back together. Then reinforced the crap out of it!!! I can maybe get pictures tomorrow when Im working on my truck...
If you could get pictures that would be great. I looked at raising the steering box and all but the problem I saw was the pitman arm and idler arm hitting the bottom of the frame when your fully turned. Are you notching for this or raising the entire section of the frame for clearance. I guess a pic would show it best.
jlaird is offline   Reply With Quote
Old 03-25-2007, 10:09 AM   #78
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: progress pics
Im gonna use this set-up for mine.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-25-2007, 04:12 PM   #79
jlaird
jlaird's Avatar
Re: progress pics
Yea, the steering linkage is the easy part. We are all mainly concerned with the tie rods, idler arm, pitman arm, etc...
Old 03-26-2007, 12:24 PM   #80
XXL
Seņor Member
XXL's Avatar
Re: progress pics
Hey, don't use that set-up... I need it to steer my truck!
XXL is offline   Reply With Quote
Old 03-26-2007, 01:08 PM   #81
jlaird
jlaird's Avatar
Re: progress pics
hey XXL, how much is your crossmember sectioned? Do you have pics of the steering clearance "problem areas"?
Old 03-26-2007, 01:36 PM   #82
Jaredm82
Active Member
Jaredm82's Avatar
Re: progress pics
I am going out to work on my truck right now. I will get some pics for you guys in a bit..
Jaredm82 is offline   Reply With Quote
Old 03-26-2007, 05:33 PM   #83
Jaredm82
Active Member
Jaredm82's Avatar
Re: progress pics
Here are f ew pictures of my steering set up. Worked great for a few thousand miles already accept for the steering shaft. It used to have a rag joint but I have since replaced it with a second u joint. My crossmember is sectioned 1.75" and my steering is raised 1.75" as well. I also lowered my cab mounts 1". The tilt column is out of an early 70's gm van and I raised it up as much as I could by cutting into the firewall. Everything works well and there are no signs of cracking...
Old 03-26-2007, 05:50 PM   #84
XXL
Seņor Member
XXL's Avatar
Re: progress pics
1.5" section. There was only small clearance issue... see pics here.
Old 03-26-2007, 06:21 PM   #85
smbrouss70
smbrouss70's Avatar
Re: progress pics
XXL or anyone else who has done this crossmember mod, have you noticed any negative (or positive) effects on the bump steer? Jared, I'm sure yours is the same as before since you raised your linkage also.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 03-26-2007, 06:50 PM   #86
FRENCHBLUE72
PROJECT 7DEUCE
Re: progress pics
ken you better check you ride I think you maybe missing some parts.
MEMBER #6377
Project "7DEUCE"
Old 03-26-2007, 06:52 PM   #87
FRENCHBLUE72
PROJECT 7DEUCE
Re: progress pics
I should have the steering linkage on tonight.
MEMBER #6377
Project "7DEUCE"
Old 03-26-2007, 07:00 PM   #88
jlaird
jlaird's Avatar
Re: progress pics
I hope that is the case with me. I'm just preparing myself for the worst.
Jared, thanks for the pics. Makes sense now.
Josh
Old 03-26-2007, 07:26 PM   #89
jlaird
jlaird's Avatar
Re: progress pics
XXL, did you have "less" problems because you have tubulars?? Hmmmm
Old 03-26-2007, 08:48 PM   #90
jlaird
jlaird's Avatar
Re: progress pics
OK, something else to throw into the equation. Porterbuilt moved the centerline of the front suspension forward one inch to center the tire in the wheelwell. Has anybody reinstalled their stock crossmeber forward one inch?
Old 03-26-2007, 08:55 PM   #91
7deuce
Sold! 2 days after finished
7deuce's Avatar
Re: progress pics
I did mine 1 1/8 and I still had the problems that XXL is talking about. My bump steer is bad with out a sway bar. And there was some grinding on the X-member and steering components.
7deuce is offline   Reply With Quote
Old 03-26-2007, 08:58 PM   #92
Jaredm82
Active Member
Jaredm82's Avatar
Re: progress pics
oh ya, I moved my motor up and forward, I dont remember how much though...
Old 03-26-2007, 10:20 PM   #93
FRENCHBLUE72
PROJECT 7DEUCE
Re: progress pics
Looks like I have some grinding to do not bad though..
MEMBER #6377
Project "7DEUCE"
Old 04-25-2007, 09:24 PM   #94
jlaird
jlaird's Avatar
Re: progress pics
Finished my lower control arm mod. Came out really nice. Here are some pics of each step.
Old 04-25-2007, 09:32 PM   #95
XXL
Seņor Member
XXL's Avatar
Re: progress pics
You're going to want to reinforce that cardboard. Maybe some duct tape?
Old 04-25-2007, 10:14 PM   #96
jlaird
jlaird's Avatar
Re: progress pics
We can always count on you for those helpful comments!!! LOL!
Old 04-26-2007, 12:33 AM   #97
pissonNOS
senior member
pissonNOS's Avatar
Re: progress pics
just wondering what the advantage of this was? does it distibute the force better than just welding a cup into your cut hole?
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 04-26-2007, 01:42 AM   #98
PBFAB.COM
PBFAB.COM's Avatar
Re: progress pics
Looks like the bag will sit a little lower and not rub on the control arm.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 04-26-2007, 08:15 AM   #99
jlaird
jlaird's Avatar
Re: progress pics
exactly.
Old 04-26-2007, 09:19 AM   #100
XXL
Seņor Member
XXL's Avatar
Re: progress pics
4000+ posts and counting. Just think of all the help that's provided others *cough cough*
Arms look good, btw!
