Old 12-07-2009, 11:07 PM   #76
ol Curt
Junior Member
ol Curt's Avatar
Re: Tommys66 Build
Originally Posted by tommys66 View Post
picked up the frame today, had it powdercoated silver. This company charges $300.00 for any base color plus $125.00 for clear with sparkle or candy colors, plus the cost of sand blasting. So since I chose silver it had to be cleared because silver alone will not hold up to weather without a clear topcoat. Total cost of silver+clear+sandblasting= $585.00
Damn,
That's scary. I got a trailer JUST like that one. Same color, same bent fender. Mine is from a 62" mower deck sliding over it when loading!
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 12-08-2009, 09:11 PM   #77
tommys66
Re: Tommys66 Build
Originally Posted by tiggamonsta View Post
Nice design on the trans cooler. Do you have a pic of the whole unit? Are there any specs on how it compares to the ones you put in front of the radiator?
Here's some more pics of the cooler for ya. I don't have any specs on the unit, I just got the longest one that would fit on the side of the frame, figured it should be sufficient. This cooler is the dual pass design.
I love the smell of lead paint!
tommys66 is offline   Reply With Quote
Old 12-08-2009, 09:15 PM   #78
tommys66
Re: Tommys66 Build
Originally Posted by ol Curt View Post
Damn,
wierd
Old 12-08-2009, 09:43 PM   #79
198plus
198plus's Avatar
Re: Tommys66 Build
If you mount the cooler there, could be problems when sitting in traffic.....No air circulation from fans
I got a trans cooler the other day. Here is where I plan to mount it...
198plus is offline   Reply With Quote
Old 12-09-2009, 02:19 PM   #80
tommys66
Re: Tommys66 Build
Well, I thought about that, but you gotta take into consideration that the radiator is about 200 degrees when trying to cool this fluid. I might add a temp gauge, and if needed I can mount a small fan above the cooler.
Old 12-09-2009, 09:43 PM   #81
tiggamonsta
tiggamonsta's Avatar
Re: Tommys66 Build
Definitely do the temp gauge. At least then you know if it is working.
tiggamonsta is offline   Reply With Quote
Old 12-10-2009, 02:59 PM   #82
tommys66
Re: Tommys66 Build
mounted the trans cooler
Old 12-10-2009, 03:08 PM   #83
tommys66
Re: Tommys66 Build
The intake I am using is from a 99-02 model truck which had the fuel pressure regulator on the fuel rail, therefore it was required to run both a feed and return line to the tank. I swapped the fuel rail and crossover tube from a 05' model, which has the fuel pressure regulator at the tank. So I am going to use a corvette style filter/regulator and only have to run a fuel feed line, eliminating the long return line.
Old 12-16-2009, 07:12 PM   #84
tommys66
Re: Tommys66 Build
got some fittings for my trans cooler. I am going to use 6AN ss braided line. The transmission and the cooler both have 1/4" npt so I had to get adapters to go from 1/4" pipe to 6AN. 6AN is 3/8 line. The 6 is # of 1/16ths so 6/16 = 3/8
Old 12-25-2009, 01:33 PM   #85
tommys66
Re: Tommys66 Build
I wanted to see if I could install the an fittings without the expensive tools. It is possible, however, I did scratch the fittings a little. I will post some more pic of the finished product later.
Old 12-25-2009, 01:50 PM   #86
Rich 5150 69
Rich 5150 69's Avatar
Re: Tommys66 Build
Not sure of the price, check here. Seen this demo`d at a show.
http://www.koultools.com/
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 12-25-2009, 03:36 PM   #87
protrash64
Resistance is Futile
protrash64's Avatar
Re: Tommys66 Build
Cool build so far.......looking forward to more updates. Keep up the good work.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 12-25-2009, 04:45 PM   #88
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: Tommys66 Build
one thing you can do if you use a cressent, is to use a wash cloth or some kind of hand town to stop it from scratching it.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 12-26-2009, 01:14 AM   #89
tommys66
Re: Tommys66 Build
I wrapped the fittings in masking tape, then a wrap of electrical tape to try to keep from scaring the fittings. It helped, but i still scuffed them a bit. I put a piece of masking tape on the hose beneath the fitting and marked it so i could tell if the red part of the fitting pulled any while tightening the blue into it.
Old 12-29-2009, 06:32 PM   #90
Strodder
Daring to be Different
Strodder's Avatar
Re: Tommys66 Build
I don't know why those fittings don't come polished, or chrome. For a Race car it wouldn't matter, but to me I think it would look better.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 12-29-2009, 06:54 PM   #91
blackmopar
Re: Tommys66 Build
you can get em nickel, gold, or black plated for the most part these days through the jegs and summit catalogs
blackmopar is offline   Reply With Quote
Old 12-29-2009, 11:05 PM   #92
Strodder
Strodder's Avatar
Re: Tommys66 Build
I didn't know they came in those colors.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 01-13-2010, 06:33 PM   #93
tommys66
Re: Tommys66 Build
I installed a fuel pressure gauge at the intake. Got all the fuel line ran, along with installing a 1999 corvette fuel filter/regulator.
Old 01-13-2010, 06:39 PM   #94
tommys66
Re: Tommys66 Build
I had a drive-shaft made. It clears really well through the cross member. Total cost for the tube, ends, slip yolk, and u-joints = $298
Old 01-13-2010, 06:44 PM   #95
70 Suburban
Rods
Re: Tommys66 Build
whats that tank out of?
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 01-13-2010, 07:01 PM   #96
tommys66
Re: Tommys66 Build
1999 camaro. Had to trim the bottom of the frame rail about 1/2" on both sides, and made the hangers from escort straps.
Old 01-13-2010, 07:05 PM   #97
70 Suburban
Rods
Re: Tommys66 Build
hmmm i think i know where one is. I would like to know about the 08 sub tank.
Old 01-13-2010, 11:07 PM   #98
TimE
Hey Y'all!!
TimE's Avatar
Re: Tommys66 Build
Lookin better all the time.
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 01-15-2010, 08:33 PM   #99
tommys66
Re: Tommys66 Build
Got the trans cooler plumbed up. Used 6 AN line.
Old 01-15-2010, 08:36 PM   #100
tommys66
Re: Tommys66 Build
Can someone tell me which is the pressure and which is the return on this powersteering sector?
