Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 08-29-2010, 11:25 PM   #76
Captainfab
60-66 Nut
Re: Power Steering Adapter Plates
Well crap, that listing has expired. I guess I should have checked back here sooner. Thanks just the same Dean
Originally Posted by dean jendro View Post
Old 09-08-2010, 01:59 PM   #77
73737373
Pls send me a PM w/ordering info and installation instructions. Thanks. Jim
1968 Custom SWB, 327/3 speed OTC
1969 CST LWB, 402/400
1970 CST LWB, 402/400
1970 Sierra Grande LWB, 350/350
1971 Cheyenne LWB, 350/350
1972 Cheyenne Super LWB, 402/400
1972 Sierra Grande LWB, 402/400
1979 Silverado LWB, 350/350
1984 Suburban
1990 454 SS
1991 Silverado, X-cab, 4.3/5 speed Getrag
2005 Silverado Crew Cab
Corvettes: 75, 77, 78, 93, 96
73737373 is offline   Reply With Quote
Old 09-08-2010, 11:11 PM   #78
Captainfab
60-66 Nut
PM sent
Old 09-17-2010, 10:13 AM   #79
landarts
landarts
I have a 67 1/2 ton 4x4 that I would like to put a steering box from a 70 1/2 ton chevy pickup. Will this adapter plate work for the 4x4?
Jim
landarts is offline   Reply With Quote
Old 09-17-2010, 11:45 PM   #80
Captainfab
60-66 Nut
As far as I know mine will work on your '67 4x4. I have sold a few to guys that wanted them for the '67 & '68 4x4's and I haven't heard of any issues with using them in that application.
Jim
Old 09-26-2010, 04:20 PM   #81
knuckledragger
knuckledragger's Avatar
I need an adapter for my 65 c10.Please send me contact info.
Dan
knuckledragger is offline   Reply With Quote
Old 09-27-2010, 01:18 AM   #82
Captainfab
60-66 Nut
PM sent.....
Dan
Old 09-30-2010, 06:01 PM   #83
knuckledragger
Thanks capt!
Old 10-10-2010, 10:53 PM   #84
Touchdown67
Touchdown67's Avatar
Hello Captain Fab. I have a 65 c10 2 wd that I am looking to upgrade to power steering. I see your adapter plates I think I need one of these. I was also wondering if you can give me any info on the rest of the parts needed or where is the best place to find parts for the switch. Thank you...
Touchdown67 is offline   Reply With Quote
Old 10-11-2010, 03:06 PM   #85
Captainfab
60-66 Nut
You're going to need a '69-'87 truck based (Pickup, Suburban, 2wd Blazer) power steering box from a 2wd C10, C20 or C30. You will also need a pitman arm and likely a new coupler (rag joint) to the steering column. Then you will need a power steering pump with brackets, pulleys and hoses that will work with whatever engine you are running. If possible it is a good idea to get the box and pump from the same donor truck. If you want to get new parts, just purchase them from your local auto parts supplier. Although you will need to either pay the core charges, or come up with them.
Old 11-02-2010, 10:03 PM   #86
dutchmanz
Knuckle Buster, Instructor
dutchmanz's Avatar
Originally Posted by Captainfab View Post
On the 2wd '67 & '68 all you need are 4) 1/4" spacers. You don't need this plate. Thanks for inquiring.
If the 67-68 frame is completely flat, as in my case, do I need just some 1/4" spacers or the bracket. I have a 68 4x4 with the 3 bolt manual gear. Any help would be great.
dutchmanz is offline   Reply With Quote
Old 11-02-2010, 11:40 PM   #87
Captainfab
60-66 Nut
The '67 & '68 2wd's are the ones that you only need 1/4" spacers. The '67 & '68 4wd's need an adapter plate. I have sold a few of these to guys with '67 and '68 4x4's. Let me know if you would like one.
Old 11-11-2010, 07:47 PM   #88
BIGPIMP
PIMPING RIDES
BIGPIMP's Avatar
This is the power steering adapter plate that I have been making since 1993. It is of a little different design than the others on the market. With mine you don't need to drill out any threaded holes on the steering box. All four of the steering box bolts go thru the frame. Also there is no inner plate to deal with. I don't feel it is necessary for a 2 wheel drive truck. I've had this same plate on my '66 Suburban since 1993 and put just over 120,000 miles on it with no issues. When I've installed these, I stitch weld the plate to the frame for a little added strength. This isn't absolutely necessary though, since there are four bolts securing it to the frame. The price for this bracket is $50.00 plus $10.00 for insured shipping in the USA. Included is the bracket as shown and four grade 8 bolts and lock washers.
do you still have these
1964 CHEVY 1/2 C/10 FLEET
1981 CHEVY 1/2 C/10 FLEET
1995 DODGE 1500 V6 FLEET
EAST
http://www.flickr.com/photos/bigasspimp/?saved=1
BIGPIMP is offline   Reply With Quote
Old 11-11-2010, 11:32 PM   #89
Captainfab
60-66 Nut
Yes I still have these.......
Old 11-13-2010, 12:27 AM   #90
shortbed70
shortbed70's Avatar
WOW these adaptors rock and talk about detailed instructions. Thanks John...
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 11-13-2010, 01:26 AM   #91
Captainfab
60-66 Nut
Thanks for the kind words Troy
Old 11-22-2010, 12:00 AM   #92
scubasteve16
scubasteve16's Avatar
I would like one for my '64 panel could you pm me the payment info so I can paypal payment for one please....
"If it throws you back in the seat when it shifts, it was slowing down before it shifted"
Disturbed Customs
1992 Chevy 1/2 ton 4x4 wore out 350
1975 Chevy 3/4 ton 4x4/ 8" suspension lift/ 468 Big Block/ 4 speed/ 4.56 gears/ 17' American Racing simulated beadlocks with Pro Comp 37x12.50 tires
1950 Pontiac Chieftain Straight 8/Hydromatic tranny
scubasteve16 is offline   Reply With Quote
Old 11-22-2010, 12:25 AM   #93
Captainfab
60-66 Nut
I sent you a PM.......
Old 12-28-2010, 07:52 PM   #94
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
pm sent.
Quick question;
The Power Steering unit is coming off a 79 4x4 Suburb.
From my searching these forums, it appears it'll work for my 66 with your adapter plate, but I'll need to get a Pitman arm off a 2wd, correct?
Thanks,
Robert
66 C20 Service Truck:
Old 12-28-2010, 11:16 PM   #95
Captainfab
60-66 Nut
The 4x4 boxes are the same box as the 2wd boxes, but the sector shaft (output shaft) is different. Consequently the 2wd pitman arm will not fit onto a 4x4 box.
I replied to your PM. Let me know what you think.
Originally Posted by LostMy65 View Post
pm sent.
Quick question;
Thanks,
Robert
Old 12-28-2010, 11:22 PM   #96
LostMy65
LostMy65's Avatar
That stinks! :argh:
I still want your bracket. I originally didn't plan on converting to power steering until spring/summer, but since my 66 pitman arm is shot, I figured I might as well do the upgrade now.
Old 01-04-2011, 09:46 AM   #97
gcwhite
Can i order 1 of these and a bracket for the pbb too.
1998 K3500 Crew Cab-daily driver
1987 1ton Blazer
1982 2WD Blazer
1970 C3500 dump truck
There is NO replacement for displacement!!!!
gcwhite is offline   Reply With Quote
Old 01-04-2011, 11:25 PM   #98
Captainfab
60-66 Nut
Yes you sure can. I'll send you a PM to work out payment details.
Old 02-09-2011, 08:14 PM   #99
wildearp
wildearp's Avatar
I found this forum and thread in Google a while back and finally installed the bracket:
I knew I needed it because only three bolts were holding my steering box on the frame and the spacers were lug nuts. The box was loose, almost falling off, and the frame had a slight crack. The kit mounted the box almost 1.5 inches further back than where it was hacked on. The tie rod is very close to the crossmember, perhaps less than 1/4 inch. That made me second guess my measurements, but it all seems to be OK. Great instructions.
wildearp is offline   Reply With Quote
Old 02-09-2011, 11:55 PM   #100
Captainfab
60-66 Nut
Wow, it looks like the PO was a little drill happy. I'm glad to hear you got that fixed correctly.....looks good. It'll be much safer now. The adapter plates now come with a template that works better for postioning the adapter plate.
