Old 06-21-2009, 12:50 PM   #76
joe231
joe231's Avatar
Re: Protrash Re-hash
looks like you know what your doing....I don't have a clue, but I'm going to push through all our body work anyway...
trial by fire is the only way to do it
well that and read everything I can get my hands on...
CHEVY ONLY
Old 06-21-2009, 12:53 PM   #77
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
im glad my dad knows what hes doing on the bodywork i wouldnt even know where to start
he wants me to do it but i always end up screwing it up
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 06-21-2009, 04:41 PM   #78
protrash64
Resistance is Futile
protrash64's Avatar
Thanx guys. I'm learning still; and I'm not fast at all. The biggest thing is to be clean. I wipe everything with wax and grease remover between every application of plastic or fibreglass filler.
I was going to post up some of the tools I use later. The thing that helped me the most was the 24'' sanding block. I also use a straight edge to check if what Im seeing is what is actually going on. It sounds funny, but your eyeballs will lie sometimes. I still need to get some pointers from Alan about sanding around the wheelwells and the body lines.
I just started using a hammer and dolly and I am really surprised what you can do with it. Just trying to learn things as I go, also.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-21-2009, 05:25 PM   #79
jason65
Registerd User
jason65's Avatar
Lookin good Jeff. I'm slow also. But you can see so much more when your not just flying through it. Your shave job on the outside door handles looks good. I see some around here that are so bubbled and rusted that it aint cool anymore. Do you like your static drop or the wifes pnumatic drop best?
jason65 is offline   Reply With Quote
Old 06-21-2009, 10:52 PM   #80
protrash64
protrash64's Avatar
Thanx man...you know..I have to admit I like static drops the best. Both of the trucks ride nicely. I just dont like screwing around when Im ready to go. I also would use 3/8's line...and I may redo the system at some point. 1/2'' is a pain. 1/4'' line reminds me of a deflating air matress .
The handles, and eveything else, will look better now that Im more experienced at bodywork. For people that are interested, here are the tools that I use. I use a refillable spray bottle for the wax and grease remover...all the Durablocks and I have a flexable block that is not pictured. I use the standard grinders and die grinders also....and as I mentioned before, a straight edge + a stick to check the body for straightness.
The supplies are all Evercoat (fiberglass, Rage, glaze). I use rolled adhesive backed paper. 36g for ripping down the fiberglass and then most of the stuff Im doing now is 150g....Im blocking and fixing some things. I figure the 3rd or 4th time I do this stuff the truck will be looking really nice.
Old 06-21-2009, 11:31 PM   #81
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Guide coat and I also use masking tape if a body line is giving me trouble. Lay the tape on the bodyline edge and sand up to it while using guide coat. When you feel the filler look away. Your eyes will make you hands feel things. Just try it.
Alan's Classic is offline   Reply With Quote
Old 07-07-2009, 08:45 PM   #82
daverod
SSN 706
daverod's Avatar
Your eyes can decieve you; don't trust them. Obi-wan Kenobi
Use the force. Don't you just love body work. Mine is all taken apart so I can lay it flat to work on. I feel for ya.
daverod is offline   Reply With Quote
Old 07-07-2009, 10:32 PM   #83
protrash64
protrash64's Avatar
Surprised to see this up here.......all I can say at this point is bondo-boogers and Ibuprofen.
Old 07-07-2009, 10:45 PM   #84
shortbed70
shortbed70's Avatar
I feel your pain on sanding I'm doing the body on my cab now and everyday I make a mess just to clean it up and do it again tomarrow but getting closer. Nice progress.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 07-07-2009, 10:54 PM   #85
protrash64
protrash64's Avatar
...... thanx s/b70. I'm working on my doors right now. Both are rust free but beat. They both had door check damage and the drivers door had a poorly repaired dent down low. I have the replacement panel to fix the door, but may wait until the rest of the sanding is done.
I'm finding the most difficult place to get straight is the 'indent' below the body line. It has a weird curve and I'm not sure how to approach it. So far I have been using my small Durablock to sand a small line about 1.5'' up. I then sand up to the body line from there. I then go back and sand down the lower portion. It seems to get it straight and doesnt leave any weird contour.
Any body people feel free to lend a hint or two .
Old 07-07-2009, 11:06 PM   #86
Alan's Classic
I used a 15" piece of 1" PVC pipe and put some sticky paper on it to get that inside curve. Towards the bottom of that curve I used a flat block up on it's edge and sanded at 45 degree angles to the crease. Hope you can get a visual on it.
Old 07-07-2009, 11:16 PM   #87
protrash64
protrash64's Avatar
Thanks Alan. It sounds like I'm approaching it correctly. Hmmm, I must be getting the hang of this stuff!!!!!! I have just been using my regular 'fullsize' blocks for the upper portion and using the edge to get the curve. I rely on the length not to dig any strange grooves along the whole panel.
Old 07-07-2009, 11:24 PM   #88
Alan's Classic
Sounds like the right approach. Have you dusted any black paint on it prior to sanding?
Old 07-07-2009, 11:45 PM   #89
shrunken66stroker
shrunken66stroker's Avatar
A little guide coat never hurt anything. That 24" block is key to keeping the long straight lines- long and straight. And the close your eyes and feel trick works surprisingly well. Most of the time you'll feel stuff that you'll never be able to see.
shrunken66stroker is offline   Reply With Quote
Old 07-07-2009, 11:45 PM   #90
protrash64
protrash64's Avatar
Yes. My truck has high build on it right now.....I just sand it lightly with 150 and see what shows up. After I make some corrections I spray it to see how it's looking.
I got scared off the round block after making some work for myself around the wheelwells on the bedsides.
Old 07-08-2009, 08:34 AM   #91
Alan's Classic
You have probably already learned this, but move the round block sideways at 45 degree angles then reverse the direction. That rule applies to all blocks. If you move any block in a straight line on it's edge it will dig out divets, even a round block.
Old 07-08-2009, 09:56 AM   #92
MacAttack
283 Drama Queen
MacAttack's Avatar
Wow guys, this is all voodoo to me.
I know I’ll have to face it and go through the learning curve soon (because the rust is insatiable), but I’m really not looking forward to it.
First things first though, I need to buy the welding stuff and learn how to do the patch panel thing. My boy took a series of in-depth welding classes and from the look of his various coupons - got it down fairly well.
Thanks again for the detail in your techniques and hard learned tricks.
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 07-08-2009, 01:06 PM   #93
protrash64
protrash64's Avatar
Mac.
You'll get there....plan on being completely p/o'd sometimes staring in disbelief at what you just did! I learned welding by starting on heavier stuff and getiing the feel of it. Make brackets and fix cracks and so forth. I think the best first welding project is to make a cart for your welder. You'll learn alot and you will be happy not to drag it around. As far as bodywork goes, I'm very slow. The thing that helped me the most was, as shrunken66 mentioned, getting the 24'' block. It really keeps you from digging in one place too much.
I will continue to post up stuff as I go; even if I'm the one with the bruised ego!!!!
Old 07-08-2009, 01:24 PM   #94
MacAttack
283 Drama Queen
MacAttack's Avatar
Gee - sounds like me in the bathroom the morning after a huge Mexican dinner and way too many Corona's.
Mac.
Old 07-08-2009, 01:24 PM   #95
joe231
joe231's Avatar
we all appreciate that!
i meant this...
not what mac said
CHEVY ONLY
Old 07-08-2009, 01:27 PM   #96
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
I found your thread, I cant believe I didn't see it before. Looks good, you got any pics of your phantom grill?
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 07-08-2009, 01:30 PM   #97
protrash64
protrash64's Avatar
i meant this...
not what mac said
........I figured as much, unless you meant to say 'lite a match' before that statement.
Mac.
......sounds like a very shallow 'learning curve' to me.......
Old 07-08-2009, 02:00 PM   #98
joe231
joe231's Avatar
CHEVY ONLY
Old 07-08-2009, 02:29 PM   #99
MacAttack
283 Drama Queen
MacAttack's Avatar
I knew you would.
Yeah - true dat, and sometimes it splashes back.
Mac.
Old 07-08-2009, 03:01 PM   #100
jason65
Registerd User
jason65's Avatar
