11-12-2009, 12:02 PM | #76 | |
Re: LFD's project white lightning -- 1968 fleetside "basically stock"
And as far as cutting install time by half, I think while it does save some it also takes more prep and fit of the parts because everything has to fit 100% perfect or the spot welder will not work at all. As with plug welding you have a lot more leigh way and it only takes some grinding of the welds and you are done. So it does save time but not really much in the end of the job. Kevin LFD Inc. |
11-13-2009, 08:58 PM | #77 |
I got a bit more done today on the firewall before running out of my sanding disks. Good thing my supplier will be at the goodguys show this weekend so I can restock.
Kevin LFD Inc. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
11-13-2009, 09:49 PM | #78 |
A320 Pilot/USAF Retired
It's been said many times, but you sir do GREAT work!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
11-13-2009, 10:41 PM | #79 |
11-14-2009, 12:46 AM | #80 |
6>8 Plugless........
Kevin, thanks for the info! Keep up the awesome work!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-14-2009, 01:28 AM | #81 |
hey kevin, looks great.... i really like how you made the firewall/ engine recess symetrical with the pass side, doing away with the spot for the clutch rod...also i like the 45* wire gutter cap.....with all that work id say you're past the 'stock look', and the only thing id suggest to enhance what you've already done, is shave the steering wheel opening, and go with a nice aluminium bulkhead...
11-14-2009, 11:12 AM | #82 | |
Kevin LFD Inc. |
11-14-2009, 12:25 PM | #83 |
how do you like the gibbs? have you done a paint job after using it? where do you buy it?
11-14-2009, 10:19 PM | #84 | |
Kevin LFD Inc. |
11-17-2009, 06:00 PM | #85 |
Well the fire wall is done just waiting on the A/C unit so I can build mounts in side the cab with out any visible fasteners then I will fill the old A/C hole. Then once that is done I will drop the cab back down and start the Cowl panel mods! I hope to have it all finished up by the end of the month.
Kevin LFD Inc. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
11-17-2009, 06:29 PM | #86 |
How does the gibbs compare to say 3m brand weld through primer? That is what I have been using and have always wondered if it was a good product or not. I usually can't see it after it is welded up.
11-17-2009, 06:37 PM | #87 |
Gibbs is for bare metal so it won't flash rust before being sealed with an epoxy. It is not a rust preventer that can be left forever.
Kevin LFD Inc. |
11-17-2009, 06:41 PM | #88 |
Oops, sorry about that. Is that spray can in the pic the gibbs you are talking about? That sure would be nice to have so you don't have to keep recleaning the metal if you are too busy to get it all finished up and primed. Have you ever used the 3m weld through primer? Just curious to whether it is good or if I need to find a better one.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 11-17-2009 at 06:42 PM. |
11-17-2009, 11:38 PM | #89 |
I am wondering what you use under that gutter cap for rust protection.
Tim |
11-17-2009, 11:55 PM | #90 | |
Under Construction
Before doing any welding I first treated the bare metal gutter, then seam sealed the factory seam before coating it with a good top coat.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
11-18-2009, 12:45 AM | #91 |
Every thread I see that has LFD In the title I check out and learn at least two new things from it. You are the man Bro
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
11-18-2009, 09:44 AM | #92 | |
You would be willing to post templates for the wire channel would you??? Thanks for sharing you progress and tips. Always a learning experience. |
11-18-2009, 11:30 AM | #93 |
PITbut
Woohoo, new thread. I like that gibbs stuff.
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
11-18-2009, 12:27 PM | #94 | ||
As for treating the metal, it depends on what shape the metal is in to start with. If their is real rust already I will cut it out and replace the bad parts. As with this truck the metal was super and bare as could be from blasting. I always send cabs to the blaster on one of my tip and flip dollies with the tip arms so they can flop it all around and get every nook and cranny. And since they charge by the hour it is also less money because it makes it so easy to do. So once it gets back from the stripper I spray everything down with Gibbs oil and let it soak in for a few days before starting. Gibbs can be painted right over but I still recommend wiping it down with a prep wipe first. The Gibbs penetrates down into the metal and just gives one more layer of defense. Then I will use a bare metal rust inhibitor (brand is not important they all do well in this set up) let it dry real good then top cote it with a good epoxy like DP90. Now this is just for down in the gutter where I will not be welding. Were welding will take place I skip the DP90 and use a weld through primmer (their is a pic of the can in the passenger side door during rocker install) and cote both surfaces that will get welded and let it dry over night. Then weld it up and move in to the next area. I have never had rust come back through but anything is possible, my way may not be perfect but it sure is toms better then what the factory did for us. It has been very rare that I have seen any kind of protection in concealed areas so figure any precaution we take will last that much longer. Also after we build these I don't think their are a lot of them that get left out in the field for another 10+ years just left to the elements. Kevin LFD Inc. |
11-18-2009, 04:38 PM | #95 |
Thanks for the step by step procedure Kevin. I agree every little bit will help. It seems that that's all these trucks do in our area is rust.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 11-18-2009 at 04:38 PM. |
11-18-2009, 11:03 PM | #96 |
Thanks I guess I didn't see any over spray of primer so had to ask. I think any thing is better than what they did at the factory and look how it lasted with these truck being used as trucks. I know mine will not see the same conditions and will out last me. I am going to look into Gibbs for my future projects I am impressed so far.
Tim Tim |
11-18-2009, 11:12 PM | #97 |
Still Learning
Kevin,
I am assuming since your customer is going to use some type of aftermarket a/c and heater system? Which one is he using do you recommend a certain brand? I have heard good things about Vintage air. I am preparing to start on cab project for my son's truck and am trying to decide whether or not to smooth the firewall or use the original heater and a/c. I think I can handle the metal work, just not too sure about going as far as you have on this one. Also, do you use straight argon for your tig? thanks, Mike |
11-18-2009, 11:41 PM | #98 | ||
Yes I use 100% argon for my tig and 75/25 for my mig. Kevin LFD Inc. |
11-25-2009, 08:40 PM | #99 |
Ok A/C showed up and it is the Vintage Air custom fit unit. I will start first thing Friday morning (after waking from my food coma) and build the mounts for the inside of the firewall then I can fill that big hole I have been starring at for too long now. Then onto the cowl and a few other misc tasks and if all goes well it should be finished up by Monday or Tuesday at the latest.
Kevin LFD Inc. |
11-27-2009, 01:28 AM | #100 |
high-Tech Red Neck
Right on, im stoked ofr another LFD build!
They are great motivation.
"He used to be a pretty nice feller, now he's a welder!" |
