05-10-2010, 05:50 PM | #76 |
Re: Tri5 55 build
looks great. Just 1 tip before any body work install your door rubber to make your doors close! It took me 2 days to get mine to work.
05-10-2010, 07:06 PM | #77 | |
Tripple Five Fanatic
Re: Tri5 55 build
Tri5
1955 Chevy Stepside/LS1 drive train http://67-72chevytrucks.com/vboard/s...d.php?t=371513 |
05-10-2010, 08:27 PM | #78 |
Re: Tri5 55 build
The best way for me to tell you is 1st align the window frame with the cab. Line up your body lines at the top and the belt line. Watch your top corner so it does not hit the top of the cab and center the door in that opening first. The body lines are more imporant than the gaps. You can close the gaps by welding filler in. I used a motorcycle lift to help lift the doors and hold them
05-10-2010, 08:33 PM | #79 |
Re: Tri5 55 build
This is for AD but the principle is the same. In the same section is other information on rebuilding hinges, installing and adjusting strikers, etc.
http://www.stovebolt.com/techtips/doors/alignment.htm I used a floor jack and helper on mine, but I can see where a MC jack would be better. They are pretty cheap at Harbor Freight.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 05-10-2010 at 08:34 PM. |
05-10-2010, 08:46 PM | #80 |
Re: Tri5 55 build
They are a pain to adjust, no getting around it. Lots of trial and error.
Brandon 63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne 57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380 72 K20 Long bed stepside (wife's) 72 K20 Long bed 396 (flip or keep...?) The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476 |
05-13-2010, 02:38 PM | #81 |
Re: Tri5 55 build
webrodder.com has a great little set of articles on 55-59 body work and a specific article on door alignment
05-16-2010, 07:59 PM | #82 | |
Re: Tri5 55 build
I need to finish my hydroboost before I move on to another small task like lining up the doors, small task Tri5
05-27-2010, 06:08 PM | #83 |
Re: Tri5 55 build
Tri5
Did you get a proportioning valve with your hydroboost unit? I didn't with mine and can't get a good answer wether it needs one or not. Do you now if it's built into the master cylinder or not? I called a chevy dealer and the parts guy didn't show one for my unit. It just seems odd it wouldn't have one. Thanks for any info. Kim |
05-27-2010, 07:21 PM | #84 | |
Re: Tri5 55 build
I got one with my Hydroboost, I pulled the complete unit; MC, Hyrdoboost and Proportioning valve.. Tri5
1955 Chevy Stepside/LS1 drive train http://67-72chevytrucks.com/vboard/s...d.php?t=371513 Last edited by Tri5Nerd; 05-27-2010 at 07:27 PM. |
05-28-2010, 12:29 AM | #85 | |
Re: Tri5 55 build
I went back to the yard I got mine from and none of the trucks had prop valves on them. The parts guy at the chevy dealership couldn't find one listed for an 05 truck. Now I'm really confused. I'll have to research a little more and see what I come up with. Kim |
05-28-2010, 01:00 AM | #86 | |
Re: Tri5 55 build
Tri5
1955 Chevy Stepside/LS1 drive train http://67-72chevytrucks.com/vboard/s...d.php?t=371513 Last edited by Tri5Nerd; 05-28-2010 at 01:02 AM. |
08-01-2010, 05:00 PM | #87 |
56 - autocross
Re: Tri5 55 build
Tri5
I just noticed your firewall. Tell me more about it? It looks like you went all the way up with it. What did your use for metal? What did you do with the inner cowl? Get rid of it? Do you have any pictures of it along the way? Look Great. |
08-01-2010, 10:53 PM | #88 | |
Re: Tri5 55 build
Tri5
08-01-2010, 11:46 PM | #89 |
Sectioning the hood
Since Kabwe, Kim57 and I talked about doing this mod and Kabwe did his I said what the heck, lets try it, here is my attempt at sectioning my hood.
Looking back I would make the cut line a little higher, this would create less work like adding little pieces of filler metal on the corners. Or better yet when cutting the bottom line, instead of cutting 1" take a about 1/2" when doing the corners. I also use those black maker lines to line up both top and bottom when tacking everything back together. Now it's time to take the hood off and finish welding then metal finish and do the brace. Do you see the slope?
08-02-2010, 12:29 AM | #90 |
Re: Tri5 55 build
Looks good Tri5.
Kim |
08-02-2010, 10:14 AM | #91 |
Certified Car Nut
Re: Tri5 55 build
looking good, now its kim57's turn.lol
08-03-2010, 12:49 AM | #92 |
Re: Tri5 55 build
Ok, now you guys are makeing me want to get a new hood and start chopping! Looks great Tri5!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
08-04-2010, 09:06 AM | #93 |
Re: Tri5 55 build
Yeah, I want to do it too but with my tall air intake i can't. Yours is looking good, though. Try not to get addicted like Kabwe. Pretty soon you'll start dreaming of what to cut up next.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
08-04-2010, 11:57 AM | #94 | |
Re: Tri5 55 build
BTW: No one cal be like the Professor Kawbe. Tri5
08-04-2010, 01:26 PM | #95 |
Certified Car Nut
Re: Tri5 55 build
See there you guys go.lol
Tri5 its looking really good. OKGMC4, stop making fun of me, its not right to tease people who have a sickness. Yes I'm a cutaholic. |
10-22-2010, 01:47 PM | #96 |
Re: Tri5 55 build
nice build. Any updates?
Doug Looking for a 67-72 short bed driver..... |
10-22-2010, 04:51 PM | #97 |
Re: Tri5 55 build
Not too much to report, just been doing stuff around the yard: tearing down and building a new BBQ island and little things with the truck. I still need to finish the hood, Hydroboost and install the drop spindles before moving on to other task.
Tri5
10-22-2010, 05:35 PM | #98 |
Re: Tri5 55 build
Nice projet with your diff at 58 inch what size is your big rear tires ?
thanks |
10-22-2010, 08:23 PM | #99 | |
Re: Tri5 55 build
Tri5
10-22-2010, 10:35 PM | #100 |
Re: Tri5 55 build
Those tires are size 20 ?
