Old 06-10-2010, 12:42 PM   #76
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: LS engine swap info
Wow! $500?!
I got mine from Wait4me, I think I will try Nelson performance in SA, a custom tune is $300.00 and they mail order too.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-10-2010, 01:42 PM   #77
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Thats list for a Wester's tune probably...Brian discounts the price, especially if he doesn't have to reference Westers data for your tune. Brian can also do a dyno tune....rather then a "bench" tune. I plan on taking my truck over to him to help dial in my combo when its complete. He's worked on my TBSS and it picked up like .4x to .5x in the 1/4.
Nelson is OK but Wait4me wouldn't be my 1st choice. You could also buy HPTuners or LS1edit and do it yourself?
Mine will be easier to tune I think. Just select the right curve for the MSD box and the rest is jets, air bleeds, and set screws....screwdriver work.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-18-2010, 11:27 PM   #78
tk-mpl
tk-mpl's Avatar
Wow, lots of info here.... Thanx guys...
Does anybody have and photos of the lokar shifter cable installed.. I am having trouble with it right now so if you got pics of the trans and the steerring column that would help.... Any tricks would be helpful too..
1968 short box stepside.
2007 5.3L 4L60, tuned w/EFI Live
2005 Silverado bucket seats.
Dominator 2600's all around.
Porterbuilt tubular control arms.
Magnaflow 3" dual exhaust.
tk-mpl is offline   Reply With Quote
Old 06-19-2010, 07:26 AM   #79
Shon
Which one? I have used both styles and ended up with the rod style over the cable style.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 06-20-2010, 01:43 AM   #80
tk-mpl
tk-mpl's Avatar
I got it figure out.... Finally found a pic. of it installed on the column. Where it is attached to the trans it is at quite an angle though..
Old 06-20-2010, 02:18 AM   #81
dwcsr
Hollister Road Co.
dwcsr's Avatar
Originally Posted by 68GMCCustom View Post
Try Brian. He even has a dyno.
Exatorq
I have to agree. He seem like a good honest guy. Even did some work for me without charge that got me out of a bind. I shipped my PCM to him and he did a quick turn around.
dwcsr is offline   Reply With Quote
Old 07-08-2010, 12:36 PM   #82
low_84_inchaska
low_84_inchaska's Avatar
what walbro pump are you guys using for the external?
also can i use my factory lines on my 84 and adapt to them to the fuel rail and to the pump to tank.
my build http://67-72chevytrucks.com/vboard/s...d.php?t=367330
84 short-wide 2wd. 99 5.3 vortec, built 4l60E, schoenfelds, bubb tune, cyber grey metallic
10 camaro ss/rs, 6spd manual, leather, loaded, cyber grey metallic
low_84_inchaska is offline   Reply With Quote
Old 07-08-2010, 12:36 PM   #83
low_84_inchaska
i am shipping my harness and computer to waitforme performance to get reworked, seems like i cannot get ahold of the other guys and jesse seems to be a good guy.
Old 07-08-2010, 12:39 PM   #84
Shon
I am using an ebay "E2000" pump <$50.
Just need the right fittings/clamp for the factory stuff to work
Old 07-08-2010, 01:26 PM   #85
Clyde65
Clyde65's Avatar
I used a Pierburg Pump from Turn Key Engine supply.
Low_84, I would just save the $ and ship it to Nelson Performance, they will do you right. Not that there is anything wrong with Jesse, he is a really nice guy, it's just that Nelson Perf has a very good rep here and on LS1Tech/Ls1truck.
I went with Jesse and them, the work they did was fine for a stock tune, nothing more( all the stuff was eliminated and I wanted it on, like front O2's the CEL, and other sensors) the harness didnt look very clean at all. no instructions were with it at all. After 2-3 calls, I figured out what went where. Their communication is on the poor side though, very frustrating.
I DID get what I paid for.Knowing now what I know, I would get an after market harness and a perf tune. Try Fuel Injection Connection (FIC) for your harness, they quoted me $508 for the engine harness with 4l60e, all relays and such for fuel pump, ac and stuff.
If your putting your LSx in your 84, just get a tank from an 87 and put the Walbro 255 in it.
Hope this all helps.
Clyde65
Rebuild of Clyde
support our troops!
Old 07-08-2010, 04:04 PM   #86
Shon
I use Current Performance out of Florida
Old 07-09-2010, 09:48 AM   #87
low_84_inchaska
i have a question on the 4l60e,,,,apparently you "have" to have a speedo for the tranny to shift?? well here is the problem, my 84 has a broken analog speedo and i dont really want to deal with the speedo right now. i thought the computer shifted the transmission.
Old 07-09-2010, 09:58 AM   #88
Clyde65
Clyde65's Avatar
You would need an electronic speedo, the truck will run and all without one, you will just be a target of Johnny Law without.
You can switch the tail housing out to a 700 ( or aftermarket) but I think that is expensive. You also can purchase an electronic speedo from many different guage companies, takes a bit to get them configured but it isnt all that bad.
The trans shifts the trans, the computer just monitors it and adjusts the rpm and or timing if needed, I really dont think it cares what the trans is doing.
Clyde65
Rebuild of Clyde
support our troops!
Old 07-09-2010, 10:00 AM   #89
low_84_inchaska
yeah, or i could use gps,,,hillbilly style,,i just want to get it on the road.
so where should i send it...to current or nelson..
current 450 for harness rework 175 for factory tune
nelson 450 for harness rework 150 for factory tune
one thing i like about current is there fuse/relay block they include
Old 07-09-2010, 11:02 AM   #90
Puglia10
Whats this lokar shifter cable i hear about? you cant just put a lq4/4l80e and be good? how much is it?
also, has anyone tried blackbear for tuning? what do you do, just send them your pcm and harness? will they do a performance tune for the same price instead of a stock tune?
1979 c30 3+3 dually
1946 GMC
Puglia10 is offline   Reply With Quote
Old 07-09-2010, 11:33 AM   #91
Puglia10
also, if the motor i get just has harness/pcm and altenator, am i screwed with no power steering pump? what else am i going to need?
1979 c30 3+3 dually
1946 GMC
Old 07-10-2010, 07:48 PM   #92
Shon
The computer has the trans tables in it, the PCM needs the VSS pulse to know what is going on but you do not need a speedo for this funtion to work. But if the trans and PCM do not get the info they need it will stay in limp home mode.
Old 07-10-2010, 07:50 PM   #93
Shon
I have used both Lokar shifter setups. One is a cable style and I did not like it that much, was a PITA to set up. I am now using the rod style but it is limited, I can only go to 3rd gear with that shifter b/c of the angles just wont allow it.
As for what a company will do for you, why not contact them to find out!? that is the best source of info.
Old 08-16-2010, 11:35 AM   #94
low_84_inchaska
I have a question on the 5.3 truck motor.
is the alternator, ps pump, water pump, starter and brackets the same for the 1999 and on motors....say will accessories off a 04 work on a 99?
thanks,
jason
Old 09-02-2010, 11:46 AM   #95
74project
Thanks for the info. just got a 5.3 vortec with 50k miles for 500$. im putting it in my daily driver, may the carb and my knowledge for it go straight to hell. Vegas heat sucks for the performance.
74project is offline   Reply With Quote
Old 10-02-2010, 11:00 AM   #96
LEEVON
LEEVON's Avatar
I'm sure this has been covered in another thread, but here's a reminder about oil pressure and water temp fittings. The metric-to-npt fittings are available at speedwaymotors.com. They might be found cheaper somewhere, but they shipped quick and fit perfect:
Water:
http://www.speedwaymotors.com/LS1-Wa...pter,8195.html
Oil:
http://www.speedwaymotors.com/LS-Ser...DisplayId=8195
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 12-10-2010, 10:27 PM   #97
justpball
justpball's Avatar
lots of great info thanks!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 12-11-2010, 12:22 AM   #98
68GMCCustom
Water:
Oil:
good info and I just recently bought (and recieved) those from them....along with my new oil pressure and water temp gauges.
still need to do something about the steam vent tho. whats the best way to do that on our trucks?
Kurt -
Old 01-07-2011, 09:08 PM   #99
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Terrific Job with this thread!!!!
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 02-16-2011, 01:01 PM   #100
kSStamp0182
LSX addict
kSStamp0182's Avatar
http://www.frozenboost.com/index.php...04a9f3530288b7
a link for those trying to get around not running cats. enjoy
hope it helps someone!
-1982 C10 SWB GMC Sierra [undergoing 6.0/4L80E swap with mild restoration]
kSStamp0182 is offline   Reply With Quote
