Closed Thread
Old 03-18-2010, 12:02 AM   #76
OYMC
Custom 1987 GMC Crew Cab Short Bed
Just a few more...
OYMC is offline
Old 03-18-2010, 12:04 AM   #77
OYMC
last few...
OYMC is offline
Old 03-18-2010, 12:42 AM   #78
OYMC
The remedy...
After taking a number of measurements I discovered that the rear axle center line was between 5 3/4" - 6" to far forward, and needed to be brought back.
After unbolting the rear leaf spring shackle hanger I found that the difference in measure between the two vertical sets of mounting holes was very close to the distance I needed to move the axle back. In order to insure that the suspension would remain square to the chassis I decided to reuse the two rear mounting holes on the chassis to the two front mounting holes on the shackle hanger.
As for the front leaf spring hangers I discovered that the distance between the two lower chassis mount holes where 6 1/4" apart. I thought to myself how much I would be able to tell having the axle center line back 1/4" from exact wheel well center? After determining that I more than likely will not notice any real difference in 1/4" I went for it.
I scribed a line over the top of the two lower chassis mounting holes for the front leaf spring hanger all the way back until I ran the scribe off the end of the chassis. Once I reattached the front lower leaf spring hanger mounting hole to the rear mounting hole on the chassis, I adjusted the angle of the hanger until the top of the lower rear hanger mounting hole was in line with my scribe line. At that point I tightened the bolt down so the hanger would not move out of adjustment. I drilled out the two top chassis mounting holes through the existing hanger mounting holes, and then drilled a new mounting hole through both hanger and chassis about 3" above the existing rear lower hanger mounting hole. *Note the two bottom holes on the hanger bolt to a separate bracket, and not the chassis.
The lower bracket required a little fabrication to be reused. After I had fully assembled the front leaf spring hangers to the chassis, I attached the lower bracket to the hanger.
Because I moved the hangers back 6 1/4" the angle of the chassis has changed (Chassis kickup), and the lower bracket no longer fits the way it should.
While the lower bracket was attached to the hanger I could build a wedge into the bracket that would fill the gap between the chassis and bracket. I used construction paper to make my templates, and then cut out the final pieces from 1/4" flat stock. After welding everything up, I test fit my new bracket(s), and everything looked, and should work great!
Other parts I moved: Shock mounts, brake line bracket, bump stops (Yet to be installed), and the parking brake cable guide bracket.
All in all I am very happy with the way it all turned out.
Tomorrow I will be installing the gas tanks, and bump stops. If I have time I will refit the bed to see how it all looks.
Oh yeah...I didn't paint the brake shoe backing plates because I have plans to convert to discs.
OYMC is offline
Old 03-18-2010, 09:38 AM   #79
dropd80s
dropd80s's Avatar
Re: Custom 1987 GMC Crew Cab Short Bed
Measure twice. Cut once.
dropd80s is offline
Old 03-18-2010, 03:26 PM   #80
OYMC
I don't know if you actually read my last Post, but I clearly stated that I didn't measure the two different beds at all.
I As! U Med.
I did measure the length difference of the short bed leading bed mount to the trailing bed mount. The bed fits the chassis perfectly, I just should have cut a little less up front, taken a little from the back, and drilled new bed mount holes. That would have been easier than moving the entire suspension...
Live and learn... As long as you learn from your mistakes, and can be man enough to admit when you are wrong, then you'll be all right!
I am not looking for comments of what I should have done differently, I have already figured that out... But thank you nonetheless.
OYMC is offline
Old 03-18-2010, 08:19 PM   #81
OYMC
Test fit bed...
Axle Centerline is fixed
OYMC is offline
Old 03-18-2010, 08:23 PM   #82
OYMC
I tried fitting the factory fuel tanks in today, and there is no way to make them work unless I drop the hangers. If I do that, the tanks are to visible (Not an option).
I am going to pickup a set of 1/2 short bed tanks today or tomorrow (Still waiting to hear from the guy who has a set) and see if those will work.
The 1/2 ton tanks are 4 gallons smaller (Each) which is kind of a bummer, but once I have this truck running at 20 MPG, I don't think it will be as big of a problem.
More soon to come!
OYMC is offline
Old 03-18-2010, 09:56 PM   #83
ghettoluxury
ghettoluxury's Avatar
looks like everything turned out fine
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline
Old 03-19-2010, 12:22 AM   #84
OYMC
It's confirmed... I'll be getting the 1/2 ton short bed tanks tomorrow...$0
OYMC is offline
Old 03-19-2010, 09:17 AM   #85
justpball
justpball's Avatar
sweet free is always good!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline
Old 03-29-2010, 11:50 PM   #86
OYMC
Oh boy! you guys will never guys what I just bought for this project...
Chevy Dana 60 front axle with a box containing a complete new rebuild kit for axle...
Hydro Assist steering
High steer / cross over steering (Brand new)
All new tie rod ends
Brand New polished aluminum diff cover
drop pitman arm for 2wd Steering box
Rebuilt 2wd steering box
14 Bolt FF rear axle
New bearings and seals
New Disc brake conversion
New polished aluminum diff cover!
and I should be getting my custom built aluminum radiator with electronically controlled electric fan any day
This truck is going to be insane!
I'll have photos soon... Our female American bull dogs is about to have puppies any day, so my wife and I have been busy getting ready...
OYMC is offline
Old 03-29-2010, 11:51 PM   #87
OYMC
Here are our babies...
OYMC is offline
Old 03-29-2010, 11:52 PM   #88
OYMC
needless to say, my wife and my son have nothing to worry about while I'm not home...
OYMC is offline
Old 03-29-2010, 11:54 PM   #89
OYMC
Oh yeah... My male American Bulldog's name is "Diesel." He is 124 lbs. I could have just as easily named him 6.2... ha ha!
OYMC is offline
Old 03-30-2010, 12:00 AM   #90
OYMC
Wow... Seems I keep forgetting things... The axles are 4.10's and I have just bought my 3rd fleet side short bed. I think I am happy with the one I have now, but only time will tell.
The last bed I bought came with two nice 1/2 ton 16 gallon fuel tanks. After I finish my land cruiser project (Customer's truck). I'll be wrapping up most of the initial build requirements for the crew cab.
Once the truck is fully put together, I will completely disassemble it for chassis powder coating, body, paint and upholstery...
OYMC is offline
Old 05-11-2010, 03:55 AM   #91
OYMC
I just bought a 2007 Dodge 1 Ton 4X4 Roll over truck with only 42,000 miles! Oh yeah, it has a cummins and a 6 speed manual trans! Can you say 650 FT of Torque baby!
The 6.2 was going to be turbo charged with a custom built NV4500... After comparing the price it would cost to build a 6.2 with that setup, it seemed more reasonable just to put in a Donor 24V Cummins...
I'll post photos in the next day or so...
Stay tuned.... One of the BADDEST CREW CAB SHORT BED BUILDS....
OYMC is offline
Old 05-11-2010, 01:40 PM   #92
SBTork
Garage wrench
SBTork's Avatar
very cool update, this truck will be awesome
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline
Old 05-11-2010, 04:41 PM   #93
bitchin85
bitchin85's Avatar
if i had the cash, this is exactally the truck id build.. only i dont know if id use a new dirtymax or cummins.. but i have always wanted a crew long or short lifted with a new diesel in it. this thing is sick bro.. keep up the awesome work!
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline
Old 05-11-2010, 10:13 PM   #94
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
5.9 or 6.7? Very cool!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline
Old 05-11-2010, 11:03 PM   #95
3r!c84
Badass
3r!c84's Avatar
1968 Corvette 5.9 Cummins tubbed drag/street car are u forreal! can you send me pics
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline
Old 05-12-2010, 02:45 PM   #96
walkerb
walkerb's Avatar
NICE-subcribed
walkerb is offline
Old 05-12-2010, 10:15 PM   #97
RMrider17
Hey sorry im a little late for this conversation, but totally a graduate of Wyotech next month in June 2010, out at the Blairsville PA Campus. And totally the same stuff here with big headed people and it being an introduction, truck is looking badass by the way haha
-Adam
RMrider17 is offline
Old 05-12-2010, 11:43 PM   #98
OYMC
The long awaited photos:
2007 Dodge 3500 4X4 with a 5.9L Cummins diesel...
Only 42,000 miles!
OYMC is offline
Old 05-12-2010, 11:47 PM   #99
OYMC
This truck is a roll over... Chassis, axles, motor, radiator, intercooler, etc... Perfect and untouched...
Body...Trashed!
6 Speed manual trans (G56 Mercedes Industrial medium duty)
OYMC is offline
Old 05-12-2010, 11:49 PM   #100
Dieselwrencher
Ditch that G56! They are a problem child and hard to get parts for. Very nice score though!
Ryan
Closed Thread
