#76 |
Re: Another Dropmember version???? :)
Nate, which one did I end up with?
Posted via Mobile Device |
#77 |
The mild.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#78 | |
A guy with a truck
Is it safe assume, with the touring version, that the UCA mount moves up the same inch, no longer allowing use of the stock inner fenders? Have you fit an LS motor w/ F-body accessory drive with either version? Anyone driving on one of these yet that can give impressions? This thing looks great, Nate. Might have to make this my third Dropmember... Posted via Mobile Device
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#79 | |
Very safe to assume..... On the Touring version, all the suspension pivot points are raised one inch higher than the "mild" version. There are a bunch of them out there, but only a few board members who have them. Should start seeing more and more on the road and I am sure they will give their impressions. I am installing a front and rear set-up (Touring) on one of my 70s here soon.... gonna drive it all the way to Dallas for the Goodguy's show in October. ![]() Here are some more details.... When running a 28" tall tire and a 2.5" drop spindle, the Mild version has a ride height of 7" from the bottom of the frame to the ground. (We reference the bottom of the frame-rail right behind the front cab mount). The picture shown has a tire installed that is just under 30" tall, thus the 8" measurement. When I measure my 70 that is completely stock, this equates to right at a 5" drop. The Touring version would make it a 6" drop. Keep in mind, that we have 2.5" drop spindles, so the crossmember alone would yield 2.5" of drop if using a factory height spindle. ![]()
#80 |
A guy with a truck
Was planning on forgoing GG for CTC this year, but between you and Cheby showing at GG, we may have to change plans...
#81 |
A guy with a truck
One more question (for now): you've stated that the track width is narrowed 1/4" per side when using this crossmember. Is this with the CPP modulars, or in addition? Basically, if I ditched my current Belltech 3" drop spindles and stock suspension, would the mild DM and CPP modulars narrow my track width an inch (.25 for DM and .75-ish for spindles) per side?
#82 | |
#83 |
67cheby
![]() Join Date: Sep 2008
LOL....thats what i am talking about, lets have the biggest C10 turnout Dallas has ever seen !
#84 | ||
A guy with a truck
#85 |
67cheby
well i know we can at least 1 up it...i was there but my truck wasnt there last year so that is 1 more !! LOL
#86 |
Make that 2, I should be there as well
#87 | |
#88 |
A guy with a truck
Perfect. This is looking better every day...
#89 |
Never Done?
![]() Join Date: May 2000
Chassis bracing looks great - is that a trailing arm cross member?
Is the bracing available separately? |
#90 | |
#91 |
A guy with a truck
Looking on PBs website, the bracing is a one-off item, intended for a four-link, not available for purchase, yet...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 06-17-2012 at 04:37 PM. |
#92 | |
#93 |
Junior Member
Nate, that looks great! My 67 is not going to be safe for very long. Can't wait till you get everything dialed in and road tested. BTW those Ridetech coilovers are sweet (I have a set on my 69 Camaro and love them).
Would like to see complete pkg setup front & rear (prices)! Posted via Mobile Device |
#94 | |
#95 |
![]() Join Date: May 2007
Sweet so the rear package comes with a 9" .
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#96 |
It's 9" compatible.
![]() Customer requested a 9". The only difference between the four-link components for the 12 bolt vs. 9" is the spreader bar that ties the 4-link brackets together and runs under the housing. The one for the 12 bolt is contoured differently.
#97 |
A guy with a truck
Looks great
#98 | |
![]() This kit utilizes the Stage 2 notch, and is the best fit for he Mild Dropmember. All the components also package nicely under an unmodified bed floor. Since the Touring Dropmember has a more aggressive stance, the rear kit that will matches best uses the same notch as the Dropmember Rear Mild kit. It's ride height is a couple inches lower allowing for a no rake stance. Since it includes a deeper notch, the bed floor needs to be raised approx. 5".
#99 |
C-10 Club Member
Beautiful.....
Man I wish I could find a pot of gold for that mild kit. This would be the perfect combo between stance/handling. Did you post a price front/rear for the mild kit? I like ![]() ![]()
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels 1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910 |
#100 |
Junior Member
I'd like to see some more pics of the trailing arm setup for the coilovers. I want to keep my 5/7" drop w/stock bedfloor. Looks great!!!!
