Old 06-18-2011, 11:34 AM   #76
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Br3w City's Project omgwtfbbq
Good looking build man keep up the good work..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 06-20-2011, 08:03 PM   #77
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Thanks Frenchie!
Looks like my issue is the TAC module and pedal. I purchased an 06 (all plastic) set.
BUT because I'm running an 03 motor and 04 pcm (just found this out lol), I need to match the TAC and pedal. So an 03-05 pedal is in order. The newer style TAC uses 2 potentiometers to gauge position; one that reads 0-10v starting at 0, and the other reading 10-0v...starting at 10. This acts as a failsafe, but the extra signal confuses the older style TAC module. It sees the voltage change and triggers the u0107 code, putting the truck into limp mode. This is why is revs once, but immediately loses connection. A VERY nice member on ls1tech has agree to ship me the new pedal asap for my old one, so this problem should be solved shorty. I will post pics of the update soon.
I have also started a fully welded header back 2.5" custom exhaust, with Flowmaster straight through "mufflers" **cough ** resonaters **cough**
I have a little plan for the exit....but thats a surprise for now.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-22-2011, 03:18 PM   #78
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
A little more messing around, still just kind of putzing things around a bit to see how ideas might work.
Old 06-23-2011, 03:51 PM   #79
jb1016
"Oh well, it's a driver."
jb1016's Avatar
Nice build man. I'm digging the LQ4.
Old 06-24-2011, 12:39 PM   #80
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Thanks man!
Got my new DBW pedal and tac from LS1Nova71, swapped over the connections and she fired right back up. Throttle response seems great, and she rev's freely! Looks like another lesson learned; having a matched TAC module and pedal, to the correct ecm is important.
I'll post another vid after this weekend.
These are some crappy phone pics of the new pedal installed on the fire wall. We had to modify the pedal; shortening it about 3 inches and changing the angle.
Managed to install the gauge cluster, and just have 2 or 3 small connections to the fuse panel and she's done. I also cleaned up a little more loose wiring. This weekend should yield the finished rough fab on the exhaust, re-mount of the hood and possibly fenders....and if all goes well, the FIRST ROAD TEST!
Old 06-29-2011, 12:34 PM   #81
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Well after MUCHO fab on the exhaust to get the side exit fitting and sounding ok, its DONE! Exhaust is all on. Today we fired up, let her warm and took her for a drive! Runs super smooth, the 4l80e shifts great, and she has GOBS of torque. Its super rich since its on a "get it running" tune, and after its dialed in, I should be good to go for some real power.
We still need to slash cut the end and do tips, but they fit up great and sounds pretty decent. With true duals and the resonater only side-exit, AND the cam....it ends up sounding a big like a chopper lol.
http://s112.photobucket.com/albums/n...t=IMG_0623.mp4
the only hiccup, I didn't double check the lug on an aluminum wheel and almost lost it. I actually had that happen once before on my s10, so we quickly pulled over and tightened her up. She runs like a champ! More pics and video, after we return from a message from our sponsors!*
*Sponsors meaning my employers want me to work instead of sitting on the forum all day...f*ckers.
Old 07-01-2011, 09:35 AM   #82
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re mounted my fenders (for now, I still want to put a sealer in between before the final attachment. Re-wired and tested my LED tail lights. I' really like the way they look with the cups moved and welded into the tail hole in the fender. Not hard to do and looks pretty clean.
Quick teaser of the side of the truck. She may be 1 color by this weekend.
Old 07-01-2011, 11:14 AM   #83
SFTorange
SFTorange's Avatar
Looking good! I'm glad to hear you got the bugs worked out in the DBW setup. Should be a blast to drive.
SFTorange is offline   Reply With Quote
Old 07-01-2011, 01:15 PM   #84
shortbed70
shortbed70's Avatar
Looks good! What cam did you go with in the motor? Better put up a sound clip to see if we like it...
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 07-01-2011, 02:51 PM   #85
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Its a Texas Speed Tsunami 235/240 .648"/.609" Camshaft on a 111LSA
Pipes are 2.5" tru duals through magnaflow resonators. Its pretty loud, idles like a bike.
I have some video clips I will try to post in a few. I can't seem to get videos to embed correctly, even though I've been told how lol.
Old 07-01-2011, 02:54 PM   #86
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
can't edit anymore?
Old 07-01-2011, 05:35 PM   #87
SulphuriousSam
SulphuriousSam's Avatar
Cuz of course if "we" don't like it you should get another cam.
1966 C10 LWB, 283, 3 on the tree (lots of work to do!) http://67-72chevytrucks.com/vboard/s...d.php?t=471348
2001 Suburban daily driver
2008 HHR (wife's ride)
SulphuriousSam is offline   Reply With Quote
Old 07-06-2011, 11:06 AM   #88
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You should be able to hear it in that video, I'm not sure why I can't edit my post...I still suck at embedding video....sad
I got her sealed up all 1 color, loose interior ends buttoned up (still need to do the radio and A LOT of custom work) so I could get it on the road. Took her to a local show, and put almost 500 miles on her in 2 days!!
Oil pressure is 40+ on startup and maintains about 54 at cruise. Temps never see more than 193*, and this is on 90* days in stop and start. I didn't push it since it hasn't been on the dyno yet for the tune, but the get up n go is there.
Pics from the weekend are on the way, and although I have lots of bodywork and such to do...I'm extremely proud of where I've come.
Old 07-08-2011, 12:21 PM   #89
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Here are some recent pics from the trip to the Dyno Yesterday.
Thanks to Tom and the Guys out and West Bend Dyno LLC in West Bend WI. They have taken great care of me and the truck, and are my go-to guys for tuning.
2 videos from some time on the dyno. I STILL can't get this embed to work correctly.
Old 07-11-2011, 04:44 PM   #90
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Got some shiny new tips for the side exit
A current one from the side, all one color!
I have also recently installed my pioneer DEH4800MP Ipod head unit, re did my blaupunkt 6x9s and my baby kenwood 3.25"s in the dash, as well as adding my Sparkly Blue matching vinyl to the sun visor.
I should be going in for the cage soon.
Old 07-25-2011, 11:30 PM   #91
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I have had some time but not a lot of motivation the past week or so. I lost my job Tuesday; although im not thrilled with the situation, but I wasn't all that happy at the company I was at and hope for some good change.
I did take some of the time I had to work on the tubs. Did some marking and modifying, but after a few tries I got everything set up to cut. A little but of patience and the bedsides removed.
Took a while to get it welded up, and i started to run out of gas but did get her all stitched up. Some of the older bed coating decided to light up on me, guess i didn't strip it back far enough. I need to wipe it down and get it coated, but they are in and secure.
Old 07-26-2011, 04:23 AM   #92
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Coming along quite nicely man, very cool!
fryer1979 is offline   Reply With Quote
Old 07-26-2011, 03:08 PM   #93
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-27-2011, 12:46 AM   #94
enick72
enick72's Avatar
Nice build. Why the tubbs? Plans on swapping the rear end?
55 Chevy 1st series
65 Chevy stepside short bed
www.bigslikpokertables.com
enick72 is offline   Reply With Quote
Old 07-27-2011, 10:31 PM   #95
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
can't fit enough tire into the stock stepside with the bedsides in place. The tubs are a bit generous (they come 3" to the frame center), but will let me run as much rear tire as I can...between the fender, and the frame.
Old 08-25-2011, 06:24 PM   #96
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Ill have some new pics coming soon! Bed has all been coated with liner and the bed floor is being made. I have some 15x12 beadlocks being made, fitted with 325/50/15 ET street radials. Should finally be able to hook this thing! I've also made some small tweaks to the dash as well.
Until the other pics come in, we decided to crack out some one shot and throw the name on the tailgate for fun.
Old 09-06-2011, 12:38 AM   #97
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Well, apparently in a union shop, if you tell a customer something will be ready by a deadline...its ok to miss that by a number of days.. SO my wheels are not here yet, but my new tires DID arrive.
Mickey Thompson 325-50-r15 ready to be mounted. Now I'll have some traction.
Old 09-06-2011, 12:41 AM   #98
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I haven't been feeling well, trying to kick a cold before LS Fest. Luckily, my pops did me a solid and helped out with a bed floor for the truck. I was supposed to have a sheetmetal floor made, but again...some shops just like to piss on customers I guess. A sheet of 1/2" and a piano hinge and viola, instant bed floor (well, there was some labor in there too lol) This will more than do for now, so I can use the bed at least travelling, or until a more elegant solution exists. Still, pretty damn nice for a quick afternoons work.
Thanks pops!
Old 09-15-2011, 09:17 PM   #99
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Some recent shots from before during and the road home from the trip to LS Fest in Kentucky.
Old 09-15-2011, 09:20 PM   #100
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
And I managed to win Best Classic Truck
